Welcome to the North American Subaru Impreza Owners Club Thursday April 26, 2018
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 04-22-2018, 09:16 PM   #2101
simpleJ
Member#: 391748
2015 WRX
CWP
Originally Posted by blancoWRX18 View Post
2018 WRX Mikey Tuned
FMIC
TGV/EGR
DP
CBE
INTAKE
AOS
I have been tuned for roughly 8K miles, under low load and driving in lower speeds noticed my AFR bounce up, no boost. Car slightly hesitates but once acceleration is applied goes back to normal. Any areas of concern here? Ive emailed Mikey but have not received a response yet.
DAM is fine, no knock.
https://datazap.me/u/blancowrx18/log...og=0&data=5-18
Any input I will greatly appreciate it
Ive already check for leaks from the AOS, BPV, INTAKE, and couplers. Everything checked out. All passed so Im out of ideas here.
need wot log
simpleJ is offline   Reply With Quote
Old 04-22-2018, 10:15 PM   #2102
Schoat333
Member#: 452248
2017 Base WRX
Need some help understanding how the ECU reacts here. I am running a cobb stage 2 for ETS intake map that I modified the target a/f ratio very slightly using access tuner. with the original OTS map I was seeing the a/f sensor peg at 10.3:1, so I dialed it back in the base target map above 4500 RPM and those torque requested range to see what effect it would have. Is it normal to have that much of an error between the target a/f ratio and actual? Maybe the ETS intake MAF scaling is off a little and I need to adjust?
I know its not a redline run, but this was just to see how the a/f ratio reacted to my changes above 4500 rpms
Good news is no knock either way I guess.
https://datazap.me/u/schoat333/modif...13-14-16-22-25
Schoat333 is offline   Reply With Quote
Old 04-23-2018, 12:24 AM   #2103
Scoobman20
Member#: 388015
Looks like the MAF needs a little work. You may want to match up your OL and CL maps at the transition too.
Scoobman20 is offline   Reply With Quote
Old 04-23-2018, 02:22 PM   #2104
Schoat333
Member#: 452248
2017 Base WRX
That's what I figured. Thanks!
Old 04-23-2018, 02:37 PM   #2105
ayau
Member#: 332408
On stage 2 bolt ons and E85 flex with OEM catback protune.
If I get a more free flow catback, would I need a retune? Typically a catback only mod wouldn't require a tune but wasn't sure if already having a J pipe makes a difference.
I'm guessing the OEM catback will free up maybe a few HP but nothing significant.
Update:
Tuner said to check for overboosting after a catback is installed.
ayau is offline   Reply With Quote
Old 04-24-2018, 11:48 AM   #2106
Schoat333
Member#: 452248
2017 Base WRX
You mentioned having the OL and CL maps match up. Did you mean the CL main D map for high load? The other CL maps all show stoich 14.6-14.7:1 so I assume it's just this high load map that I would want to edit.
Old Today, 12:05 AM   #2107
ayau
Member#: 332408
Nothing really else to do the car now but do some WOT logs lol.
https://datazap.me/u/ayau/log-152471...og=0&data=9-25
Old Today, 08:15 AM   #2108
Pisdauf
Member#: 485197
Hey guys, first post from long time lurker. Would truly appreciate if someone could eye over this datalog as I'm still new to the tuning thing. Got a protune recently on my new WRX after a few mods and it kind of feels like there is a lot left on the table, although I could be mistaken. Granted, I would rather have a safer tune than go balls out and blow up a new car.
it put out 270/275 on a dynojet which I thought was low but tuner said was normal
2018 WRX 6MT
3RD GEAR PULL
PROTUNE
93 OCT
-TGV/EGR DELETE
-FULL CATLESS INVIDIA EXHAUST
-GS EBCS
https://datazap.me/u/pisdauf/pro-tun...g=0&data=16-18
Thanks in advance, lots of helpful stuff around here!
Pisdauf is offline   Reply With Quote
