12-10-2008, 01:52 AM | #1 |
Member#: 192178
Vehicle:99' Impreza wagon All red! |
95 OBS Gas and no go?
I am looking to buy a 95 impreza wagon but the owner of it says it starts up fine and idles fine but when the gas is applied the car does not move. Anyone know for sure what would be causing this?
It sounds to me that it could be the throttle cable, or a fuel problem. I would like to know what I am up against before I descide to buy it so your help ASAP! would be much appreciated. Thanks, Dan
12-10-2008, 02:02 AM | #2 |
Member#: 90235
SCIC
Vehicle:1993 GC ej255 swap White |
check the fuel filter it might be clogged, check the throttle cable if its loose.
12-10-2008, 02:19 AM | #3 |
Member#: 192178
Yah, that could be it. The car is about an 8 hour drive away so I would like to bring as many parts it could be as possible to make sure I cover all angles. Anything else it could be?
12-10-2008, 02:33 AM | #4 |
Member#: 90235
SCIC
does it have the intake box?
12-10-2008, 03:02 AM | #5 |
Member#: 192178
12-10-2008, 01:52 PM | #6 |
Member#: 90235
SCIC
to much air will choke the motor and it will run very lean and it will die out
12-10-2008, 02:26 PM | #7 |
Member#: 159986
AKIC
Vehicle:2014 Jeep Patriot Blue-ish |
Doesnt move as wont move in gear?? or wont rev up when open up? id bring a can of starter fluid, to check for intake vaccum leaks. if its in gear and wont move, if its an auto, maybe a good band tightening job, or stick maybe throw out bearing, or clutch? isit throwing any codes do you know?
12-10-2008, 03:34 PM | #8 |
Member#: 80465
RMIC
Vehicle:2001 2.5RS Black Diamond Pearl |
it's hard enough to diagnose a car thru the internet when you have it, it's even harder when you yourself haven't even seen the car. according to your first sentence, i would take off the parking brake.
12-11-2008, 03:15 AM | #9 |
Member#: 192178
I am sure the owner is no that stupid. Like I said just wanted to get a few ideas of what it could be before I make an 8hour drive to look at it. Want to try and fix it if I do by it. Sounds like it could be a simple fix and the owner just does not know jack about cars. So we will see.
11-16-2009, 12:04 AM | #10 |
Member#: 197278
Vehicle:1999 Lifted OBS |
Just curious as to what happened. To me, it sounds like the transmission's forward drives are shot.
11-16-2009, 01:32 AM | #11 |
Member#: 192178
I never bought the car so never found out. Bought a 99 impreza L instead
Similar Threads | ||||
help!!! flashing cel and no one can help | tommy 02wrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 21 | 06-05-2010 07:26 PM |
FREE: 95 OBS 1.8L Motor and Gearbox | gongeuzler | NWIC Private Classifieds | 4 | 10-16-2007 01:25 PM |
Spiders, gas and no clothes don't mix. | HoRo1 | Off-Topic | 9 | 04-02-2006 09:40 PM |
Some Show and No Go.. | Nightstar | Member's Car Gallery | 55 | 10-19-2005 06:29 PM |
HELP!! Give it gas but car has no go! | Sobelizard109 | Service & Maintenance | 3 | 05-10-2003 01:49 AM |
