Approx 30K miles of use, no wrenches and visable signs of adjustments on height retainers. Damper inserts are HUGE. As big if not bigger than my Bilstein PSS9's I have on my VW. I can see some scratches on the inserts but they do not leak or bounce. IIRC they are 20 way dampening adjustable front and 18 rear. Dampening adjuster knobs move smooth and click firm. The height shown is set with 4.00" downward adjustment left in the front and 4.50" remaining in the rear. There is 2" upward adjustment left both front and rear from where it sits now. So: 6" up down front, 6.5" up down rear. They have been spayed down with white lithium grease on a regular basis to prevent corrosion and height retainers move fine. I am running 205/55/16" tires on JDM BD5 BBS Forged wheels with a +55 offset and they are close in the rear, and rub the liners in front only very seldom, and only on hard bumps and in aggressive corners (at current height shown) The one and only reason I am willing to part with these is I have a very bad back from a previous work injury and even on the lowest dampening setting my back starts to hurt on my daily commute. If you autocross there are no limits to how high or low or how stiff you want these bad boys.
So, I am looking for $550 shipped straight up. Not looking for suspensions in trade as I put my stock springs back in with new KYB's today
-Jason
Located in 05403 Vermont
