08-30-2002, 03:25 PM | #1 |
Member#: 11786
AKIC
Vehicle:2014 OB 2.5i 6MT Custom Dirt/Snow twotone |
lets talk head swapping.
question, will the '02 2.5 heads fit a 2.2 block? this is in consideration of building a turbo motor, so would there be any benefit to this rather than just running the regular 2.2 heads? or is there a better combination?
08-30-2002, 04:17 PM | #2 |
Member#: 2958
NWIC
Vehicle:2001 2.3RS? |
IIRC, the 2.5 heads flow slightly better than the 2.2 heads. You would need to figure what head gasket to use and what timing belt.
EJ25 heads on a EJ22 Turbo block would be a great turbo motor. J |
08-31-2002, 12:42 AM | #3 |
Member#: 11786
AKIC
anybody know the right belt and gasket to use? obviously id like to draw off anyones prior knowledge than trial/error myself.
Lets talk Legacy Spec B 6-spd swap into '06 WRX | jay25RS | Transmission (AT/MT) & Driveline | 10 | 03-17-2008 03:02 AM |
Motor bulders: Lets talk heads. | DoctorNick | Normally Aspirated with bolt-on Forced Induction Powertrain | 12 | 02-06-2003 03:34 PM |
Lets talk about head work and raising the redline | Red Rocket | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 14 | 06-14-2002 04:41 AM |
Lets talk wheel size 17s or 18s | ACT | Brakes, Steering & Suspension | 6 | 04-02-2001 03:22 PM |
