Welcome to the North American Subaru Impreza Owners Club Monday December 10, 2018
View Poll Results: Year/model of the car the failure happened
04 STI 34 11.45%
05 STI 19 6.40%
06 STI 88 29.63%
07 STI 20 6.73%
08 STI 12 4.04%
05 LGT 6 2.02%
06 LGT 9 3.03%
07 LGT 3 1.01%
08 LGT 0 0%
02-05 WRX 55 18.52%
06 WRX 18 6.06%
07 WRX 12 4.04%
08 WRX 9 3.03%
04-08 FXT 12 4.04%
Voters: 297. You may not vote on this poll
Old 12-16-2015, 04:38 PM   #851
Myblack2006sti
Member#: 391159
- 2006 sti
- 89,000
- turbo gone engine rebuild
- nope said it wasn't a problem with the oil pick up tube breaking
- spt intake
Myblack2006sti is offline   Reply With Quote
Old 04-12-2016, 11:37 AM   #852
suburrito
Member#: 384053
2006 STI
SGM
- 2006 sti
- 110K
- none, was changing proactively, and noticed 3 cracks forming
- no warranty
- pro tuned stage 2
suburrito is offline   Reply With Quote
Old 09-21-2016, 09:29 PM   #853
KIMCHEE
Member#: 430003
2015 STI Limited
2015 STI Limited
18,500 Miles
Stock
My wifes commuter car.
Oil tube pickup issue. CEL came on about 100 miles ago. Subaru is ordering the parts.
KIMCHEE is offline   Reply With Quote
Old 11-24-2016, 12:29 AM   #854
hondaeater69
Member#: 60324
1998 RS
Originally Posted by KIMCHEE View Post
2015 STI Limited
18,500 Miles
Stock
what was the CEL for?
hondaeater69 is offline   Reply With Quote
Old 11-24-2016, 12:32 AM   #855
hondaeater69
Member#: 60324
1998 RS
wow i'm glad i found this thread. i have an 06STi motor in my rs conversion! seems 06sti motors are failing dis-proportionally. hot dam. why isn't this sticked? i'm coming up on 30K miles, so i'll be getting the killerb and getting it installed before driving it any more. this thread is what nightmares of made of. i'm not sure i'll be able to sleep until this gets fixed !!
Old 12-15-2016, 01:33 PM   #856
todd_fuller
Member#: 79004
2005 Impreza WRX STi
Crystal Grey
- 2005 STi
- 127k miles
- R&R pickup tube while doing oil pan gasket since I was in there
- pickup tube had no cracks.
todd_fuller is offline   Reply With Quote
Old 12-15-2016, 06:04 PM   #857
Silver VR4
Member#: 240625
This was a few years ago, but:
2006 STI
85k(I forget exactly when I replaced it, but I know it was under 100k when I did it)
Oil pressure light would flicker on start up, no damage otherwise
Noticed cracks near the top flange on pick up tube
Replaced with KillerB pick up tube
Silver VR4 is offline   Reply With Quote
Old 12-16-2016, 11:31 AM   #858
CHR1S H4NSEN
Member#: 330050
I'll be putting in the KillerB in the next few months.
2017 STi
CHR1S H4NSEN is offline   Reply With Quote
Old 12-19-2016, 10:37 AM   #859
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
We've been making our pickup since 2009. Over the years I've heard more stories than I can count. It's always saddening when a $20 part destroys a several thousand dollar engine :/ To date our 'failure is not an option' design had zero failures. Very proud that we can provide a part that helps instill confidence in the cars we love so much!
Thanks so much for the support guys!!
KillerBMotorsport is online now   Reply With Quote
Old 03-24-2017, 12:52 PM   #860
NoobaruSubaru
Member#: 457635
2015 WRX STi
World Rally Blue
2015 STi
25,xxx miles
100% Stock
Dealer is replacing my engine and everything oil related. They placed emphasis on the oil pick up tube and pump. Will be ordering a KillerB pick up and see if my dealer will use that instead lol.
NoobaruSubaru is offline   Reply With Quote
Old 03-24-2017, 01:12 PM   #861
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by NoobaruSubaru View Post
2015 STi
25,xxx miles
100% Stock
We sell the pickup to many dealers. If they have any issue with it (and they are not already using ours), have them give us a call.
Old 06-13-2017, 07:21 AM   #862
RexKwonDo
Member#: 404751
kind of insane that I did this on my 2007 STI and ten years later, I will probably have to do it again on a 2017 STI.
SMFH SUBARU
RexKwonDo is offline   Reply With Quote
Old 06-14-2017, 01:04 AM   #863
motoman399
Member#: 270808
SMFH SUBARU
After the warranty period of course! Subaru should have to replace all the failures!!
motoman399 is offline   Reply With Quote
Old 06-15-2017, 03:28 AM   #864
RexKwonDo
Member#: 404751
That's what I was thinking...I usually only tend to keep cars for 2-3 years tops, if it goes before then at least it won't be at my expense. Still, pretty absurd that the company would rather just keep replacing blown motors than just fix the f'ing problem.
Old 06-15-2017, 08:00 AM   #865
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Well, they tend to stick to the contract; if it fails before warranty period, they cover it.
There is likely some bureaucracy involved as well since Subaru sources them from another OEM. Also, in Japan where new car ownership is much shorter than here in the US, this is next to non-existent in the JDM.
Old 06-19-2017, 03:23 AM   #866
Abismo
Member#: 99707
2018 WRX Premium CWP
Curious what the oil pickups for the 15+ wrx / sti look like. have you guys cracked those open yet?
granted different motor I know of course.
Abismo is offline   Reply With Quote
Old 06-20-2017, 09:07 AM   #867
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
All 2006-current MY STi pickups are the same part number.
FA pickups are different, and we do make a pickup for those as well. The tubes don't fail, but we have see screen failures that have caused the pump, crank, etc. to be destroyed by allowing larger debris into the pump. The OEM FA pickup has spot welds that cause the screen wires to break very easily. Ours has a larger screen area and uses a different process to hold the screen in place... among other changes to improve oil flow
Old 06-20-2017, 12:35 PM   #868
Abismo
Member#: 99707
intriguing. has there been any reports of those screens breaking and grenading engines. As always that pickup looks beefy.
Old 06-20-2017, 03:05 PM   #869
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I and a couple others have had similar experiences, but this is going to be a chicken and the egg argument. Did the pump failure cause the engine to blow, or did the engine blowing cause the pump to fail. Either way, the screen lets go. Here are some pictures of OEM, the failure we had... that led to creating our own pickup.
Old 09-10-2017, 03:57 AM   #870
dingobite
Member#: 82391
08 OBP Sti
Block seized up bearing shattered last july with 2 years 13k+ miles on this motor i havent had the heads inspected yet to see if they are useless.
Mechanic couldnt even hand crank the block this pipe has 58,000+ miles on it
dingobite is offline   Reply With Quote
Old 09-10-2017, 11:22 PM   #871
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Just curious are you running the stock motor mounts, what weight engine oil, and do you ever run the car hard before the engine/oil is fully warmed up?
Fierysun is offline   Reply With Quote
Old 09-11-2017, 12:00 AM   #872
dingobite
Member#: 82391
08 OBP Sti
During the winter i wouldnt mash the gas till after a couple miles or the coolant was up over 190, oil i used went through two oil changes both around 7500 miles total was 20w50 motul classic (conventional oil) finally changed over to 0w40 mobile during 2016 winter. Its generally 40 degrees or lower here for almost 6 months when i leave work so im sitting for atleast a minute every morning.
Stock motor mounts ive since added group N mounts with this rebuild i also had a issue where bank one would throw a misfire code after swapping new old parts spark plugs it only hid the code much better though it was still present.
Biggest issue i had by far the turbo itself was draining oil out the gasket sometimes it would pressurize and id think everything was alright, i didnt even see it the mechanic did the oil would miss the everything in the engine bay except the bottom tray and a drip or two on the drain hose.
I was always topping off the oil the last 3000 or so miles before it was fixed.
I do drive fast still do mostly its 3-5 miles drive at the ramps where i really give it some gas.
Old 09-11-2017, 09:25 AM   #873
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I've been collecting data since 2009 trying to find a correlation. If there were a correlation, I'd be on top of it; if you do 'X', you need 'Y' (pickup) because data 'Z' shows the effect. It would make marketing them so much easier. So far, the data is all over the map
Old 09-11-2017, 05:59 PM   #874
Fierysun
Member#: 82745
2005 Subaru STI
It's most likely not going to be a single incident that cracks the oem oil pickup, but the same conditions repeated over and over again. For dingobite's case, his engine oil probably isn't fully up to operating temp with only a 1 minute warm up time and 40F degree's outside before spirited driving. Thick cold oil is going to put a lot of stress on the pickup. With that being said, I'm not saying this is the cause, but it certainly doesn't help to run the engine hard with cold oil. Also, I'm theorizing that the stock motor mounts doesn't do the pickup any favors with the huge amount of engine shake that it provides.
Old 09-11-2017, 09:18 PM   #875
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ I would buy the cold oil more than anything. Seen failures from OEM to solid mounts and everything in between.
With the pickup submerged and filled with oil it's fairly well dampened from engine movements.
Cold oil on the other hand, doesn't like to flow. Since these engines (specifically the rod bearings) are so sensitive to oil condition I recommend an oil temp gauge as the first most important gauge to own on cars with these engines. If you don't have a gauge, then wait twice as long as it takes for the coolant needle to stop moving (normal operating temperature).
Oil pickup tube failure mikeb01453 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-24-2009 10:39 AM
Oil pickup tube torque spec? LeeC Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-11-2008 01:15 PM
oil pickup tube. jstam Built Motor Discussion 26 09-04-2008 06:56 PM
Oil pickup tube torque spec? LeeC Built Motor Discussion 0 07-24-2008 06:54 PM
oil pickup tube, need help asap please ihadmail Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 07-11-2008 12:25 AM
