05-17-2012, 07:05 AM | #176 | |
Member#: 171948
Vehicle:19 Sti Crystal white |
05-17-2012, 12:59 PM | #177 |
Member#: 241254
Vehicle:2015 Scat Pack |
05-17-2012, 01:51 PM | #178 |
Member#: 220868
South East
Vehicle:2005 STi Urban Camo Orlando, FL |
^ There ya go!
05-17-2012, 05:06 PM | #179 |
Member#: 207561
AKIC
Vehicle:2018 Forester Limite Pearl |
For those who still have A/C, I had mine vacuumed and refilled properly (not the DIY method) and have noticed that my car is running much more smoothly. I'm having noticeable differences in my everyday running temps even with the A/C not in use.
06-08-2012, 12:18 AM | #180 |
Member#: 98955
Vehicle:2011 WRX Hatch White |
Anybody try 3M High Temperature Aluminum Tape???
http://solutions.3m.com/wps/portal/3...beNG0PRPD79Lgl Wonder how it would compare to DEI cool tape. Would it make a good cheaper alternative? |
06-08-2012, 08:59 AM | #181 |
Member#: 264877
How durable is this DEI tape. I know it's only been around a year or two, but how does it hold up for a daily driver?
06-08-2012, 12:41 PM | #182 |
Member#: 220868
South East
I have never used the 3M stuff so I can't compare directly.
The DEi stuff has held up pretty good for me, It is still applied to the TMIC with very little damage or peeling. It has been on for almost 3 years now too, pretty good so far. |
06-09-2012, 08:58 AM | #183 |
Member#: 236952
Vehicle:2010 WRX (SSM) Stg 2+ 310/370, 6sp R180 |
CM,
Do you guys sell T-bolt clamps alone? I'd like to add them to the things I'm ordering but can't find any on your site |
06-11-2012, 03:13 PM | #184 |
Member#: 220868
South East
Yeah we do, I'll shoot you a PM.
06-11-2012, 03:27 PM | #185 |
Member#: 236952
PMed you back! thanks
06-13-2012, 12:51 AM | #186 |
Member#: 98955
Recently installed an SPT turbo heat shield over the stock shield. Also applied some DEI cool tape to the underside of the SPT shield and one thing I noticed is a slight ~1-2 improvement in MPG. The area right above the turbine seems cooler now as well at least not as scorching as it used to be. I want to say the heat soak seems less now as well. Didn't notice whether spool up is any better. I think the slight MPG improvement alone makes it worth the $60 for me.
06-13-2012, 12:57 AM | #187 |
Member#: 98955
What other things are good to wrap besides turbine, downpipe and intercooler? I want to be able to chill my bear in the engine bay.
06-13-2012, 01:07 AM | #188 |
Member#: 298536
South East
Vehicle:2013 STI Satin white |
nice write up, heat really is killing my subie this summer -_-
06-14-2012, 09:10 AM | #189 |
Member#: 207561
AKIC
Anyone with experience with a turbo chimney? Saw a post about one the other day and wondered if it worked or was more of a gimmick
06-14-2012, 09:42 AM | #190 |
Member#: 142029
Vehicle:2013 Forester 2008 350z, 1991 Miata BRG |
^^ I had one long ago and it worked well. It only fit the standard WRX TMIC though. i'm not sure if someone makes one for larger TMIC's... maybe Subtle does?
06-14-2012, 12:47 PM | #191 |
Member#: 45076
Vehicle:2004 Stg 2 wagon AT 16 BRZ. Both silver |
I agree it worked real well, but when I went STI TMIC it does not fit. I have it in my garage and its for sale in the Tristate classifieds if you are interested.
06-14-2012, 01:18 PM | #192 |
Member#: 207561
AKIC
I've got a V7 STI TMIC so it probably wouldn't help. Thanks for the info though.
06-14-2012, 01:56 PM | #193 | |||
Member#: 220868
South East
Wrapping your intake in the heat reflective tape can help as well. For cooling you can get an intercooler sprayer, either water or N2o. |
06-14-2012, 05:09 PM | #194 |
Member#: 236952
just need a DP, exhaust wrap, turbo blanket, AP, and tune |
06-14-2012, 05:19 PM | #195 |
Member#: 166427
South East
Vehicle:03 wrx |
i just been mind focked
this is something to think about. |
06-15-2012, 08:37 AM | #196 |
Member#: 322973
Vehicle:2009 WRX black obsidian pearl |
Does the heat wrap have any adverse effects? Could this cause heat to be trapped inside the turbo causing the oil temperature to be higher?
06-15-2012, 11:06 AM | #197 |
Member#: 79222
W. Canada
Vehicle:'09 STi 297.5 WHP Blue |
The oil gets pumped around and the water keeps the temps down to where it's supposed to be...
06-21-2012, 02:35 PM | #198 |
Member#: 220868
South East
There will always be a debate on whether or not heat being held in will be bad or not, but personally, I'd rather have the heat held in then radiate all over the engine bay and affect all the surrounding parts.
06-26-2012, 11:44 PM | #199 |
Member#: 305025
Great thread, thanks for the info. the question is. how is the butt dyno?
06-27-2012, 12:27 PM | #200 |
Member#: 220868
South East
It helps, especially when you have to sit for awhile at a light, etc.
Before you could really tell driving around the city or in traffic etc. when the TMIC got heatsoaked. With all the heat shielding it helps, it will never completely prevent heatsoak but it definitely helps keep it cooler longer. |
SCCA AUTO-X: Bartlett Beat in the Heat Bonanza | JordyB | Alaskan Impreza Club Forum -- AKIC | 65 | 08-13-2008 12:57 AM |
Beat the Summer Heat With the All-New Portable Seat Cooler! | NYCshopper | Non-Subaru News & Rumors | 5 | 01-06-2007 12:05 PM |
How are you beating the heat? | upnygimp | Off-Topic | 9 | 09-27-2006 05:34 PM |
Beat the Heat | iWayner | South East Region Forum | 5 | 07-25-2003 06:13 AM |
Austin: Beat the Heat | TriniTuner | Texas Impreza Club Forum -- TXIC | 7 | 02-14-2002 10:20 PM |
