Welcome to the North American Subaru Impreza Owners Club Sunday October 20, 2019
Old 06-11-2017, 03:09 PM   #1
AJ_2002
Member#: 413694
Default 02 WRX mysterious issue
I have a 2002 WRX with 196k miles on it and am having a difficult issue to diagnose. The car has a cobb stage 2+ tune with a uppipe, downpipe, turbo inlet, boost controller and a intake. The car idles well and runs normal until 3500 rpms where it then starts to spit and sputter and misfire under boost. Car normally boosts to 15-17lbs and now will only go to 10ish lbs. I put a fuel pressure gauge on the car and it read about 45 psi at full throttle (low) and i replaced the factory pump with a walboro 255 and it didn't fix the problem. I have looked the car over for boost leaks several times with no luck. I swapped the Fuel pressure regulator with a spare with no change. Only codes the car would display is misfire codes occasionally when at WOT above 3500 rpms and it varied on cylinder each time. I have pulled plugs and checked gap, swapped plugs with other known good ones, swapped a coil with a known good coil, switched coil positions, all with no change. I take the car to a experienced Subaru and he ruled out fuel as a issue and diagnosed it as a bad MAF, i replace the MAF with a new one and the car gains a little improvement in power at WOT for a couple pulls and then goes back to the same issue. The only time i had luck with the issue going away is when i pull the fuel pressure regulator vacuum hose off the intake manifold and the car will boost to 10-12 lbs without a misfire or sputter. The issue will only happen occasionally with the FPR vacuum hose unplugged.
Any recommendations or past experiences that were similar are appreciated
AJ_2002 is offline   Reply With Quote
Old 06-12-2017, 01:58 PM   #2
astanley
Member#: 456114
02 wrx
gray
I'm going through the same problem. 02 wagon blouch16g, catless up, Tomei inlet, tgv deletes, 650 inj, DW45 fp. Just three days ago my car was boosting fine up to 20psi. Now I can barely touch the throttle without it sputtering and maybe misfires? I'm gonna do the plugs, I already ran all the fuel out, and checked for boost leaks and found none. No vacuum leaks either I'm stumped.
astanley is offline   Reply With Quote
Old 06-12-2017, 02:09 PM   #3
subaru_gc8
Member#: 29292
2004 WRX wagon
when my car was doing that, we tried to change alot of different stuff, found out when I changed all the coils and plugs it stopped
Old 06-12-2017, 11:29 PM   #4
Fino
Member#: 417685
'03 V7 STi, 4.44
Sonic Yellow
That does sound like an ignition issue. I'd check the plugs and coil packs. Is it throwing any codes?
Fino is offline   Reply With Quote
Old 06-13-2017, 09:32 AM   #5
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Did this just start after the COBB items were installed or has it been a while after the install?
Given the age & mileage, I'd suggest the same as subaru_gc8; change all plugs and coils. Coils only last so long.
Old 06-15-2017, 12:16 PM   #6
mjtct
Member#: 455505
I had a similar issue in cylinder 3. Switched coil pack with cylinder 1 - that didnt fix it. Changed cylinder 3 injector connector - that wasnt it. Moved spark plug 3 to cylinder 1 and replaced the coil pack connector on cylinder 3. Fixed
Car had strange surging under load which eventually became a misfire under load. Finally ended up a steady misfire in 3.
mjtct is offline   Reply With Quote
Old 06-15-2017, 03:18 PM   #7
monkeyposeur
Member#: 333468
93 SS - 06 OB XT
03 WRB GD 205/22T 20G-XT
I had a similar issue. My battery terminal connection was loose and it would vibrate at higher rpms. Guess I got lucky mine was a simple fix.
monkeyposeur is offline   Reply With Quote
Old 06-20-2017, 02:16 PM   #8
thebionicman
Member#: 247561
2011 TR-42S
If you power cycle the engine does it go away for a while?
Mine does the same as what you describe, but if I am coasting, key off, key on, pop the clutch to start I can make boost for a while (few minutes) then it starts with the issue of no boost over 10 psi.
thebionicman is offline   Reply With Quote
Old 06-20-2017, 04:31 PM   #9
Silver_fozzy
Member#: 364356
Chapter/Region: HIIC
2000 Forester (s)
Silver/black (two tone)
Default similar issue
I cleaned my IACV, MAF, CRANK, and CAM sensors and one of them fixed my misfire under boost. You should also check your timing, mine wasnt off but i heard 1 tooth can cause something similar to your issue.
Silver_fozzy is offline   Reply With Quote
Old 06-21-2017, 02:29 PM   #10
Blue Meeko
Member#: 344674
2003 Impreza wrx
Replace coil packs. ( with factory ones).
Blue Meeko is offline   Reply With Quote
Old 09-10-2019, 05:52 PM   #11
mjtct
Member#: 455505
I tried switching cylinder coil packs and injectors. Finally fixed after replacing all coil packs. Something weak in the Subaru ignition. Most coil packs I have replaced are clearly failed
Old 09-11-2019, 10:57 AM   #12
subaru_gc8
Member#: 29292
2004 WRX wagon
most coils these days have to be inspected for discoloration and stuff. my subaru went about 6 months before I got a misfire light and I couldn't get into boost at all. they way our computers work is unless there is a certain number of anomalies on a drive cycle, it wont trigger the cel. But anyways glad you found the problem
Old 09-13-2019, 11:03 AM   #13
shineyTwrex
Member#: 361473
2003 WRX
Holy crap man, thank goodness you posted this up. Im having similar issues too!
WOT above 3500rpm it sputters. i usually pull around 18-20psi, and now today i got like 11.2psi... checked all my VAC and hoses from intake to the Intk Air Manfld, it was all fine.
AFR was fine. But if you resolved the issue with coil packs and all that jazz, then ill probably shoot for that too then.
shineyTwrex is offline   Reply With Quote
Old 09-13-2019, 11:20 AM   #14
7m-gtte
Member#: 192102
2003 WRX WRB
VF-39
Sounds like coil pack issue. Mine did the same thing.
7m-gtte is offline   Reply With Quote
