Welcome to the North American Subaru Impreza Owners Club Saturday October 19, 2019
Old 09-07-2019, 02:23 AM   #1
epeder1102
Member#: 436463
2004 WRX
Default Cruising and Idling Extremely Lean?
I just installed an AEM wideband into my 2004 WRX. The car is fairly new to me, my second WRX. The problem I am seeing is that for normal around town driving the AFRs seem normal around 14.7 to 15.3 at idle and low speed cruising and becoming fairly rich under boost. However, the other day I got on the highway and cruised at 70 and slowly watched the AFR creep higher and higher. After about 45 mins of cruising my gauge was maxed out, meaning AFR > 18.0.
This scared me so I pulled off the highway, noticed idle was maxed AFRs too and reflashed my tune via the accessport. Upon restart idle seemed normal, but when getting back into cruising at 70ish, the AFRs maxed out much quicker than before. Everything else about the car seems normal. It pulls hard and becomes nice and rich under boost. No hesitation or stuttering. Idle is perfectly normal even when the AFR was maxed. I'll attach a picture of my accessport numbers from when I pulled over, just before I reflashed the tune. I do get some knock numbers once in a while but DAM never drops below 16. AF Learning is never negative, which I think means it is always adding fuel...could maybe point to a possible problem? I'm not sure where to start here since the car seems normal otherwise and although I know the stock front O2 sensor isn't very accurate, it still never read more than 15.0 at idle or cruise the whole time when looking at the accessport AFR. Maybe I have a faulty wideband sensor for my AEM gauge? Any help would be appreciated, I'll list my mods below. Thanks.
EDIT: Forgot to add that there are no obvious vacuum leaks, however I have not done a proper boost/vacuum leak test yet. Seems to me that if that was the problem it would run lean right away not just after some time of driving. The problem consistently happens after 20 to 30 mins of driving on the highway. Also, there is no check engine light on.
2004 WRX
P&L Motorsports Catted Turboback
Cobb SF Intake
P&L Motorsports Catless Uppipe
Cobb OTS Stage 2 91oct Tune via Accessport V3
epeder1102 is offline   Reply With Quote
Old 09-07-2019, 12:12 PM   #2
wrxlaunch
Member#: 181298
2015 FUQ21BottiTuned
Full Bolt on Flex Fuel
When at idle... wait 30 seconds, what is your A/F and what is your A/F learning 1 ?
wrxlaunch is offline   Reply With Quote
Old 09-07-2019, 01:10 PM   #3
subaru_gc8
Member#: 29292
2004 WRX wagon
if it were that lean it would buck like a horse..if it running fine, then you would be okay
Old 09-08-2019, 03:29 AM   #4
epeder1102
Member#: 436463
2004 WRX
When I haven't been driving for long idle stays at 14.7 to 15.0 with a 4.69ish AF learning 1. AF learning 1 varies from 2 to 8ish day to day it seems. However under high boost AF learning 1 drops to zero every time.
Old 09-10-2019, 01:01 PM   #5
jzapatajr
Member#: 506074
Maybe the issue is with the sensor? Bad sensor?
jzapatajr is offline   Reply With Quote
Old 09-10-2019, 01:12 PM   #6
86Dreams
Member#: 385256
V7 S204
'19 Giulia Q4
so the aem wideband is which model? where is the sensor installed?
Which gauge is it that
? Is it the one in the picture? and if so is it the big number or little number?
86Dreams is offline   Reply With Quote
Old 09-14-2019, 09:16 PM   #7
epeder1102
Member#: 436463
2004 WRX
So today I drove a tank of gas purely on the highway and I calculated the gas milage for that tank to be 29mpg!! Not sure if I am correct, but that seems way too high compared to my old stock bugeye that got a max of 24mpg. This supports the gauge that the car is running extremely lean, as it was maxed out the entire trip...but the car is still running flawlessly...
Originally Posted by jzapatajr View Post
Maybe the issue is with the sensor? *Bad sensor?
I am in contact with AEM, so far all they said was it could be a bad sensor or a bad gauge and asked for a bunch of my info...not very helpful yet.
Which gauge is it that ? Is it the one in the picture? and if so is it the big number or little number?
Its a AEM UEGO 30-4110 with the sensor installed on the top side of my downpipe about 8 inches from the turbo. The gauge that gets maxed out is the AEM gauge, I just included a picture of my accessport to show that nothing else seems out of whack when the AEM gauge is reading super lean. The AFR reading on the accessport from the stock upstream O2 sensor is always good, but I know that sensor is not always very accurate since it is a narrow band sensor.
I could also take some cruising logs with my AP, just not sure if that would be helpful or not.
Wouldn't the car throw a CEL if I was really running that lean? I do have a CEL now but it is a P0442 for a small evap leak which seems unrelated.
Old 09-15-2019, 06:18 AM   #8
subaru_gc8
Member#: 29292
2004 WRX wagon
did you calibrate it correctly?
the stock sensor is fine. if they stock sensor is crap you car wouldn't run dont write if off , that is where your car is taking all of its readings from. I mean think about it when you get tuned, the tuners dont use the wide bands, they use the readings off the oem o2
Old 09-15-2019, 11:27 AM   #9
epeder1102
Member#: 436463
2004 WRX
The AEM UEGO supposedly never needs calibration. Also, I could be wrong but I am pretty sure a lot of tuners won't even touch your car without a wideband. I will be running some injector cleaner through the system and cleaning the MAF sensor in the next few days to see if that makes any difference. Hopefully AEM will get back to me with their opinion soon.
Old 09-15-2019, 06:07 PM   #10
subaru_gc8
Member#: 29292
2004 WRX wagon
yeah I dont know about that, I know aem says it doesnt but you know after a while everything degrades. SO unless you are changing the O2 every year I wouldnt trust it but thats me. me honestly, I think you should not use it.. I mean what are you going to do if you go lean... its another dummy gauge that people say you need but really doesnt do anything for your car unless you are tuning the car yourself and can log it
Old 09-15-2019, 07:35 PM   #11
epeder1102
Member#: 436463
2004 WRX
The sensor is literally 3 weeks old.. so it should be good. I installed the gauge because I am hoping to eventually learn and understand datalogs and things so I can step away from the Cobb OTS tunes and try RomRaider for myself.
Old 09-20-2019, 12:29 PM   #12
subaru_gc8
Member#: 29292
2004 WRX wagon
I hear ya, but this is the thing, if you were running that lean the car will buck like crazy. mostly anything over like a 16:1 will give that feeling, so that is why im saying that you shouldn't rely on that gauge cause its wrong, plus I have a hard time believing that a sensor that doenst need to be calibrated is going to just work. I have an inovate and it tells me for accuracy, I need to calibrate every 6 months. its the same reason why all o2 sensor look alike but you cant put one that is made for one car into another. just FYI if you want to learn to tune, the best way is to jump into it. get familiar with setting from different roms and try new things. cobb will teach you nothing Take classes and will have a better learning curve that way.
Old 09-21-2019, 07:44 PM   #13
epeder1102
Member#: 436463
2004 WRX
So AEM sent me a new gauge and sensor no questions asked and, funny thing is, the new gauge and sensor don't work together...it gets pinned to max lean. But, my original sensor and the new gauge they sent work perfectly together. No extreme lean conditions. Weird, but glad AEM's customer service was willing to help out.
And regarding learning to tune, I will be jumping into it just as soon as I pay $170 for a Tactrix cable XD I only have an AccessPort and Cobb OTS tunes because the previous owner bought it.
You mentioned taking classes...what classes? So far I've just been absorbing info from RomRaider forums.
Thanks for all the input on my problem, seems to be figured out and I guess my 30mpg highway is normal, which I am not complaining about.
Old 09-23-2019, 12:58 AM   #14
subaru_gc8
Member#: 29292
2004 WRX wagon
So for classes. there are different places you can take as a JC or a tech school. I have a buddy that said if you call I think its dynapak they offer classes on their dynos and how to tune with them. I do also have another friend that leaned through haltech. SO yeah you just ahve to do some searching and find what works for you
Old 09-23-2019, 03:43 AM   #15
reshufflesleep
Member#: 506314
Have you done calibration correctly?
reshufflesleep is offline   Reply With Quote
