Welcome to the North American Subaru Impreza Owners Club Tuesday October 22, 2019
Old 01-26-2011, 06:00 PM   #1
txl146
Member#: 32459
02 WRX VF34 (SOLD)
Junior Tuned 301whp
Default Samco Ancillary hoses - install guide!
Picture of Samco 9 pcs Ancillary hoses. You will need to remove TMIC and intake top cover in order to install all hoses. Hose #6 requires removal of coolant tank.
Hose #3 (passenger side crank case) ---> you will need to remove intake top cover in order to install one.
Hose # 5 (connects to nipple off of turbo inlet)
Hose #6 (coolant tank bottom hose) --> requires removal of coolant tank.
Hose #7 (driver side crank case) --> you will need to remove TMIC in order to install one.
Old 01-26-2011, 06:29 PM   #2
txl146
Member#: 32459
02 WRX VF34 (SOLD)
Junior Tuned 301whp
2 hoses not used on USDM - anyone found any good use for them?
Old 01-26-2011, 06:55 PM   #3
Dragon Wagon
Member#: 101095
1997 leggy gt
Reo Red
the longer of the two hoses is for your master cylinder for brakes the smaller hose goes under your turbo coolant reservoir hope this helps
Dragon Wagon is offline   Reply With Quote
Old 01-26-2011, 09:44 PM   #4
Wileycyote
Member#: 268173
2003 WRX Wagon
Thanks for the post. I did this install over xmas and had one long hose left. I now know what its for.
You guys put any additional clamps any of the hoses that you replaced?
Wileycyote is offline   Reply With Quote
Old 01-27-2011, 05:56 AM   #5
Dragon Wagon
Member#: 101095
1997 leggy gt
Reo Red
I used the stock hose clamps
Old 01-27-2011, 09:46 AM   #6
quazimoto
Member#: 70395
I don't think its for the brake booster. Our brake booster line has a one way valve in it. Without it the booster will not work properly.
quazimoto is offline   Reply With Quote
Old 01-27-2011, 01:22 PM   #7
txl146
Member#: 32459
02 WRX VF34 (SOLD)
Junior Tuned 301whp
There is a label attached to a long hose to specifically use a valve.
Old 01-27-2011, 02:12 PM   #8
oguitar
Member#: 206720
2002 WRX Wagon
OP thanks for the picture. It cleared up a lot of my questions.
oguitar is offline   Reply With Quote
Old 01-27-2011, 03:32 PM   #9
Wileycyote
Member#: 268173
2003 WRX Wagon
Thanks for the info. I was also wondering about the lines that don't have stock clamps.
Old 01-27-2011, 04:47 PM   #10
txl146
Member#: 32459
02 WRX VF34 (SOLD)
Junior Tuned 301whp
Guys, post picture of engine bay with these hoses installed.
Old 01-27-2011, 08:47 PM   #11
txl146
Member#: 32459
02 WRX VF34 (SOLD)
Junior Tuned 301whp
Updated with more pictures and corrected the first picture based on input from you guys!
Hose #4 is for sale as I have a spare one. PM me if you want it for $12 shipped.
Old 05-14-2011, 01:13 PM   #12
resonic
Member#: 282728
2001 Bugeye
07V Green
Hi, i got a RHD STI over here in europe and i would like to use also the 8th and 9th pieces of the kit. Does anyone has an idea where those hoses belong?
resonic is offline   Reply With Quote
Old 06-10-2011, 12:58 AM   #13
scotto4k
Member#: 208515
2003 WRX
v7 EJ207 20g'd
Ok so I just put 7 of the 9 hoses on my 03 the other day and don't really know why nobody has tried the brake booster hose. It will fit... I think... i held it up in place and it could I assume however with a slightly different routing. The guys in the UK have and I understand they're different being RHD and all but if I cut out the one way valve and shoved it the hell in the samco one I assume it will work...? My car is my DD so I don't really wanna be the test dummy...
Lastly my "coolant under tank hose" did not fit at all the ID of the hose was wayyy small. So I have that one sitting around as well.
scotto4k is offline   Reply With Quote
Old 06-16-2013, 02:53 PM   #14
smidge112
Member#: 289681
2005 wrx wagon
I just installed hoses on my 2002 wrx. And this shorter hose you speak of does not fit on the bottom of the coolant reservoir unfortunately.
smidge112 is offline   Reply With Quote
Old 02-08-2014, 01:24 PM   #15
soobie799
Member#: 272961
03 wrx
black
Has anyone had problems installing the coolant hose under the resivouir. I'm having trouble cause the I.D. Of the hose is way to small to fit over the nipple.
Edit- nvm I missed the last three previous posts lol
soobie799 is offline   Reply With Quote
Old 02-21-2014, 01:43 PM   #16
sxotty
Member#: 95600
2003 WRX wagon
Ok so getting off the resevoir coolant hose I broke the plastic hose with a red stripe above it. Any idea what this hose does? It goes form the air intake somewhere. Maybe some sort of vacuum test? Anyway I wondered if I could just get any hose to replace it or need something hard plastic like it seemed to be as well as what the heck it is. You can see it in picture five next to coolant tank (mine had a stripe on the side toward coolant tank).
sxotty is offline   Reply With Quote
Old 02-21-2014, 02:25 PM   #17
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
its part of the head breather system on either side of the oem hard tubes that bolt on the tmic
fastnoypi is offline   Reply With Quote
Old 02-21-2014, 03:20 PM   #18
sxotty
Member#: 95600
2003 WRX wagon
Thanks, I can't find it in the oem catalog so I will just put some hose over the cracked pieces and hope for the best . Anyone know a part number for the under coolant tank hose? I stupidly got this kit b'c I had a leak somewhere. Yeah that was where the leak was and the new hose doesn't fit of course. I tried to buy some hose at the autoparts store, it was cheap, but kinked. I am not sure if it will be a disaster or not with the kinked hose, but it sure seems likely to me.
https://www.partswebsite.com/stores/...s7/7591040.gif
Of course that doesn't list the silly hose that I need for some reason. There was a bunch of corrosion on the metal part the hose connects to on the engine it is a bummer.
Old 03-02-2014, 01:58 AM   #19
Gatdula420
Member#: 300458
2002 Impreza WRX
Hate to bump an old thread, but I had a quick question. Do you need to drain and refill the coolant? I watched the Mishimoto install video and they said to drain and refill; is it really necessary for installation of the hose kit?
Austin
Gatdula420 is offline   Reply With Quote
Old 03-04-2014, 02:38 PM   #20
Dentt42
Member#: 180570
2002 WRX Wagon
WR Blue
Austin
You would only need to drain it enough that it runs out of the hoses you want to change. I've only completely drained it when changing the radiator.
Dentt42 is offline   Reply With Quote
Old 03-04-2014, 02:56 PM   #21
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Austin
just pull off your lower hose and drain in a clean bucket. Refill/burp.
Its the quickest way.
Otherwise you can try clamping with radiatorhose pinch-off pliers to minimize draining.
Old 03-04-2014, 03:22 PM   #22
Gatdula420
Member#: 300458
2002 Impreza WRX
Thanks for the comments guys.
If I were to drain and refill with the same fluid, would I need to add new coolant additive?
Austin
Old 03-04-2014, 03:35 PM   #23
Dentt42
Member#: 180570
2002 WRX Wagon
WR Blue
Austin
If you don't have any real spills, just top it off (if it even needs it) with some distilled water. A gallon is less than a buck at the grocery store.
Old 09-12-2019, 11:34 PM   #24
TRinityMtrSprts
Member#: 43720
2002 mbp WRX
97 Ford Ranger on Bags
blast from the past, but any chance on getting these photo's back up pretty pleaaaaase!!!!
TRinityMtrSprts is offline   Reply With Quote
what is the little wire connected to the battery? flatbox Car Audio, Video & Security 3 05-29-2006 06:41 PM
WTT: Black Samco Hoses for Blue ones (MAF hose, Throttle Body hose, BOV recirc hose) TROLL Private 'For Sale' Classifieds 5 03-11-2006 02:23 PM
what hose is connected to the driver side GBOD question.. ONT-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-16-2005 08:23 AM
HELP! broke my turbo inlet hose off at the recirc. hose connection metbluWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 10-29-2004 11:27 PM
Here is what I REALLLLLY want to do! HiFiWRX North West Impreza Club Forum -- NWIC 13 05-15-2003 02:33 AM
