Welcome to the North American Subaru Impreza Owners Club Wednesday February 21, 2018
Old 09-06-2009, 08:52 AM   #1
Harnicka
Member#: 189686
2004 Impreza 2.5RST
Java Black Pearl
Default I need some assistance, need help with my build
  • 2.5L STi heads ( wrx camgears) w/ WRX short block
  • Stock WRX intake manifold w/ deleted TGV
  • Walbro Fuel pump
  • SARD Fuel Pressure Regulator
  • TXS Fuel Rails
  • Vibrant manifold
  • Stock td04 turbo w/ ported inlet and wastegate
  • STi Catback Exhaust
  • Aftermarket Top Mount Intercooler
  • Cobb SFI Intake
This is what i currently have on my 2002 wrx, for some reason it feels sluggish, i recently bought this car before it had the sti shortblock on it but bearing blew and the wrx shortblock was put back on. I am wondering maybe the map that is loaded now is more for wrx heads rather then sti heads or maybe since the STI heads have AVCS im loosing power or i just have to get it returned..
Harnicka is offline   Reply With Quote
Old 09-06-2009, 11:07 AM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
sti shortblock is 2.5
wrx shortblock is 2.0
loss of displacement..
Old 09-06-2009, 11:56 AM   #3
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
depending on which wrx shortblock he got but yeah if you got the ej205 shortblock then you just lost .5 displacement. FAIL
ownnij is offline   Reply With Quote
Old 09-06-2009, 03:40 PM   #4
Harnicka
Member#: 189686
2004 Impreza 2.5RST
Java Black Pearl
so what would be the best fix i have the wrx heads so just put them back on?
Old 09-07-2009, 03:31 AM   #5
SLOWSUBY
Member#: 169417
alls you did was lower the compression. so its going to struggle until it hits boost
SLOWSUBY is offline   Reply With Quote
Old 09-07-2009, 09:17 PM   #6
Harnicka
Member#: 189686
2004 Impreza 2.5RST
Java Black Pearl
so since the compression is lower i should retune it?
Old 09-07-2009, 11:32 PM   #7
SLOWSUBY
Member#: 169417
it wouldnt hurt.
Old 09-08-2009, 11:32 AM   #8
ryan_west06
Member#: 139045
05 STI SnowmanTune
you cant be serious man!
ryan_west06 is offline   Reply With Quote
Old 09-08-2009, 11:42 AM   #9
tolnep
Member#: 18602
2005 Moller Skycar
glow in dark purple
an upside down hybrid.. first ever as far as i've seen...
now lowered compression means you can run more boost. long long ago when i started looking at custom turbo apps for an old datsun, i read where some folks were doing 6:1 compression ratio and running truly humungous boost..
course it comes in real late.. but that reduced compression (at least what you would hear in the old days) means you can get mister turbo to jam in more air and fuel which is what makes power in the end...
tolnep is offline   Reply With Quote
Old 09-08-2009, 02:58 PM   #10
ryan_west06
Member#: 139045
05 STI SnowmanTune
wonder what would happen if he went with a 2.0 wrx block on 2.5 heads on wrx exhaust mani lol
help with my build Wrx.CHRIS.Wrx Built Motor Discussion 1 11-04-2009 12:11 AM
Need some help with my build 07 STI NvisionSTI Built Motor Discussion 6 09-18-2008 01:26 AM
need some help on my build. injector/em bloopsta26 Built Motor Discussion 4 06-03-2008 11:05 AM
I need a lot of help with my system. cppchrisdh Car Audio, Video & Security 3 02-21-2007 09:42 AM
need some snow chain help with 18s skip4343 Brakes, Steering & Suspension 0 11-08-2002 06:08 PM
