01-30-2010, 11:18 PM | #276 |
Member#: 120152
Nice solution for the 07 owners you found there!
01-31-2010, 09:34 AM | #277 |
Member#: 17704
Vehicle:2009 STi Silver |
Wow. You really went at that thing eh? I had this thought before, but never got around to it.
I was thinking it might be easier to buy a new barometric pressure sensor and wire it in place of the valve. |
01-31-2010, 10:28 AM | #278 | |
Member#: 232666
01-31-2010, 10:29 AM | #279 |
Member#: 232666
i don't know if it's really possible , you will need to change all the valve. and they are expensives
02-01-2010, 04:52 PM | #280 |
Member#: 232666
Hello everybody i would like to delete all the air pump system but i have TWO valves on my sti, so i just need to know all the codes cells to delete, to gave them to a tuner
could you please send me the list of all the cell to delete? after this conversion? many thanks |
02-02-2010, 01:48 AM | #281 |
Member#: 179846
NWIC
Vehicle:07 STi Limited EFR 8474 TS EWG |
read the thread
02-07-2010, 11:49 AM | #282 |
Member#: 103232
Vehicle:GTX 3071R'd 11WRX PPG,4.44,LSD,E85,6spdx3 |
Im going to delete the pump on a friends car. Dealership has replaced the pump a few times now.
02-07-2010, 12:01 PM | #283 |
Member#: 17704
I'm pretty sure we can wire in a 108kpa Baro sensor in place of the valve on the driver's side. Anyone have the pinout for the valve?
02-27-2010, 11:19 PM | #284 |
Member#: 123843
NESIC
Vehicle:2016 STI LTD CWP Let LED's light your way! |
I installed the block-off plates this weekend myself. Without this thread I would have had more 'fun' doing so.
The driver's side secondary valve had water in it (found this out after the valve had sat on the bench overnight and warmed up a bit). I had no codes but for the past few months since winter set in, and with increasing frequency, I was getting an exhaust rumble feedback into the air-feed system. Because of the water the valve would open but not close after the air-pump cycled for the 30 or so seconds it was supposed to after start-up. It would after a few more minutes of either letting the car warm up further or driving it, eventually close. As with others I did essentially the same thing. The air-pump is easily disconnected and removed. The driver's side secondary valve (once TMIC is removed) and air-feed tube are both relatively easy to remove. I obtained a set of block-off plates from Cosworth USA and a set of OEM gaskets from the dealer. The passenger's side secondary valve and air-feed tube are not easy to work on. The valve is located next to the driver's side valve and is tucked half-way under the intake manifold. The air-feed tube is also snaked along the top of the engine block under hoses and wires. To access the bolts to the air-feed tube on the passenger's side head you do have to remove the downpipe and the uppipe. Luckily the uppipe can be removed in its entirety without having to remove the header collector or jacking up the engine. I also highly recommend getting new OEM gaskets when reinstalling the exhaust pipes. Also use anti-seize on the bolts as well. Instead of trying to get the entire air-feed tube out, which would have been more work, I left it in place. I used a hack-saw blade that I cut in half to cut the head off the air-feed tube. As previously stated by others you have to watch that you do not cut into the power-steering line or the turbo oil-feed line. After the car was back together, it started and ran without any problems what-so-ever. I of course had a CEL and the cruise-control indicator lamp flashing. I took the car up to my tuner and he simply took my Accessport and downloaded my original map he previously created from my original tune. He created a new map for me that omits the air-feed system. No CEL and the car runs like a champ. Honestly, I did not know if either secondary valve was actually failing. I took an educated guess using this post in part as a guide. I was correct in doing so. No more exhaust feed-back noise and overall the car is a bit more quiet. My feeling is that the valve never fully closed. Regardless, it's out. When I eventually get around to servicing the intake manifold and TGV's, that's when I will remove the passenger's side secondary valve and air-feed tube. Plan on spending a good part of the day doing this install. |
03-01-2010, 07:28 PM | #285 | |
Member#: 192526
Vehicle:2008 WRX FMIC/VF48 Red/Steel Grey |
In fact there will be more power loss using the air pump because the closed loop system is not 100% efficient. . . Engine drives the alternator which then drives the air pump. . . There's 2 couplings in that loop that are not 100% efficient: 1) engine coupled to the alternator 2) alternator coupled to the air pump I'm doing surgery on my car soon when I drop in my newest turbo and I remember how much clutter there is under the IM from my first turbo swap and I'm estimating the issues with removing the air valve on the passenger side next to the turbo inlet. But today I found that Subie put the sensor in that very valve I want to take off. Aye carumba, and damn you to hell Subaru!! |
03-08-2010, 09:18 PM | #286 |
Member#: 88501
BAIC
Vehicle:2011 WRX Hatch Dark Grey |
Do the block off plates really make a good seal?
I would think you need some kind of gasket for them. Plus, if I understand correctly, the valve for this system is part of what gets removed, which means exhaust wants to escape from these "blocked off" holes. That's a leak before a sensor. Also... assumings the holes do get a tight seal, why would the car need a retune if this is the only mod? Or does the tune remove the air pump factor (which is usually not on) |
03-08-2010, 11:21 PM | #287 | |
Member#: 206590
Vehicle:07 Extee |
03-23-2010, 01:28 PM | #288 |
Member#: 152176
Vehicle:2001 2xImpreza 2.5RS BRP/SRP |
I'll rephrase my post.
On 07 STI I removed the entire air pump system. I will get a blocking plate and the car will be tuned opensource or with cobb op. will I be having issuies? |
03-30-2010, 10:27 AM | #289 | |
Member#: 49979
Vehicle:11 need a 2nd STI 08 black TA STI |
Nice work by Bariga on cutting out the sensor. Looks like I'll be doing that to my '08 STI. Frank |
03-30-2010, 10:40 AM | #290 | |
Member#: 206590
Vehicle:07 Extee |
03-31-2010, 09:50 AM | #291 | |
Member#: 186356
Vehicle:2006 WRX-pte6262 CTS-V,& 05 RS |
i tried to pry it off the housing but no luck. |
04-10-2010, 05:04 PM | #292 |
Member#: 179846
NWIC
take a sharp knife and cut it off the metal housing.
04-29-2010, 01:18 PM | #293 |
Member#: 189606
SCIC
Vehicle:E46 M3 Ti Silver |
Think I'll be doing this to my 09 STI. but where is the air pump, I haven't take a great look, but I know it's not in the place of the 07 and priors.
04-29-2010, 01:19 PM | #294 | |
Member#: 17704
Take pics if you do it on your 09. I'm considering doing it on mine as well. |
04-29-2010, 04:33 PM | #295 | |
Member#: 189606
SCIC
But... If I happen to have alone time on my short vacation coming up, I'll probably do it.. lol. Then just go to crawford and have them fix my map to cut out those CELs. |
05-01-2010, 01:52 AM | #296 |
Member#: 233813
E. Canada
Vehicle:2006 Forester XT Platinum Silver |
05-02-2010, 07:37 PM | #297 |
Member#: 18797
VIC
Vehicle:MY06 WRX Wagon Black |
Stupid question:
The guy who is about to do my clutch is suggesting I remove this air pump etc. now ( while working on clutch) because "if" it fails it will be hugely expensive to work on it then. The Air pump works fine. Not sure about the failure rate of these things... Would it work just as well to turn off all the poteintal cells and leave the whole works in place? Thanks |
05-02-2010, 07:55 PM | #298 | |
Member#: 206590
Vehicle:07 Extee |
Relationship to clutch job? Low |
05-03-2010, 10:53 AM | #299 |
Member#: 18797
VIC
Okay, so if the air pump dies. Can the cells just be canceled and call it a day, without having to remove everything (pump, solenoids...)?
The relation to the clutch: He says he is down there anyway so this would be a good time to remove the airpump etc. Thanks |
05-03-2010, 12:34 PM | #300 |
Member#: 206590
Vehicle:07 Extee |
On your car, there are three components that can go bad - the pump and two valves. If the pump craps out or a valve is stuck closed - no problem, disable that CEL and keep on truckin.
However, if a valves sticks open or leaks, you're SOL. If you do have him remove the system, make sure he leaves the valve with the pressure sensor plugged in. I removed all the piping to the valve, but left it in place. DO NOT have him just remove the pump. |
Air pump removal + fail? 07 WRX. | Badmunky | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 14 | 03-10-2018 03:40 AM |
WTB 06-07 Wrx AIR PUMP | StageWrx | Private 'Wanted' Classifieds | 1 | 03-30-2009 10:44 PM |
is it safe if i remove the restrictor on my wrx | prlblkwrx02 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 44 | 03-24-2007 07:21 PM |
Is it safe to switch to summer tires yet? It is March after all... | Samirr76 | Tri-State Area Forum | 38 | 03-06-2003 09:25 PM |
