08-27-2017, 05:17 AM | #1 |
Member#: 373537
Vehicle:2008 Impreza STi EDM |
MerpMod(speed density,flex fuel,map switching,LC,FFS&more) porting&develop. continues
Continuing the work of Merp and all others patches for 32 bit roms are available here (speed density, flex fuel, map switching on the fly, cel flash on knock, LC, FFS ....)
http://romraider.com/forum/viewtopic.php?f=37&t=14020
08-27-2017, 04:09 PM | #2 | |
Member#: 473558
08-27-2017, 04:24 PM | #3 |
Member#: 373537
Most of the roms are at the beggining of the thread plus a few others already available plus what I'm currently working on ... but if you're interested in some particular car/cal id just write it there and if not available now ... it will be
08-27-2017, 07:52 PM | #4 |
Member#: 473558
Thanks bro I will search for the A2ZJ710J
08-31-2017, 04:27 PM | #5 |
Member#: 394646
NWIC
Vehicle:2003 WRX Flex Fuel Pv=nRT |
Super excited for where this is going, despite it not applying to me. 16 bit here...
09-03-2017, 04:57 PM | #6 |
Member#: 373537
A2ZJ710J version testers wanted
06-11-2022, 06:44 PM | #7 |
Member#: 220816
Vehicle:2018 Exotruck |
06-13-2022, 10:19 AM | #8 |
Member#: 515308
Cause 2011 wrx is on n bad need of flex
08-04-2022, 05:10 PM | #9 |
Member#: 515308
After following your 08+ instructions I verified 0001000 to 0002000 matched except for line 000ff8. It was only off by 2 bits. So I think I have it figured, can’t test it till my new tuning laptop comes in, tired of fixing the old one.
08-04-2022, 05:14 PM | #10 |
Member#: 515308
I’m very excited, after a year with a merpmodded flex 05 forester xt, no way I could go stock rom on this 11 wrx. Gotta have that E85 turbo crack
08-27-2023, 06:53 PM | #11 |
Member#: 535323
Hey, im sorry for asking, but can someone explain to me, which one would work with the 03-06 JDM Legacy GT (A2WD001B)?
Best regards wakeN |
01-07-2024, 01:19 PM | #12 |
Member#: 515308
A deep dive here and mainly on romraider. I doubt it has been ported. You might get lucky, or find o e close enough to work, or maybe even a bounty to get someone to port the modifications to that rom, you also want one of them to give you a completely worked out rom too, there are 100 extra settings that most of the roms can’t see.
01-07-2024, 02:18 PM | #13 |
Member#: 220816
I'm using one of these patches I. The green truck. It's working but not great. Could benefit from at least a separate cranking fuel table
01-07-2024, 02:25 PM | #14 |
Member#: 515308
Yeah, when real cold in Alabama, so kinda cold, I have to restart a 100 times. But in cold u could get away with less e content. That would help with starts.
06-10-2024, 03:00 PM | #15 |
Member#: 537616
ECU Swap?
I would like to try out some of the MerpMod ECU modifications, but my ECU isn't supported because it only has 512kb of memory.
So I'm wondering if I could swap out my 2004 Forester XT ECU which only has 512kb of memory for a 2005 Forester XT ECU since those have 1024kb of memory... Has anyone done anything like this in order to use MerpMod? |
06-10-2024, 09:15 PM | #16 | |
Member#: 191967
Vehicle:2005 EVO VIII open source tuning subaru |
09-29-2024, 12:40 PM | #17 |
Member#: 539218
I'm trying to load my rom with merpmod features, but I'm getting some errors loading on Ecuflash. All merpmod features are grey out and when I try to open the table I get an error msg saying "map descriptions is invalid or incomplete. I saved all the merpmod defs as instructed from RR and GitHub. Can somebody tell me what I'm doing wrong or missing. Loading pictures for reference. https://imgur.com/O3uiDGl
https://imgur.com/nnIRcFj https://imgur.com/Z5YFva2 https://imgur.com/dxnDny3 |
11-29-2024, 10:09 PM | #18 |
Member#: 539392
Also having the same issues
Followed everything on RomRaider and the forums. My Merpmod tables are there but greyed out and says they’re incomplete but I have everything like it should be.
