02-09-2001, 10:49 AM | #1 |
Member#: 1376
check engine light and missing gas cap
My wife forgot to replace my gas cap when she filled up my RS; the check engine light therefore came on a couple days later. I finally got a replacement cap which I installked yesterday, but the light is still on. My question- how long till it goes out or do I need to reset my ECU? Why exactly does the light come on- does there need to be some kind of gas (vapor) pressure in the tank normally?
Thanks in advance! leo
02-09-2001, 10:55 AM | #2 |
Member#: 493
Vehicle:1999 2.5 RS Rally Blue Pearl |
You need to reset your ECU. Had this happen to me once before when I didn't tighten down the gas cap enough. Once I reset the ECU and tightened down the gas cap the Check engine light never came back.
02-09-2001, 10:57 AM | #3 |
Member#: 114
Vehicle:'03 Evo, Rice White '01 Erion CBR 929 |
I don't know how long it takes for the light to go out. If it bothers you, disconnect the negative lead on the battery for 20-30 minutes and reconnect.
The MIL is triggered because of pressure, yes. It thinks there is a problem with the evaporative purge canister. Since the RS doesn't have a secure fuel door this would be a good time to get a locking cap... I got mine for $5 at Wal-Mart. |
02-09-2001, 11:05 AM | #4 |
Member#: 3096
Vehicle:2001 2.5 RS Silverthorn |
Once you reset the CE light and later on it comes on again have it checked out. I've had my RS since Nov and had to replace 3 O2 sensors already.
Check Engine Light and Cruise Light Blinking | finger123 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 25 | 02-17-2014 07:09 AM |
gas smell, check engine light, and uncooperative service center! | db97 | Warranty Issues & SOA Problems | 14 | 02-12-2006 09:24 PM |
high speed run in sti..then check engine light and engine sputters then runs fine? | mpower22 | Engine Management & Tuning | 7 | 02-07-2006 06:57 PM |
help check engine light and abs light??? | greentre | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 10-15-2002 05:11 AM |
