Brakes & Suspension Forum sponsored by The Tire Rack |
08-30-2002, 08:36 AM | #1 |
Member#: 23078
Vehicle:2003 WRX BLACK |
Tell me about your Dream Suspension Setup!!
give me some ideas, never mind budget, what would you get to overhaul/upgrade the handling of WRX?
I would like to spend around $2000 on coilover it self tho... i was thinking the entire Cusco F/R strut braces, lower arm bar, f/r swaybars,camber plates, with STI lateral link and trailing arms.....
08-30-2002, 09:44 AM | #2 |
Member#: 6713
TXIC
Vehicle:2007 Prius brown |
my dream setup would be to remove 200lbs from the front of the car
wide race tires adjustable shocks adjustable ride height adjustable camber and caster and I'll prolly be achieving all of these things, except the 500lbs of weight removal |
08-30-2002, 09:44 AM | #3 |
Member#: 2184
Vehicle:2005 Legacy GT wagon Platinum Silver Metallic |
I already have it. STi struts/springs/trailing/swaybar/lateral links, control arm and swaybar bushings, and Cusco front lower brace.
One part of me does wonder about adding DMS 50s to that equation, but not enough to do it...(yet). Kevin |
08-30-2002, 11:05 AM | #4 | |
Member#: 10821
NESIC
Vehicle:2008 WRB STi |
Are your STi struts adjustable? If not, have you tried a wrx with them? thanks |
08-30-2002, 11:18 AM | #5 |
Member#: 15533
Vehicle:2010 Dodge Ram Hemi boat, dirt bikes, bobcat |
My dream setup is to have a monkey at each wheel in place of the struts. I would also like to have a gorilla in the trunk to assist with weight distrobution when handling in corners.
08-30-2002, 11:38 AM | #6 |
Member#: 15618
International
Yummy
Car stripped of that useless electrical stuff, soundproofing and HVAC.
Cage for stiffness and safety Rebushed Custom road racing suspension. Front and rear Kaaz diffs. Modify the steering. Oh yeah, and a decent driver. |
08-30-2002, 12:42 PM | #7 | |
Member#: 23078
Re: Yummy
08-30-2002, 02:05 PM | #8 |
Member#: 610
VIC
Vehicle:2003 Lexus IS300 Graphite Gray Pearl |
I'm happy with assorted Cusco bars, and an Ohlins coilover setup.
08-30-2002, 05:46 PM | #9 |
Member#: 19576
Vehicle:2002 Subaru WRX Platinum Silver |
I'd like Cusco Co's, Braces and Swaybars. Whiteline Reinforced Swaybar mounting brackets and an Anti-lift kit. MRT rear links and Aluminum Fr. Arms.
08-30-2002, 05:57 PM | #10 | |
Member#: 17684
Vehicle:1989 pathfinder rusted red |
08-30-2002, 06:26 PM | #11 |
GC84Ever
Super Moderator Member#: 301
NWIC
Vehicle:1970 FF-1 & '70 Van 02 WRX/01 RS |
08-30-2002, 06:28 PM | #12 | |
Member#: 2184
Kevin |
08-30-2002, 07:40 PM | #13 |
Member#: 15618
International
steering solutions
veedubaholic - some info here
forums.i-club.com/forums/showthread.php?s=&threadid=235574 |
08-31-2002, 03:35 AM | #14 |
Member#: 2272
BAIC
Vehicle:2019 Macan 4cyl 1993 Impreza FWD WRX swap |
For my L, I have a "purchased off the shelf" set up in mind:
DMS 50mm Race suspension Adjustable camber/toe/etc. plates Those 16"x7.5" light weight wheels (like 10lbs) i saw once with some racing slicks Group N bushings all around upgraded Engine/tranny/pitchrod/diff mounts Cusco rear xmember (have already) and front xmember braces Aluminum control arms (Possibly combined with whiteline ALK kit) Cusco from strut brace and rear strut brace with V-bar Cusco front/rear adjustable swaybars with those solid aluminum front endlinks (not the whitelines) and kartboy rear endlinks (have already) Whiteline reinforced swaybar mount MRT (does cusco have this as well?) adjustable front and rear control links and trailing arms Front and rear lightweight bumber beams (~70lbs) Remove all sound deadening material from the car (~100lbs) Remove non-essentials from car (airbags, stereo, carpets, panels, speakers, A/C, ABS, etc. ~50-100lbs) VERY lightweight seats (~40-60lbs?) I'd include ohlins and some of the really fancy stuff like maybe some custom wheels ala the conebasher, but I like to keep it to off-the-shelf items and DIY stuff only Did I miss anything? |
08-31-2002, 04:52 AM | #15 |
Member#: 8171
NWIC
Vehicle:2002 WRX WR Blue |
From everything I've read, I'd drive over to a dealer, meet gtguy there, and say "see everything in his car? Put it in mine too."
--jeff |
08-31-2002, 03:51 PM | #16 | |
Member#: 2184
Kostamojen, that's a SERIOUS setup you have in mind there. How close are you to fruition? Kevin |
08-31-2002, 10:04 PM | #17 | |
Member#: 2272
BAIC
OTters: Tell Me About Your CornHole. Your Cornhole... Tell Me About It. | Asinine | Off-Topic | 60 | 09-10-2008 01:23 PM |
Tell Me About Your Best Friend (Outside Your Family) | Subi Chicky | Off-Topic | 24 | 05-25-2004 01:39 PM |
tell me about your dreams. | Keith | Off-Topic | 44 | 03-29-2004 12:40 PM |
Tell me about your exhaust | Tim Sanderson | Mid West Subaru Owners Club Forum -- MWSOC | 20 | 08-03-2002 11:33 AM |
tell me about your coil over suspension | bluemax | Brakes, Steering & Suspension | 2 | 06-02-2001 09:37 AM |
