11-25-2008, 12:25 PM | #376 |
Member#: 71092
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
There's also no way around the fact that you're going to have to spend some money and buy some books. And then actually read them. Self-tuning is not quick, not easy, and not for someone who isn't willing to put several months of studying into it.
11-25-2008, 01:16 PM | #377 | |
Member#: 140444
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
http://www.romraider.com/RomRaider/Books |
11-26-2008, 10:06 PM | #378 |
Member#: 42964
Vehicle:08 STI, 03OBS, 99L |
Sorry if I've missed this- did try searching with no luck.
Do we need the Openport 2.0 with full adapter set or just the cable (Specifically 08 STI?)? I thought I read somewhere that 07 and below need an adapter but 08's and up do not. |
11-26-2008, 10:36 PM | #379 |
Member#: 103136
You only need the flash block with the 02-05 WRX, as far as USDM.
11-30-2008, 06:24 AM | #380 |
Member#: 191212
Vehicle:2007 FXT-5MT E85 20G TD06SL2 Kinugawa |
OP2.0 + Linux??
When will OP2.0 in Linux be supported? RomRaider Linux download only supports OP1.3
11-30-2008, 11:50 AM | #381 | |
Member#: 181328
International
Vehicle:2004 STI H4 Blue |
Protocols are the same of the OP.2. Of course PO.2 have a lot of benefits . But this cheap ones really works I bought one to try, becuase no body talks about it |
02-03-2009, 12:52 PM | #382 |
Member#: 200730
Vehicle:'08 E92 M3 '95 GC ZJ |
does anyone know what a good tuner will charge to do this for you? i have never dabled in this so williatry has given me enough insight that this isnt to be trial by fire. or there will be fire.
02-03-2009, 10:38 PM | #383 |
Member#: 133754
SCIC
Vehicle:1998 3.6RSTi All blue, all blue baby |
Anyone having problems with Romraider logging after updating the Openecu software to 1.41
02-03-2009, 10:39 PM | #384 |
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
multiple threads about that
The firmware update changed the interface to the OP2.0, they're still working on an update to RomRaider to work with it. Kascade (the developer) thinks he has a working version, it's currently being tested and if all goes well it should be released in a couple of days. |
02-04-2009, 03:23 PM | #385 |
Member#: 133754
SCIC
Yeah, I found out like 2 minutes after I posted that. Lol, thanks for the info though.
02-10-2009, 11:40 PM | #386 |
Member#: 132400
Vehicle:2006 WRX |
how do you install the drivers for the cable. they are installed on my computer but do i have to somehow put them on the cable? sorry for the newb question.
and now that i have downloaded the latest romraider 0.5.2b when i go to the logger it says "logger definition not configure" but i have the latest 0.3.4b definitions in there!? Last edited by kh15; 02-11-2009 at 12:10 AM. |
02-11-2009, 07:39 AM | #387 | |
Member#: 103136
If you are getting that message, you didn't install the logger defs correctly. You need to go to settings -> logger definition location in RomRaider's logger to specify where the logger.xml file is on your computer (make sure you unzip what you downloaded). |
02-20-2009, 10:03 PM | #388 |
Member#: 187675
Hi guys can someone explain please how does tactrix works I want to go stage 2 and I dont understand how do I do it I understand i gotta get cabels but then what?
02-21-2009, 01:56 AM | #389 | |
Member#: 51961
RMIC
To reprogram the ECU you need a computer program that can talk to the ECU and a cable to transfer the data. The tactrix cable is used to communicate between your computer and the car's ECU. ECUFlash is the program that coordinates the communication. That's all you need to read from and write to the car's ECU. The data is transferred in a single file called a ROM that contains every field the ECU uses to do anything. When you want to make a change, you use a program to edit the ROM, and then use ECUFlash to write it to the car's ECU. Both RomRaider and ECUFlash can be used to edit the ROM, most people use RomRaider because it's a bit more powerful, but both programs essentially do the same thing. |
Similar Threads | ||||
Tactrix OpenPort 2.0 cable | Caballero_STi | Engine/Power/Exhaust | 2 | 04-28-2009 11:58 AM |
WTB: (MD) Tactrix OpenPort 2.0 | eduSti | MAIC Private Classifieds | 3 | 03-31-2009 03:10 PM |
FS CT: Tactrix Openport 2.0 | Boosted WRX STi | Engine/Power/Exhaust | 10 | 03-19-2009 07:30 AM |
WTB: Tactrix Openport 2.0 Cable | Xissix | NWIC Private Classifieds | 2 | 11-04-2008 10:35 PM |
FS: Tactrix Openport 2.0 $160 shipped | scoobysti05 | Engine/Power/Exhaust | 7 | 10-20-2008 12:30 PM |
