05-29-2006, 02:54 AM | #1 |
Member#: 77777
static in speakers
hey guys, I was wondering if anyone else had problems with static in the speakers when the car is running? I installed a navi/dvd player in the car and now when I have the engine running there is a static noise, but when the engine is off the noise goes away. Any solutions?
05-29-2006, 03:31 AM | #2 |
Member#: 477
Vehicle:GC4 -> GGA -> GM6 Yeah, that's about right. |
Ground loop, electrical noise, etc., could be anything ... did you do the install yourself? You could try rerouting wires, better grounds, shielding, or a million other tricks...
05-29-2006, 03:50 AM | #3 |
Member#: 86822
VIC
Vehicle:2004 WRX PSM |
static or whinning? like accelerating noise?
most likely you need better grounds. make sure you sand the area down so it's BARE metal. OR your RCA cable might be too close to your power wire OR you need better RCA period. One of the three is likely the problem. I"d start with the grounds =) goodluck. If you can't get it, pm me and i'll see I can help ya further! cheers Justin |
05-29-2006, 04:02 AM | #4 |
Member#: 100256
VIC
Vehicle:2001 2.5 RS Blue |
if the volume on the speakers were played load majority of the time, it could be blown, or just eletrical
05-29-2006, 04:08 AM | #5 |
Member#: 86394
VIC
Vehicle:2000 RS Coupe Blue Ridge Pearl |
Lemme guess... does the whine of the noise increase as you rev the engine?
05-30-2006, 01:56 AM | #6 |
Member#: 77777
Ok the weird thing is that the noise decreases as I drive and only appears when I and between gears or in neutral. I will try to ground it better tomorrow and see.
Similar Threads | ||||
Would grounding mod cease static in AM reception? | dingo dave | Electrical & Lighting | 11 | 01-25-2011 06:28 PM |
speaker fuzz/static in 1K-2K range | HolyMahwah | Car Audio, Video & Security | 6 | 06-28-2006 12:16 PM |
Static in speakers | munchie | Car Audio, Video & Security | 0 | 12-07-2004 09:38 AM |
problems with static in sound | brokemypiston | Car Audio, Video & Security | 2 | 02-16-2004 01:14 AM |
