08-02-2006, 02:17 PM | #1 |
Member#: 88071
Vehicle:1985 Defender 90 |
car wont idle after 20g, 860cc's and pump
installed all of this on my 04 sti and it wont idle. i have to keep giving it gas for it to stay on. the idle will just fall and stall if i dont give it gas. car blows black smoke also. what should i do. i have to drive 1 hour to get a tune and it wont even run. anything i could of overlooked? priming problem?
again its td06 20g helix 860 walboro fuel pump using utec.
08-02-2006, 02:25 PM | #2 |
Member#: 101464
Your tuner should have emailed you a map to atleast get it there if he knew you were going to have to drive it.Put it on a trailer and tow it.Probably the lack of tune for your mods.
08-02-2006, 02:27 PM | #3 |
Member#: 88071
thanks ill email them now.
08-02-2006, 02:27 PM | #4 |
Member#: 114096
No, the car should still start and idle. It will just run rich as hell.
Are there any fuel leaks? Did you install the fuel pump properly? |
08-02-2006, 02:28 PM | #5 |
Member#: 88071
thats what i was thinking. sounds like a fuel pump problem. ill have to go recheck everything
could the utec be doing it. im runing the stage 2 sti on it now. should i go to stock mode? |
08-02-2006, 02:28 PM | #6 |
Member#: 99280
Vehicle:2006 WRX LTD OBP |
yea your running rich as hell is what the problem is. poor idle plus lots of black smoke = richness.
Your stock tune doesnt know what to do with all the extra fuel yet. |
08-02-2006, 02:37 PM | #7 |
Member#: 101464
What would the fuel pump have to do with it running rich as hell.YOU ARE NOT TUNED for what you have on the car now.If you read his post it starts it just idles rough.
08-02-2006, 02:39 PM | #8 |
Member#: 101464
My car did the same thing when I put my green on when I got my temp map it would idle a little better but not the greatest.
08-02-2006, 02:41 PM | #9 |
Member#: 88322
Vehicle:2009 BMW 135i |
My car would not idle with only a 50% increase in injector size (approx 550 to 815) with the factory ECU. It would just die immediately or not even catch at all while cranking.
08-02-2006, 02:41 PM | #10 |
Member#: 88071
no it wont idle. unless i keep the gas to the floor
08-02-2006, 02:41 PM | #11 |
Member#: 101464
If you cant get a temp map to limp it there take it as easy as possible so you don't damage your ride.
08-02-2006, 02:42 PM | #12 |
Member#: 88071
thanks ill see what i can do
08-02-2006, 02:42 PM | #13 |
Member#: 101464
Are you saying that with the pedal to the floor it only idles and doesn't rev up at all.
08-02-2006, 02:44 PM | #14 |
Member#: 88071
no if i play with the gas it will stay on and rev but as soon as i let off it, it will just die
08-02-2006, 02:45 PM | #15 |
Member#: 61586
W. Canada
Vehicle:2005 STi WI and all the goodies |
oops I missed that you don't have a map.
+1 for a temp map. The stock injectors are just about maxed, so the ECU is still telling your injectors to open right up, which is a bit much with your 860s. -J Last edited by Jitenshakun; 08-02-2006 at 03:12 PM. |
08-02-2006, 02:48 PM | #16 |
Member#: 101464
Try to get a temp map if you can Christian at Cobb emailed me mine to get my car to him but that's with an access port I don't know about utec.Trailer it if you have to.
08-02-2006, 03:08 PM | #17 |
Member#: 77810
Vehicle:2006 Evo IX SE Tarmac Black |
You need to have the correct injector scales....
08-02-2006, 03:11 PM | #18 |
Member#: 44351
Vehicle:2004 Mitsubishi Evo 701whp 9.91@146 |
Are you using the stock MAF housing?
Since you said you are using the UTEC, turn the open loop fuelling on and adjust the injector flow rate to 860's and the stock injector flow rate to 550. This should put you in the ballpark. FYI...there is new speed density firmware that came out for the UTEC yesterday. |
08-02-2006, 03:44 PM | #19 |
Member#: 83054
Vehicle:'11 SWP STI |
Check all your connections for your FP and injectors. Mine ran fine, idled a bit rough though (never stalled), with the stock ecu on PE 850s until I got it tuned.
08-02-2006, 05:48 PM | #20 |
Member#: 62395
Vehicle:2005 STI Black |
Do you have a boost gauge? If so what is your car's vacum level? I had a similar problem with a DSM, turned out I had a vacum leak, the throttle body was leaking. I hope that helps.
08-02-2006, 06:41 PM | #21 |
Member#: 36139
SCIC
Vehicle:'06 LGT CDan - BSM '85 Vette Beater w/NOS |
DO NOT Drive it running like that. You can gas wash the cylinders and have much bigger problems! You are way too rich like everyone is saying...too rich to just "drive thru". Do your car a favor and have to trailered to your tuner, or definitely get a temp map to cut the injector flow.
We had a similar problem after an injector install...fuel was running out of the tailpipe...way, way too rich. |
08-02-2006, 06:51 PM | #22 |
Member#: 108618
Vehicle:2010 10 RX350, 04 A4 12 IS350, 08 STI |
either get a map from tuner or tow the car to the tuner, u dont want to drive it like that
08-02-2006, 07:22 PM | #23 |
Member#: 115322
South East
Vehicle:04 STI ASPEN WHITE |
you just need a map to scale the injectors back. you had small injectors spraying a small amount of fuel now you have big injectors and the ecu does not know it.
Similar Threads | ||||
Car wont idle | hornyturbo | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 12 | 05-05-2009 05:00 PM |
Car wont idle after turbo and inlet install | nova7176 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 19 | 03-09-2009 10:54 PM |
car wont idle/p1022/IACV leaking air | SBW | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 07-14-2008 09:22 AM |
Car wont idle after trans install..? | Honkey3k | Normally Aspirated Powertrain | 4 | 03-19-2007 02:58 PM |
Installed new Trans, car wont idle? | Honkey3k | Transmission (AT/MT) & Driveline | 7 | 03-18-2007 02:02 PM |
