Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Old 06-21-2008, 07:47 AM   #1
4080wrx
Member#: 68129
Chapter/Region: HIIC
2001 Impreza RSTi
Default 97 OBS ABS Sensor
Hey guys I need your thoughts on this one. Currently I am doing a 03 WRX motor, tranny, and drivetrain into a 97 OBS.
The other day I swapped over the front hubs from the WRX and learned that the ABS sensor on the OBS is to long. Anyone have a fix for this? Luckily after I converted the rear drums to WRX rotors the ABS sensors plugged in fine.
The only options I can think of for the fronts are to use 03 WRX ABS sensors and hope they plug and play with the 97 OBS ABS or just use the 97 OBS hubs.
Thanks in advance
4080wrx is offline   Reply With Quote
Old 06-21-2008, 10:28 AM   #2
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
I should hope that'll work ont he fronts too. I did the same with my 97 OBS but used 02's in the rears. I"m not doing a WRX swap though. EZ30R here in the full. I"ll be the first to do a full swap and at minimun just the engine and using the stock ECU. Good luck though
-Gaddis
Seraphinwolf is offline   Reply With Quote
Old 06-22-2008, 06:19 PM   #3
4080wrx
Member#: 68129
2001 Impreza RSTi
well it looks like i will just end up installing 02/03 sensors.......anyone know if these will work with the 97 OBS' ABS?
ABS light on, what sensors trigger it? wheel ABS sensor, speed sensor, what else? kirbykirb Legacy Forum 4 06-19-2010 11:37 PM
WTB: left rear ABS sensor 99 OBS hunter15 MWSOC Private Classifieds 8 10-13-2008 07:33 PM
ABS light wierdness.. Faulty ABS Sensor? TKDKracker007 Brakes, Steering & Suspension 6 05-06-2006 01:33 PM
2002 OBS ABS acting up LostArt Brakes, Steering & Suspension 3 01-17-2004 12:36 PM
Drum to Disk swap on OBS? ABS issues? danc Brakes, Steering & Suspension 19 07-22-2002 01:07 PM
