Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 09-28-2008, 12:58 AM   #1
TDagen
Member#: 163648
V9 6mt R180 Brembos
Default Sti knock sensor on 02 Wrx hybrid?
Anyone ever done this? I have a hybrid knock issue was just pondering...Or is the Sti knock sensor the same as the 02 wrx, The 32bit just interprets it differently?
TDagen is offline   Reply With Quote
Old 09-28-2008, 01:05 PM   #2
TDagen
Member#: 163648
V9 6mt R180 Brembos
anyone?
Old 09-28-2008, 06:39 PM   #3
johnny p
Member#: 141232
02 v7sti wagon
signal green
Its" tuned "for the size of the motor. So use the EJ257 knock sensor.
johnny p is offline   Reply With Quote
Old 09-29-2008, 06:37 PM   #4
TDagen
Member#: 163648
V9 6mt R180 Brembos
Has anyone tried this I think it "might" solve some unwanted problems...If it really is tuned for the size of the motor it would be correct.
Old 09-29-2008, 07:00 PM   #5
Nuke209
Member#: 108089
2003 WRX
NF Performance
So you're wondering if using a 2.5l knock sensor would eliminate the infamous phantom knocks using the 16bit ecu.
Because if so, I am wondering that also.
Nuke209 is offline   Reply With Quote
Old 09-29-2008, 10:41 PM   #6
TDagen
Member#: 163648
V9 6mt R180 Brembos
Yes, yes I am. I am going to try it if no one has I mean this could be it...I have been tuning with RR and ever since this hybrid it loses power randomly from fake knock...
Old 10-01-2008, 12:29 AM   #7
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
Has anyone else toyed with the idea of using a sti knock sensor when doing a 2.5 hybrid swap?
rexworx is offline   Reply With Quote
Old 10-01-2008, 09:03 AM   #8
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Just be careful doing this because if I remember correctly the early WRX sensors emit higher voltages than the Sti sensor. The STi sensor requires amplification to get a good signal out of. While you could be fixing the phantom knock you could also reduce the ability of the ECU to detect knock. Since the ECU uses knock to determine ignition timing this could lead to a blown engine since the ECU could advance ignition well beyond the safe zone.
My 02 WRX Time Attack car with an STi motor had very high knock voltage values. This wasn't an issue since I was using a Hydra and could just raise the "knock threshold" map accordingly.
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Will 04 sti o2 Sensor work 02 wrx? coqui2004miguel Alaskan Impreza Club Forum -- AKIC 13 03-11-2010 11:26 AM
Help replacing O2 and A/F sensors on 02 WRX Samirr76 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 02-02-2010 05:02 PM
WTB: Knock sensor for 02 WRX turbobird14 Private 'Wanted' Classifieds 5 11-22-2008 12:47 PM
Vibration sensor on 02 wrx? califesaver Car Audio, Video & Security 1 11-10-2007 08:38 AM
location of the air intake temperature sensor on 02 wrx mac ej20 Service & Maintenance 3 09-02-2006 10:50 PM
