10-22-2018, 02:20 AM | #1 |
Member#: 485649
Project: Vooduru
The conversion is a 2009 WRX engine/ transmission into a 1973 VW Super Beetle. Yeah, I know it's been down many times before, but this one is different - trust me. The end product will be the ultimate sleeper VW (my version) street legal drag car.
I'm about 9 months into the project and pretty close to getting it running. I have about 1,000 pictures of ever detail of the build. I will post a few to get caught up, but if you have any questions about any detail, I probably have pictures. Part 1 of the project is to do the conversion. Part 2 is to restore the exterior/ interior of the Beetle back to it's original "like new" condition. I fabricate or build everything I can rather than buy it. Here's some pics of the header I built last week. It's equal length (within 3/8" of an inch) with 1-5/8"x .063" wall primary tubes and 1-7/8"x .63" wall up-pipe. The material is 321 stainless steel that is either fusion welded or uses 347 filler rod. It's all been back purged.
10-22-2018, 02:29 AM | #2 |
Member#: 485649
After the turbo, the exhaust has to bend around over the top of the motor and then down. Because I narrowed the torsion housing to fit 275 x 15" tires under stock fenders, there was no other place to run the exhaust. It's made of 2.75" x 063" wall 304 stainless.
10-22-2018, 02:45 AM | #3 |
Member#: 485649
Getting caught up.
10-22-2018, 02:49 AM | #4 |
Member#: 485649
The trans was pushed 4" forward past the torsion tube.
10-25-2018, 12:22 PM | #5 |
Member#: 2692
TXIC
Subscribed! Very cool
10-25-2018, 07:58 PM | #6 |
Member#: 485649
Getting started on plumbing. Need to get a bleed screw in the upper line still.
02-18-2019, 10:32 AM | #7 |
Member#: 427150
what is the radiator out of?
02-18-2019, 12:32 PM | #8 | |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
Looks like it's just a WRX radiator, the way the upper tank has that raised section with the fill neck on one end and the upper hose connection on the other. |
04-14-2020, 03:50 PM | #9 |
Member#: 507639
Vehicle:1973 Thing Type 181 Yellow |
Updates?
Any updates on this?
I have an EJ205 in a Thing. Curious to see how you do the plumbing. |
04-16-2020, 01:54 AM | #10 |
Member#: 352704
VIC
Vehicle:1965 Vw panel bus with an EJ20 Turbo Swap |
Wow , how'd I miss this build !
04-16-2020, 09:56 AM | #11 |
Member#: 493859
TXIC
Vehicle:06 WRX TD Swapped sorta black-ish |
Cool stuff.
Noob question on builds like this: How do you solve the drive line rotation problem? IE: needs to spin backwards instead of forwards? And all of the internals are engineered for spinning "the wrong way" under load. |
04-17-2020, 12:59 AM | #12 |
Member#: 352704
VIC
The Subaru engine spins the same way as the Vw engine so that's why these are perfect for these conversions. The only difference is that if you want to run a Subaru gearbox. Then you have to run a reversed ring and pinion from http://www.subarugears.com/
05-31-2020, 10:26 PM | #13 |
Member#: 515236
subbed, this is tight
06-08-2020, 11:56 AM | #14 |
Member#: 450480
Realy nice build. QQ's - Are you sticking with the stock height oil pan, what's your ECU solution, and what are you doing for the vehicle harness? Instagram/forum posts elsewhere?
Looking forward to more detail. |
06-08-2020, 02:08 PM | #15 |
Member#: 511005
This is awesome!
06-09-2020, 09:33 PM | #16 |
Member#: 352704
VIC
