Welcome to the North American Subaru Impreza Owners Club Monday March 25, 2019
Old 07-02-2008, 03:48 PM   #1
07tr
Member#: 149464
1977 Sierra Project
Primer
Default E85 Maps
Anyone know if there are any e85 maps floating around to purchase? I've looked everywhere and cant seem to find any. I know pdx tuning is doing them for access port, but im just not ready fork out 5 to 6 hundred bucks for one yet.
Thanks for any help
07tr is offline   Reply With Quote
Old 07-02-2008, 11:49 PM   #2
lukeskywrx
Member#: 59837
2004 Spec-C Type RA
What MAF? -Speed Density!
You can take a working gas map and given enough injector capacity just decrease the scalar by 25-30%, then tune to 12-12.5/1 gasoline afr, then give it a bit more timing. That will get you running just about right.
lukeskywrx is offline   Reply With Quote
Old 07-03-2008, 08:13 PM   #3
eminehart
Member#: 11205
2015 WRX
what injectors are you running.
eminehart is offline   Reply With Quote
Old 07-03-2008, 09:23 PM   #4
hotrod
Member#: 14141
2002 Impreza WRX
That is a bit lean for a start up map at WOT, to be safe it would be better to shoot for WOT high load mixtures in the 11.0-11.5 gasoline AFR range, and start out with timing you would use on the same setup for Pump premium to 100 octane Sunoco GT1.
A first attempt map should always be on the safe side of both timing and fuel air mixture. You can push those boundaries after you can get it on a dyno or do some logging to verify you are getting the actual mixtures and timing you think you are.
Safe starting maps are much cheaper than just a little too far maps.
Larry
hotrod is offline   Reply With Quote
Old 07-03-2008, 11:19 PM   #5
07tr
Member#: 149464
1977 Sierra Project
Primer
right now im running the stock injectors, thanks for all the information. i think im gonna have to give it a try. are my stock injectors ok or will i have to replace them first?
Old 07-03-2008, 11:40 PM   #6
eminehart
Member#: 11205
2015 WRX
They will not flow enough. Unless you just want to do it for gas price reasons. You would have to run at wastegate boost or youll max out the stockers in no time. Log you're Injector Duty Cycle if it goes above 55% then you will need bigger injectors. You will need a walbro fuel pump as well.
Old 07-04-2008, 01:10 AM   #7
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 551/441
You should contact Tim Bailey with Surgeline Tuning I was just talking to him today about e85. He said he tuned an STi last night using it and was hella impressed ( My words not his haha) I do a e85 mix tune but its not as common here as it is out in the nw
robbieshonda is offline   Reply With Quote
Old 07-04-2008, 02:11 PM   #8
eminehart
Member#: 11205
2015 WRX
E85 can get some serious performance advantages and it's cheaper than premium.
Old 07-06-2008, 02:11 PM   #9
Bullwinkle1983
Member#: 172332
2006 WRX
The stock injectors on the 06+ WRX are fine for running E85 on the stock turbo. E85 flows around 30 percent more fuel then non-oxy fuel, where did you get that 55% number?
Bullwinkle1983 is offline   Reply With Quote
Old 07-06-2008, 02:29 PM   #10
eminehart
Member#: 11205
2015 WRX
sorry I have had an exhausting week. my math wasn't working. But the number is around 60% any higher and you run high IDC or you lean out the tune to the point that an off the shelf tune would not be safe only a custom tune could be the safest option. I just don't know what kind of IDC on a 06-07 WRX stage 2
Old 07-06-2008, 11:24 PM   #11
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Ive tuned a few cars on e85 but all were carbed. they made great power. You just have to drive 45 minutes to get it here... and I have a race gas dealer right across the street
Steps to switching from E85 map to 93octane map Coop1103 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 05-16-2010 08:17 PM
new take on an e85 map wrxkyle AccessPort 3 03-03-2010 05:34 PM
new take on an e85 map wrxkyle Open Source Reflashes 0 03-02-2010 03:41 PM
cobb OTS stg2 E85 maps? redwrxhead AccessPort 1 08-15-2008 01:26 PM
AP E85 maps. ajchxc AccessPort 1 07-10-2008 09:38 PM
