Welcome to the North American Subaru Impreza Owners Club Friday July 19, 2019
Old 07-05-2008, 07:08 PM   #1
xBOXCARx
Member#: 92594
2005 Legacy GT, 16G
GRP
Default Open Source Tuning Help
I need your help. I am trying to get this to work, however, I can't even get ECUFlash to open any XPT maps or customized ones that are 192kb. The only maps it will recognize are 160kb maps. I have reinstalled the newest version of ECUflash and the definitions but it still says:
"Unknown Rom Image. Ecuflash could not recognize this ROM image using any of the current definitions. You can choose one of the following options:
1)abort using this ROM image (with no chance of saving)
2)continue using this ROM image with no definition (no editing or viewable, but saveble)
3)use wizard to create a new definition (NOT RECOMMENDED!!-FOR DEVELOPERS ONLY )
it also says this "[21:51:04.140] image file is incorrect size."
The Directions from XPT are as follows:
Copy the XPTxxxxx.XML file from that directory to the following location if using EcuFlash 1.30 or lower: "C:\Program Files\OpenEcu\EcuFlash\Metadat a\Subaru\WRX" , if you have an STI, change "WRX" to "STI". If you have EcuFlash 1.31 or higher, copy the file to this directory: "C:\Program Files\OpenEcu\EcuFlash\Metadat a\Subaru\Impreza WRX"
I have tried multiple times to follow the instructions but I'm not sure i'm following them correctly. For some reason it is not working for me. The Rom file i downloaded is a .HEX file. Does it need to be .xml in order for ECU flash to recognize it? If so is there a way to convert the file?
Any help would be appreciated,
xBOXCARx is offline   Reply With Quote
Old 07-06-2008, 03:51 PM   #2
eminehart
Member#: 11205
2015 WRX
You need 2 different files.
Your XPT Rom (xxxxxxxx.hex) file and your XPT definitions File (xxxxxxx.xml)
You put the xml file in the proper metadata folder and then open the hex file with ecuflash.
eminehart is offline   Reply With Quote
Old 07-06-2008, 07:57 PM   #3
xBOXCARx
Member#: 92594
2005 Legacy GT, 16G
GRP
Yup, that was the problem. Thanks man!
Old 07-06-2008, 11:31 PM   #4
eminehart
Member#: 11205
2015 WRX
you will also need a new ecu_def file for RomRaider to edit it. You can't just add a def to it. RomRaider uses only one file for all ecu definitions.
Old 07-07-2008, 02:01 AM   #5
mickeyd2005
Member#: 122595
2005 LGT Wagon
ABP
I have multiple xml files: the basic one, the motorcycle one, the beta 08 STi one... Romraider accepts more than one ecu definition XML file.
mickeyd2005 is offline   Reply With Quote
where to begin with open source tuning JustinS STi Commercial ECU Reflashes 34 02-01-2016 11:57 AM
New to Open Source/Tuning...a little help? subieguy2 Open Source Reflashes 15 07-18-2008 08:26 AM
open source tuning help.... Skatermxracer Tri-State Area Forum 15 03-25-2008 07:51 PM
The Official Enginuity Open-Source Tuning Thread qoncept Engine Management & Tuning 188 11-13-2007 08:15 PM
Open Source Tuning Sticky Proposal Tgui Commercial ECU Reflashes 3 11-24-2006 12:59 PM
