Welcome to the North American Subaru Impreza Owners Club Saturday March 23, 2019
Old 07-07-2008, 11:25 AM   #1
TDagen
Member#: 163648
2002 Resurrected WRX
Default very rough idle lean afr's at idle
Ive just reflashed to a different map . Im working on this new map for my hybrid 2.5l. It idles very rough with it runs lean longer than before when decelerating then re- applying throttle so if I put 10% throttle it will take 6 cells on the data log instead of two to drop the afr to 14. if someone lets me know how I will post a log or two. Its dw 740's 18gturbo bigtmic ect.. all advice is welcome. Thanks Travis
Old 07-07-2008, 11:39 AM   #2
brettm
Member#: 35107
2003 WRX WRB
2006 LGT Silver
Use (replace curly braces with []):
{CODE} {/CODE}
also has this been happening from the start or did it just start with your latest map? It sounds like you might need to scale your injectors... Did your other map work fine (did you try going back to it)?
brettm is offline   Reply With Quote
Old 07-07-2008, 11:46 AM   #3
TDagen
Member#: 163648
Yeah the last map works but its for acces port . Ive got the injectors scaled to 739 from the dw paper work. I beleive I am using stock latencies. It runs great under throttle afr at 11.24 but idle and very low throttle are weird. let me try and post one
Old 07-07-2008, 12:14 PM   #4
TDagen
Member#: 163648
[code]
Last edited by TDagen; 07-07-2008 at 12:51 PM. Reason: that was the most horrible looking log attempt.
Old 07-07-2008, 12:15 PM   #5
TDagen
Member#: 163648
sorry thats horrible!
Old 07-07-2008, 01:16 PM   #6
brettm
Member#: 35107
2003 WRX WRB
2006 LGT Silver
try running learning view and post up your results.
Old 07-07-2008, 02:31 PM   #7
TDagen
Member#: 163648
ive got rom raider it pops up in excelspread sheet any other way?
Old 07-07-2008, 03:45 PM   #8
brettm
Member#: 35107
2003 WRX WRB
2006 LGT Silver
open it up in excel, copy the log, paste it into the reply window in between the [CODE ] YOUR LOG HERE [/CODE ] tags
And go download learning view. Run it and post up the results.
Old 07-07-2008, 04:28 PM   #9
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
You need to change the column titles to 5 letters or less to keep the spacing right
[ code ]
MRP AFR RPM
20 14.7 3200
21 14.7 3500
[ /code ]
without the spaces
Code:
MRP  AFR  RPM
20     14.7   3200
21     14.7   3500
You can copy/paste directly from excel to inside the [ code ] "paste here" [ /code ] as long as the column titles are less than 5 characters.
You wont be able to run your same MAF table in Romraider that you did in AP. The AP uses different injectors scalars so you cant just change over to 740cc and 0.68 latency and have everything run correctly on the same MAF scale.
engine lean/rich at idle, otherwise good, help tune, gearing up for stage 2 MAtwal Engine Management & Tuning 0 02-17-2010 01:28 AM
lean at idle/gradually lean at wot MattP.18 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-21-2009 07:16 PM
Spiraling AFR's when pumping the brakes at idle... TexRex2002 Engine Management & Tuning 5 06-30-2004 12:57 AM
Spark plug=very rough idle and CEL? Bunuel Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-22-2002 11:59 PM
Very rough idle...HELP! bouse1 Normally Aspirated Powertrain 1 08-10-2001 03:15 PM
