Welcome to the North American Subaru Impreza Owners Club Tuesday March 26, 2019
Old 07-09-2008, 04:04 PM   #1
ogboot
Member#: 170906
psm
Smile First time log before tuning, what to log?
Hey guys, my tactrix cable is waiting in my mailbox. I have a stock 02 wrx and am about to get into modding it. Was going to try out a stage1 map whilst waiting for my turbo-back, but before i change anything i want to do some data logs @ stock to make sure i don't have any problems to begin with. What should I log besides knock correction, timing, etc?
Thanks in advance.
ogboot is offline   Reply With Quote
Old 07-09-2008, 11:49 PM   #2
Kotir
Member#: 17300
1993 Widebody Wagon
748whp e98
Here's what RomRaider recommends logging starting out:
http://www.romraider.com/Documentati...aiderFAQ#toc69
RomRaider FAQ are definitely worth reading through if you're new, that's what I've been going over since I got my Tactrix cable.
-Tim
Kotir is offline   Reply With Quote
Old 07-10-2008, 01:15 PM   #3
bcblues
Member#: 17256
18 Outback
on the road....
It depends on what maps you intend to modify. If you are working on fueling, you will log different parameters than if you are working on boost.
bcblues is offline   Reply With Quote
Old 07-10-2008, 02:01 PM   #4
ogboot
Member#: 170906
psm
i checked the linky in post #2 and did some runs @ stock just to make sure I wasn't having any unknown problems before I reflashed. Everything looked great, have the opensource stage 1 flash on the car now and everything seems to be running fine. ima keep doing some research and may get around to tweaking it a little eventually.
Going to Oahu for the first time. Any ideas on what I should do? nottheliving Off-Topic 64 01-13-2007 08:08 AM
EJ25 to EJ25 swap, first time, good tips and tricks to know? Patrick Olsen Subaru Conversions 8 11-27-2006 10:14 PM
One more mod before a tune..what to get? ScoobySnacker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 09-12-2006 02:55 PM
First time visiting LA area...what to do? Dick Fitzwell Southern California Impreza Club Forum -- SCIC 19 05-25-2005 12:00 PM
first time at the track, what can i do better? Depeche Proven Power Bragging 3 04-14-2003 07:48 PM
