Welcome to the North American Subaru Impreza Owners Club Tuesday March 26, 2019
Old 07-08-2008, 11:54 PM   #1
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Default deleting TGVs and I/M Readiness status
I was wondering, when a TGV delete is done does it affect the i/m readiness status if the CEL is deleted via open source?? Do they affect any thing as far as fuel trims go??
in time i want around 300 whp out of my 02 wrx and want it to be a reliable daily driver so im very curious about tuning and doing it properly.
mxpunk is offline   Reply With Quote
Old 07-12-2008, 11:22 AM   #2
matty50racer
Member#: 166668
They don't effect fueling at all and you can set a switch to force pass readiness and never worry about that again.
matty50racer is offline   Reply With Quote
Old 07-13-2008, 02:49 PM   #3
alwazsidwaz
Member#: 133454
2004 Forester
AW
how do you set a switch? is there a link you could post?
alwazsidwaz is offline   Reply With Quote
Old 07-13-2008, 02:52 PM   #4
Arctic Penguin
Member#: 119532
2006 WRX
you can also leave the rods in with motors and sensors functioning and never know the difference
Arctic Penguin is offline   Reply With Quote
Old 07-13-2008, 05:02 PM   #5
MasterKwan
Member#: 98961
2003 WRX
They do affect cold start fueling. I richened up my cold start mixture to match the TGVless JDM WRX's.
MasterKwan is offline   Reply With Quote
Old 07-13-2008, 06:31 PM   #6
Wheeler Bement
Member#: 15652
2002 2.5L WRX Wag.
160K club
where did you do this? I have an 02 and can't find anything that remotely "looks" like a cold start up fueling parameter. maybe the 02's don;t have it defined yet.
Wheeler Bement is offline   Reply With Quote
Old 07-13-2008, 09:28 PM   #7
MasterKwan
Member#: 98961
2003 WRX
I believe it's "Primary Open Loop Fueling Compensation (Coolant Temp)"
Old 07-14-2008, 10:12 PM   #8
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
thanks for the info guys. when do tgv's start becoming a restriction?? i eventually want around 300 whp, maybe alittle more.
Old 07-16-2008, 09:29 PM   #9
matty50racer
Member#: 166668
If you can do it yourself it's a free ~10hp mod. Obviously the more power you make the more power you'll get from this mod. They aren't going to be a "restriction" at the 300hp level but will make your goal easier to reach with less boost pressure.
Not ready status...... help Sideshowbob Service & Maintenance 28 05-16-2009 11:38 PM
WRX intake manifold with deleted TGVs SubeSTIle SWIC Private Classifieds 0 01-19-2009 06:51 PM
anyone have deleted tgvs? SubeSTIle South West Impreza Club Forum -- SWIC 0 06-29-2007 01:09 AM
FS:VA - APS TGV Delete Mounts and Brackets AspenItIs Engine/Power/Exhaust 27 06-13-2007 01:12 AM
