Welcome to the North American Subaru Impreza Owners Club Tuesday March 26, 2019
Old 02-18-2015, 10:23 AM   #26
XERO287
Member Sales Rating: (18)
Member#: 253541
2011 WRX 5DR Premium
^The ratings for 6 speed clutches are far different than that for 5 speed clutches.
XERO287 is offline   Reply With Quote
Old 02-18-2015, 10:24 AM   #27
XERO287
Member#: 253541
Originally Posted by tomkun View Post
Is their anyone here on that has the stage 2 daily on a wrx thats making around 330whp?
I know on venders site it says 315 but I read that a lot of people said their clutches are underrated.
I'm making that, had to switch from stage 2 Daily to stage 3 Daily. I feel like the stage 3 is a better clutch after owning both in any case.
Old 02-18-2015, 11:20 AM   #28
flimflamman
Member Sales Rating: (47)
Member#: 147328
2007 WRX
FlimFlamRacing
Yes, I was referring to the 5 speed kit, FTR.
flimflamman is offline   Reply With Quote
Old 02-24-2015, 03:50 PM   #29
azsun
Member Sales Rating: (1)
Member#: 351553
Looking to pull the trigger on a SB soon, really haven't been impressed with the ACT HD so far.
Debating between the 5 speed stage 3 DD or endurance; anyone have feedback between the two? Noob question, but I'm assuming the 6 speed won't work on a WRX
At 305 wtorque on 91, ~360 on 100oc/E85 (don't use all that often).
azsun is offline   Reply With Quote
Old 04-12-2015, 11:11 AM   #30
URABUS07WRX
Member Sales Rating: (11)
Member#: 262367
2007 WRX
Just got tuned yesterday by Corbin Johnson on E85 making 430/417 and the clutch is holding up great!
URABUS07WRX is offline   Reply With Quote
Old 09-13-2015, 03:52 PM   #31
Cefaln452
Member Sales Rating: (22)
Member#: 255736
2004 STi
JavaBlackPearl
I am running the same clutch and Corbin tuned me as well making 575whp and its holding up just fine.
Cefaln452 is offline   Reply With Quote
Old 03-24-2016, 04:47 PM   #32
TROLL
Top Scoob 006
Member Sales Rating: (63)
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
Did you say you are running a Southbend Stage 2 Daily at 575 whp? Are you sure?
TROLL is offline   Reply With Quote
Old 03-26-2016, 06:27 PM   #33
brumby
Member#: 162631
03 subaru wrx
I've used southbend for my focus svt and wrx. I drove to southbend and picked both clutches up and had them matted with the flywheel I was using. Great company and I only can say positive things about the stage 2 and up.
brumby is offline   Reply With Quote
Old 03-29-2016, 02:14 PM   #34
Miggs1337
Member Sales Rating: (2)
Member#: 379581
2014 WRX
Gloss Vengeance Red
I wanted to add my .02. I've had this clutch for about a year and rolling around 400 wtq on the SB Stage 3 daily clutch and it's been awesome. Clutch is heavier, but I actually prefer that. The engagement is close to stock as well. I love it!
Miggs1337 is offline   Reply With Quote
Old 03-29-2016, 09:54 PM   #35
Cefaln452
Member#: 255736
2004 STi
JavaBlackPearl
Yes I am sure, car is making north of 650 at the wheels and it doesn't slip... can't launch the car but other than that it won't slip. I need to get a much larger one so that I can launch it.
Old 04-03-2016, 05:59 PM   #36
H_wells3000
Member Sales Rating: (14)
Member#: 322035
You are way out of this things range!
Checking in awhile later. I ended up smoking this clutch around 380 wtq.
This is after I roasted it pretty bad launching it, the slippage became worse and worse.
I have since switched to the endurance version with the cerametallic and all has been well.
H_wells3000 is offline   Reply With Quote
Old 11-18-2017, 06:40 AM   #37
blue sedan
Member Sales Rating: (9)
Member#: 311622
2010 WRX
Originally Posted by flimflamman View Post
I really like the 5 speed Stage 2 DD. The pedal feel is just like OEM, which is great for my mostly congested commute. It has a nice grab that isn't to harsh on the shifts.
However, I am putting 320 to the wheels and it is only rated at 315 at the crank. So... I am a bit over the recommended amount, but I only commute with it now and if I ever get back to rallycross and/or HPDE it will likely wear pretty quick.
I also got the OEM flywheel this time around. The LWFW was nice (awesome for the track), but I got tired of the CEL's, shudders, and heavy pedal (in traffic) from the Act HDSS clutch.
How has the clutch been holding up for you since you are over the torque rating?
blue sedan is offline   Reply With Quote
Old 11-18-2017, 08:39 AM   #38
Usmc75
Member#: 469554
Heard great reviews about SB stage 3 daily. Can anyone confirm this that had experience with this clutch with a 5 speed?
Thanks!
Usmc75 is offline   Reply With Quote
Old 12-25-2017, 08:18 PM   #39
Enlight
Member#: 58574
2005 Legacy GT Wagon
Are you guys mating this to South Bend's flywheel or OEM?
Looking to replace Clutchmasters FX300/LWFW from previous owner. I live in NYC, deal with stop 'n go traffic, want lighter clutch engagement, and reduce NVH.
Enlight is offline   Reply With Quote
Old 12-26-2017, 09:49 PM   #40
VsubaruT
Member Sales Rating: (6)
Member#: 448117
2006 WRX
steel gray
Currently running SB stage 2 daily with OEM flywheel. Putting 327whp and 331wtrq. Holding real well. Love this clutch!
VsubaruT is offline   Reply With Quote
Old 02-19-2019, 10:20 AM   #41
AcquaCow
Member Sales Rating: (46)
Member#: 36838
2001 B50 RSTi Sedan
2011 DGM WRX hatch
Put 30k on a stock STi clutch/flywheel at 20psi on a vf39 ~350wtq, no issues.
Swapped to a South Bend stage 2 daily, broke it in over 500mi and on my first WOT roll in 3rd gear, it started slipping. I put 4000mi on it overall, tried various ways to try and bed it in better, but no luck. I got into the winter months with colder air, making a bit more power, and it would slip on any WOT runs in 3rd through 5th.
I eventually had to dial the boost back a tad to keep it from slipping, but that's no fun.
I finally had it swapped out after 4k miles and it all still looks kinda brand new. The flywheel even still had machining marks on it/etc.
I think in my case, the pressure plate just wasn't up to the task.
I'm back on an ACT HDSS, which is what I was on before I went back to a stock clutch. I hate how heavy it is, but it certainly doesn't slip. Now it's time to swap my VF39 for a 1.5xtr and push higher =)
AcquaCow is offline   Reply With Quote
Old 02-23-2019, 10:34 AM   #42
Subimods
Vendor Sales Rating: (32)
Member#: 209139
2019 STI
We love these clutches! You made a great choice. Respect for the 6spd swap as well!
__________________
| Lowest Prices On Subaru Performance Parts Anywhere
| Price Matching Available
ALL "Shipped" prices are for orders within the Continental US Only (Lower 48 States). Military & First Responder Discounts Available! We want to earn your business!
Email:
Phone: 860-291-0015 Facebook:
Instagram:
Subimods is offline   Reply With Quote
