Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2019
Old 02-18-2019, 02:50 PM   #2751
brecks
Member#: 435142
2004 STi
Java Black Pearl
Originally Posted by PDXREALTOR View Post
I have material here that you can use to make a custom 2.5 - 3" intake adapter for your 7163. It slips right on the inlet cover. I'll send you one for the price of shipping. All they are is skateboard wheels, and you'll hog out the center with a forstner bit.
They have a durometer reading high enough to handle the heat. I can take a pic of the one that's sitting on my 7163 right now, after a lot of use.
Another key, IMO, is the intake filter. Make sure you get a filter with a 6" opening and put it on a velocity stack style intake fitting that then connects to a 3" pipe.
You can also see some of my best graphs a few pages back. I got better spool and redline RPM by ditching the BW wastegate can, and going with a high spring turbosmart one port.
I have the turbosmart with high spring pressure, but itís a dual port. Iíd definitely be interested in seeing the custom 3Ē setup. Iíll send you a PM.
brecks is offline   Reply With Quote
Old 02-18-2019, 03:09 PM   #2752
Waddlz
Member#: 395275
2012 STi
If I copy your VE and put in for my altitude, I am way out of range of the compressor at 7000 RPMs at 27 psi
The only one that comes close to being in the efficiency ratio is an 8374, but it says it will surge at low throttle.
Waddlz is offline   Reply With Quote
Old 02-18-2019, 03:13 PM   #2753
PDXREALTOR
Member#: 468393
2017 STI
Originally Posted by Waddlz View Post
Yes. I did not realize that with the V-band there is no way to upgrade to a 7670 or 8374. I'd need an entire new kit.
Even without vband the 7163 is a t-25 and the b2 frames are t3.... I just went through this as I really wanted to keep the 7163, but rotated.
PDXREALTOR is offline   Reply With Quote
Old 02-18-2019, 03:50 PM   #2754
Waddlz
Member#: 395275
2012 STi
I downloaded a spreadsheet to calculate VE, and I "think" its correct.
based on these numbers, I'm well in the efficiency range of this turbo at 24 psi.
I need to find a log that i hit 27, as this one was on E68 and held ~25 to redline
Old 02-18-2019, 03:52 PM   #2755
PDXREALTOR
Member#: 468393
2017 STI
My same matchbot show on the map at redline on a 7670. I'm far from knowing much of anything re: compressor maps so, I may be someplace I shouldn't be earlier on the map.
Old 02-18-2019, 03:53 PM   #2756
Waddlz
Member#: 395275
2012 STi
Old 02-18-2019, 04:27 PM   #2757
Waddlz
Member#: 395275
2012 STi
Old 02-18-2019, 05:16 PM   #2758
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
You have to move the dots to your housing.
yamahaSHO is offline   Reply With Quote
Old 02-18-2019, 07:21 PM   #2759
brecks
Member#: 435142
2004 STi
Java Black Pearl
Any suggestions for a mild cam with a stock location 7163? Built bottom end, stock B25 heads, FMIC, E85. Thinking along the lines of a GSC S1
Old 02-19-2019, 03:15 PM   #2760
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
Here's my attempt at matchbot. The only thing I'm sure about is the data I entered came straight from a log. Other info may be off, most of it I left as is unless I had the data.
I'm also hybrid MBC so note the WGDC data may be wacky. I forget the details on what I did with those in matchbot. I just remember having to play with them.
Matchbot
I find the VE increasing at redline to be odd. Also, did you actually log exhaust back pressure, intercooler pressure drop, and air filter drop? Or were they just guesses? they all affect your mass flow rate.
And honestly, your pt 6 isn't that far off the map.
Have you plotted the power output from Matchbot versus actual dyno data you have, to check the shape of the projected curve?
I'd also ditch the 2500 RPM in lieu of a 3500 RPM where your psi and torque values are climbing hard.
Old 02-19-2019, 03:27 PM   #2761
PDXREALTOR
Member#: 468393
2017 STI
Thx. I didn't change anything but the boxes I could input actual log data into. I'll play with this when I'm not mobile. My ve map is *dialed* and, I'm at or above 100 in alot of high map/rpm cells. *shrug*
I have compared numbers to the virtual Dyno log I used, torque is pretty close except the last matchbot cell, power.... Not so close. I'll throw them both up tonight.
Old 02-20-2019, 08:00 AM   #2762
Onyanineza
Member#: 495426
Just looking at all those engines makes my heart warm
Onyanineza is offline   Reply With Quote
Old 02-20-2019, 11:55 AM   #2763
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
Kelford Rally cams.
subydude is online now   Reply With Quote
Old 02-20-2019, 12:39 PM   #2764
brecks
Member#: 435142
2004 STi
Java Black Pearl
Originally Posted by subydude View Post
Kelford Rally cams.
Thanks! Those the 264/260? Any particular reason?
Old 02-20-2019, 04:34 PM   #2765
subydude
Member#: 80649
If you compare the profile in depth it's got more lift with less duration than the S1's which will match that turbo and stock port heads better.
Old 02-20-2019, 05:59 PM   #2766
brecks
Member#: 435142
2004 STi
Java Black Pearl
The only kelford rally cams that I found are dual AVCS. For single AVCS the R-199-B are the closest match, 264/260 I: 10.9mm E: 10.45mm Compared to the old S1s (not the new billets which are 268) 266/266 I: 10.8mm E: 10.4mm
Don't want to stray too far from Borg Warner talk, drop me a PM
Old 02-20-2019, 08:15 PM   #2767
Homemade WRX
Member#: 33782
96 in the garage
Meh, there are like 12 of us on here anyway and I'm pretty sure we all like engine talk.
Old 02-20-2019, 08:27 PM   #2768
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
You shouldn't have to enter anything in Match-Bot about your wastegate situation. If you enter all other data fairly accurately it will calculate the expected WG % at each of your 6 data points. My Match-Bot for the 7670 was pretty accurate on my 2.35L. I was way off the map past 7200 rpm @ 25 psi. Coincidentally even on my race-gas tune I didn't gain much trying to run 30 psi to redline so we tapered boost from 35 psi to 25 psi at redline (8200rpm). The 8374 shows to be a better match and since I would like to see what 30 psi does on E85, I'm upgrading to the 8374 soon.
Matchbot
Old 02-20-2019, 09:16 PM   #2769
Homemade WRX
Member#: 33782
96 in the garage
That'll be the jam! Already own it or can you still look at the 8474?
Old 02-20-2019, 11:49 PM   #2770
kellygnsd
Member#: 32669
LINK G4+ hybrid STi
Sold. Thats a nice wide map. Are they on the market already?
Old 02-21-2019, 01:47 AM   #2771
brecks
Member#: 435142
2004 STi
Java Black Pearl
In that case, what do you think? Slightly more lift or slightly more intake duration and a good bit more exhaust duration? Iíve always been under the impression that for turbo cars, more lift equals quicker spool and more duration means more horsepower up top
Old 02-21-2019, 11:35 AM   #2772
subydude
Member#: 80649
Look at the ramp angle too and how they're measuring lift at what distance. There's more than just the peak duration/lift to a cam.
Old 02-21-2019, 12:31 PM   #2773
brecks
Member#: 435142
2004 STi
Java Black Pearl
I donít think Iím familiar enough with cams to know the difference in performance of things like duration at X amout of valve lift, or timing at X amount of valve lift. Much to learn.
For ramp angle, is the Kelford a steeper angle? The heads have slightly stiffer springs (Manley singles with ti retainers) and stock valves. Correct me if Iím wrong, but steeper angles mean more harsh opening/closing of valves.
Old 02-22-2019, 11:47 AM   #2774
Waddlz
Member#: 395275
2012 STi
if I Had a CD block, I'd be rocking that 8474 too. Thing is amazing
Full race says "coming soon" but it will probably cost $2900 from them when you can buy it anywhere else for half that.
Old 02-22-2019, 02:19 PM   #2775
PDXREALTOR
Member#: 468393
2017 STI
Paid 1740 shipped for my 7670.
