Welcome to the North American Subaru Impreza Owners Club Thursday March 21, 2019
Old 08-18-2006, 02:54 PM   #1
gotawd
Member#: 31504
FP Red
2.5L/6 speed 02 WRX
Default CEL P1112 and P0244
I am throwing these 2 codes on start up. The car will start for about 2 seconds then the CEL will come on and shut the car off and throw just these 2 codes.
P1112-atmospheric pressure sensor circuit range/performance problem
this sensor is in the ecu which could be a big problem but just curious why im throwing it and if any way to fix.
P0244-range/performance of wastegate solenoid
im using a external wastegate so im not sure what the deal is with this one.
if anyone has any idea or what i can try to do to fix id appreciate it. i just need this thing to start.
tyler
gotawd is offline   Reply With Quote
Old 08-18-2006, 03:48 PM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
It's possible a barometric pressure sensor failure might be provoking the P0244 and a fuel cut. What do the freeze frame data say about manifold absolute pressure and RPM? It's also possible the real failure is with the MAP sensor.
There's no way to repair the barometric pressure sensor.
How many miles on your 2002 WRX? The ECU is covered by a Federal Emissions Extended Warranty good for 8yr/80,000mi. But you couldn't just show up at a Subaru dealer with the ECU in hand and get it replaced. You'd have to have the car towed in.
Jon [in CT] is offline   Reply With Quote
Old 08-18-2006, 04:22 PM   #3
gotawd
Member#: 31504
FP Red
2.5L/6 speed 02 WRX
i just bought the ecu on nasioc. i put it in my buddies wrx and it worked fine. i have 75k on my car but a built 2.5 with a fp green and such on it. any idea what i can try to get this figured out?
Old 08-18-2006, 04:31 PM   #4
gotawd
Member#: 31504
FP Red
2.5L/6 speed 02 WRX
the first problem was my EW burnt 6 wires together on the bulkhead harness which fried a ground pin in the ecu. i soldered all the wires back together got a new ecu and messed it up(had the shielded wire and the MAF wire soldered together). with that ecu the car would start and run and throw high input codes for the 7 sensors that are on the harness. so with this new ecu i dont get any high input codes and just those 2. i am confident all my wiring it fixed just curious about these codes. and with the ecu that through the high input codes it didnt throw these 2 which i figured it would. so im stumped
Old 08-18-2006, 04:31 PM   #5
Jon [in CT]
Member#: 2992
02 WRX Sedan
Yes. Tell us what the manifold absolute pressure and RPM were from the freeze frame data that was stored along with those two trouble codes.
Old 08-18-2006, 04:44 PM   #6
gotawd
Member#: 31504
FP Red
2.5L/6 speed 02 WRX
i dont have any other data. i used a cheapo obdII scanner and all it showed was the codes.
Old 08-18-2006, 06:35 PM   #7
Jon [in CT]
Member#: 2992
02 WRX Sedan
Find a better one.
Old 08-18-2006, 08:28 PM   #8
gotawd
Member#: 31504
FP Red
2.5L/6 speed 02 WRX
where do i get a scanner that shows you data logs?? most of the ones i have used or borrowed only pull codes.
Old 08-19-2006, 02:41 PM   #9
gotawd
Member#: 31504
FP Red
2.5L/6 speed 02 WRX
any ideas?
Old 08-20-2006, 04:43 PM   #10
gotawd
Member#: 31504
FP Red
2.5L/6 speed 02 WRX
the ecu is perfectly fine...i just put it in my buddies wrx and it fired right up and didnt throw a code. anyone else ever had this code and what did you do to fix it??/
Old 02-13-2019, 10:40 PM   #11
rallysti2004
Member#: 497757
hi, I see this is an old thread but this just happend to me and I wondering how you fixed it?
rallysti2004 is offline   Reply With Quote
Help -> massive power cut and P0244 accelguy Open Source Reflashes 4 06-30-2008 10:22 AM
ABS and CEL on and Speedometer is dead Silentdawn Service & Maintenance 21 11-12-2006 08:43 PM
CEL light code P0244 then light clears??? ChrisCJ99 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 10-01-2006 01:09 PM
P1544 and P0244 cel fixes rs6 Service & Maintenance 0 07-26-2005 02:51 PM
HELP - CEL P0302 and P0304 = Misfire on Cyl 2 and 4! dexterous Normally Aspirated Powertrain 8 04-14-2005 11:38 PM
