Welcome to the North American Subaru Impreza Owners Club Friday March 22, 2019
Old 06-12-2008, 12:53 PM   #26
efmd3
Member#: 120985
2002 Impreza WRX
Midnight Black Pearl
oh shyte, well hopefully that isn't my problem...
efmd3 is offline   Reply With Quote
Old 06-12-2008, 05:36 PM   #27
criscross79
Member#: 12263
'02 WRX SRP 4EAT
XPT Stg II
It could also be the wires from the green connectors to the ecu. Personally I would rather replace the tactrix cable then pull apart the dash to replace some wires.
Chris
criscross79 is offline   Reply With Quote
Old 06-13-2008, 08:47 AM   #28
efmd3
Member#: 120985
2002 Impreza WRX
Chris
true, hopefully its not a wiring, but rather a software issue.
Old 06-13-2008, 06:11 PM   #29
criscross79
Member#: 12263
'02 WRX SRP 4EAT
XPT Stg II
well, if it's a software issue, you can do what I did and reinstall all software and drivers and replace the ecu. After all of that though, mine still didn't work
testing it with another tactrix cable was the last thing I could do before I started replacing the wiring.
Chris
Old 06-15-2008, 12:54 PM   #30
snobrder_ad
Member#: 129203
2004 WRX Aspen White
StgII
any updates on your fix? ive been having the same problems
snobrder_ad is offline   Reply With Quote
Old 06-16-2008, 04:10 PM   #31
efmd3
Member#: 120985
2002 Impreza WRX
cable was toasted, thanks for your help everyone
Old 06-16-2008, 05:22 PM   #32
Nuke209
Member#: 108089
2003 WRX
NF Performance
I knew it!
Nuke209 is offline   Reply With Quote
Old 06-16-2008, 06:36 PM   #33
efmd3
Member#: 120985
2002 Impreza WRX
yea, too bad they dont have any kind of warranty
Old 07-06-2008, 09:20 PM   #34
Silverpike
Member#: 92399
Arrrrrrrrgh. I have this exact problem. Everything Chris says is happening to me too. I have an original v1.0 OpenPort, and I've never gotten around to using it until today.
From reading through the posts, it looks like there is some probability my cable is toast. That makes me .
Mine is an 02 WRX (early build date). I can datalog with the cable using RomRaider, but ECU reading always fails. I've tried every suggestion posted on every thread on NASIOC, RomRaider, openecu.org, and God knows where else on teh internets. I've never tried a write. I have one more laptop I can try tomorrow, but I predict that will fail as well.
I may just have to suck it up and buy a new v1.3.
Silverpike is offline   Reply With Quote
Old 07-06-2008, 10:02 PM   #35
criscross79
Member#: 12263
'02 WRX SRP 4EAT
XPT Stg II
Just get a version 1.2. it's $20 cheaper. that's what I'll be getting when I get around to buying one.
Chris
Old 07-07-2008, 09:55 PM   #36
bcblues
Member#: 17256
18 Outback
on the road....
I had a Tactrix cable go bad on me too. In fact, it became a bit flaky and then it came apart at the seam when I went to unplug it form the OBD2 port. The end of the plug stuck inside the OBD2 port, and the rest came out in my hand. I ordered a new one, which works fine. Then I futzed theold one back together (it just unplugged from the circuit board inside the plasting plug and the two plug halves came apart). The old one works fine now too. I just made sure the tiny pins were properly aligned, plugged the two halves together and put a few drops of superglue in the seams to hold it securely.
bcblues is offline   Reply With Quote
Can't find my reflash connector plug KAX Electrical & Lighting 0 04-19-2007 01:39 PM
'02 Can't Reflash criscross79 Commercial ECU Reflashes 25 04-14-2007 10:42 AM
'stage 1' reflash people. did you feel the gains with just a reflash? DoctorNick Forester Forum 16 04-09-2005 06:50 PM
WTT: (Cobb Stage 2 AccessECU) '03 reflashed ECU for '02 reflashed ECU 02subadrew Private 'For Sale' Classifieds 6 03-16-2005 10:38 AM
Cobb reflash and dealer reflash question battosai Bay Area Impreza Club Forum -- BAIC 0 09-11-2003 11:23 PM
