Welcome to the North American Subaru Impreza Owners Club Monday March 18, 2019
Old 07-03-2008, 07:28 PM   #1
eminehart
Member#: 11205
2015 WRX
Default All of a sudden.....Low Progaming Voltage
I have an 02 wrx. All of a sudden I cannot flash. This is the first time in over a hundred flashes. I am getting the low programming voltage error. It is 4.3 instead of 12. I checked the jumper so don't ask.
The voltage at the jumper is 4.3 there is no short or break because the voltage goes all the way to the OBDII port.
I tried resetting the ecu- with software and by pulling the negative.
Does anyone else know what the voltage should be at the jumper and maybe thats causing my problem. The reason I ask is that at one time I tested the voltage and i think it was 12.
I need help does anyone know how to fix this?
eminehart is offline   Reply With Quote
Old 07-03-2008, 07:41 PM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
Some people route 12V to the jumper from another source to get around this problem.
Jon [in CT] is offline   Reply With Quote
Old 07-03-2008, 07:52 PM   #3
eminehart
Member#: 11205
2015 WRX
Can I route any 12V directly to the jumper and it will flash safely. And should it be directly to the Blue wire(that goes to the OBD port) or the Red/white wire (that goes to the ECU and is hot with the 4.3 voltage) or should i connect both wires to a 12Volt source.
Old 07-03-2008, 09:31 PM   #4
eminehart
Member#: 11205
2015 WRX
So should that red/white wire be 12V.
Old 07-03-2008, 10:46 PM   #5
eminehart
Member#: 11205
2015 WRX
well i got it to flash
Just cleaned the OBD2 ports terminals with some Electric parts cleaner.
I was getting worried........................................... ............
BTW it's only 4.3 Volts there.
Old 07-05-2008, 02:51 PM   #6
wrx2k4
Member#: 68632
2017 STI
Wht
did you use the spray like you would use to clean out your desktop key board? or something diff im having the same problem and this may help me out alot!
wrx2k4 is offline   Reply With Quote
Old 07-06-2008, 03:02 PM   #7
eminehart
Member#: 11205
2015 WRX
no the electrical connection cleaner stuff. I got CRC QD-electronic cleaner. If you have MAF sensor cleaner you can use that as well. I believe it's some kind of alcohol blend. They are available at all auto parts stores. Probably a BigBox store as well but less likely.
Old 07-06-2008, 09:50 PM   #8
wrx2k4
Member#: 68632
2017 STI
Wht
^^^awesome im going to try it out and see what happens. thanks for the input by far the most helpful piece of info yet to be posted. I was to the point of buying a new ecu or burning the car lol! j/k
Old 07-10-2008, 11:11 PM   #9
eminehart
Member#: 11205
2015 WRX
I don't think I had heard of a OBD2 connection being that gunked up before. I do have a lot of miles 172,000 and driven down my fair share of dusty roads.
I just gave it a shot and it worked out for me.
BTW are you having any luck?
Old 07-11-2008, 12:02 AM   #10
nhat
Member#: 140163
03 STi
hellaflunctional
172k on an 02?! damn
do you ever go to any pirates meets? i went to a couple while i was out there
Whine noise all of a sudden in WRX - all gears at certain times Civ2Sub311 General Community 46 09-15-2018 11:06 PM
'02 WRX high/low boost problem all of a sudden andygold Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-11-2006 08:51 PM
What's with all the dog killing all of a sudden? now with a sword mr_disco Off-Topic 10 09-02-2004 10:00 PM
My valley = plethora of rednecks all of a sudden... Jimmy S. Off-Topic 7 11-06-2003 04:20 AM
