Welcome to the North American Subaru Impreza Owners Club Friday March 22, 2019
Old 07-05-2008, 01:36 PM   #1
SurfGuruJeff
Member#: 148974
2010 4x4 Silverado
Default EcuFlash won't read, but RomRaider Logs
I've tried and tired and tired to get EcuFlash to work, but I keep getting one of two errors:
(This error I get if I hit OK the split second after I turn on my ignition)
OpenPort 1.3 Subaru TX46LrMNd06cb4d53c44cfa1c85992b7774ccd7c4ee5e4cc [10:30:14.650] SSM2 init
[10:30:14.830] SSM2 ECU ID is 3D 12 59 40 06
[10:30:14.960] Requesting Seed...
[10:30:15.021] Sending Key...
[10:30:15.692] interface close
[10:30:15.702] interface close
(I get this error if I hit OK after the ignition is on)
[10:29:29.415] SSM2 init
[10:29:29.866] SSM2 init
[10:29:30.316] SSM2 init
[10:29:30.767] SSM2 init
[10:29:31.218] SSM2 init
[10:29:31.668] SSM2 init
[10:29:32.109] SSM2 init
[10:29:32.549] SSM2 init
[10:29:32.990] SSM2 init
[10:29:33.431] SSM2 init
[10:29:34.022] kernel get version
[10:29:34.663] interface close
[10:29:34.673] interface close
[10:29:40.561] Using interface
Green test connectors are plugged in, and working (i.e.- the car won't start in test mode).
I am able to log in RomRaider with no problems.
I have used this tactrix cable to tune my 02 WRX without any problems.
I switched from EcuFlash 1.35 to 1.34 and the problem is still the same.
This is for a USDM Drive-By-Wire 2005 STi
SurfGuruJeff is offline   Reply With Quote
Old 07-05-2008, 02:12 PM   #2
wrspeed
Member#: 40110
04 STI
131 MPH 4th gear Madness
make sure that romraiders logger is not runing when you try to read or flash the rom because both programs are going to be tryng to use the same port at the same time.
im using the 1.35 since it came out with no issue
wrspeed is offline   Reply With Quote
Old 07-05-2008, 02:49 PM   #3
fujiillin
Member#: 171344
2006 STi Wagon
Black HTA Green
I'm not too familiar with the 16 bit ecu's, but are you connecting the reflash connector and the green connectors?
fujiillin is offline   Reply With Quote
Old 07-05-2008, 03:24 PM   #4
SurfGuruJeff
Member#: 148974
2010 4x4 Silverado
I know not to run two programs on one device, so no, that's not it.
This is a 32bit ECU that does not require a flash block connector like the older model Subarus. I have the blocks just in case, and looked under the dash... nothing there for flash block connecting, as there shouldn't be.
Old 07-06-2008, 07:47 AM   #5
tekfoc
Member#: 21392
2016 C63S AMG MB
Iridium /MB C300 4MATIC
on your passanger side below glovebox side of the door remove cover ! make sure the green connectors are connected .
allways leave this connection connected. svc tech probley forgot to reconnect it or the last owner .
tekfoc is offline   Reply With Quote
Old 07-06-2008, 09:38 AM   #6
bcblues
Member#: 17256
18 Outback
on the road....
With everything connected properly, what does it say in the lower right part of the EcuFlash screen? Is EcuFlash interfacing with the ECU?
bcblues is offline   Reply With Quote
Old 07-06-2008, 03:48 PM   #7
SurfGuruJeff
Member#: 148974
2010 4x4 Silverado
Thank you so much! I found it... I had looked for it before, but a lot of the resources for instruction on how to do it don't say that there is for sure two connectors, and none of the directions say where the second set of connectors is (I had actually taken a peak under the glovebox to find the second set of connectors, but didn't realize it was under the plastic.)
Thanks!
Old 07-06-2008, 03:55 PM   #8
tekfoc
Member#: 21392
2016 C63S AMG MB
Thanks!
my pleasure .
It's always the most stupid thing that turns out to be the problem.
good luck with the tune
Ecuflash won't read rom, but will write..help. scoobystas Open Source Reflashes 9 07-01-2009 04:31 PM
Romraider logging v.785 settings AmeenR Open Source Reflashes 5 03-20-2008 03:39 PM
Best Location for a LC-1 WBO2 Sensor for RomRaider Logging? williaty Open Source Reflashes 16 03-10-2008 10:46 AM
'04 Check engine light but scanner won't read? drdome99 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 01-29-2006 03:56 PM
CEL just came on (and stayed on), but AccessPort won't read it? ImportVenom Engine Management & Tuning 6 10-18-2004 07:17 PM
