Welcome to the North American Subaru Impreza Owners Club Wednesday March 20, 2019
Old 07-10-2008, 12:25 AM   #1
02RexWI
Member#: 165141
Default CEL, and Boost Cut Elimination??
I am hung over whether to purchase the accessport, or to go with romraider, and get a protune. I need to know if it is possible to eliminate CEL's from coming on with freeware software such as romraider, such as low catalyst efficiency. Also on that note, is their a way to get rid of the boost cut @ 130 MPH with that software as well?
02RexWI is offline   Reply With Quote
Old 07-10-2008, 09:18 AM   #2
BuddyWRX
Member#: 176661
HINT: Download the OS software and play round with some maps.... it's free / educational, so why not?
Yes, the OS editing software allows you to enable/disable CEL trouble codes from poping up.
BuddyWRX is offline   Reply With Quote
Old 07-10-2008, 10:33 AM   #3
WeldingHank
Member#: 98645
2002 WRX Wagon
you are also allowed to removed boost and fuel cuts. but you shouldn't move them too far.
WeldingHank is offline   Reply With Quote
Old 07-10-2008, 02:15 PM   #4
02RexWI
Member#: 165141
Do all the programs allow that, I was gonna go with romraider, or do you guys have one you recommend?
Old 07-10-2008, 03:38 PM   #5
benw
Member#: 103320
1998 swapped
Forester L
RomRaider is a map editor and logger.
EcuFlash will flash a map to the ECU, it is also a map editor.
You should have these two utilities minimum. There are some other extras that you can find on the RomRaider site which help. Namely, the Learning View tool, Airboy's spreadsheet, and DataLogLab (excellent log analysis suite).
benw is offline   Reply With Quote
Old 07-10-2008, 04:25 PM   #6
nhat
Member#: 140163
03 STi
hellaflunctional
130mph?
if you want to use romraider yourself, you need a wbo2 to do anything safely.
Old 07-10-2008, 05:58 PM   #7
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
^^ thats not exactly true....you can change the boost and timing, just dont mess with the fuel without a wideband. The stock maps are pretty rich from what i've seen...
Anyone using dataloglab? From the screenshots it looks like a prettier version of airboys spreadsheet.....is there anything DLL can do that airboys sheet wont?
Old 07-10-2008, 07:59 PM   #8
02RexWI
Member#: 165141
I was planning on getting the innovate LM1 for a wideband, but i'm not gonna start editing maps for my car until I read up on tuning a bit first, I'm a mechanic so I understand what's going on with timing, boost, and fuel maps, but I dont have the first clue on what I need to monitor, and what to change how much to improve the maps I edit.
Old 07-10-2008, 08:56 PM   #9
WeldingHank
Member#: 98645
2002 WRX Wagon
get an LC-1, its cheaper and not so huge.
Old 07-10-2008, 10:48 PM   #10
eminehart
Member#: 11205
2015 WRX
I was thinking the same thing when I bought my LC-1. But now i'm getting a LM-1 to tune other peoples cars. I still like my lc-1 and It's all set up for me but the LM-1 can be easily moved from car to car. It depends on your goals.
Lc-1 is great for a permanent install.
Can't go wrong with innovate, some other widebands on the market don't really go quite rich enough for our cars.
eminehart is offline   Reply With Quote
Old 07-11-2008, 12:04 AM   #11
nhat
Member#: 140163
03 STi
hellaflunctional
very true ron.
$40 for DLL?
Old 07-11-2008, 06:30 PM   #12
Airboy
Member#: 72829
2006 WRX
2015 WRX
I bought a second LC-1 and made it "portable" by adding a cigarette lighter cord to power it.
Airboy is offline   Reply With Quote
Old 07-11-2008, 10:35 PM   #13
02RexWI
Member#: 165141
That sounds like a much better option than dropping the extra cash on the LM-1.
On another note, do any of you guys have any suggestions on whether or not to purchase this map, I wasn't planning on using the launch control, but it is perfect for my setup I have right now.
hydra and boost cut???? majunche66 Other Engine Management 4 05-01-2009 08:51 AM
CEL and engine cut off anotherfiz General Community 11 07-12-2007 07:11 PM
CEL and boost 5spdfrk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 10-14-2004 01:28 PM
Hitting Fuel Cut and Boost cut at 18 PSi HELP!! ChrisV-FL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-11-2002 10:36 AM
Help!SAFC and Boost Cut Defender !! trustz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-20-2002 07:39 PM
