Welcome to the North American Subaru Impreza Owners Club Wednesday July 17, 2019
Old 07-18-2008, 06:31 PM   #1
Superorb
Member#: 135252
2002 WRX Wagon
Default Herky Jerkiness
From 1000-3500 rpms the car is VERY jerky to the point it looks like I can't drive. What could be a possible cause that I can start checking? Fuel filter changed 20k miles ago, plus changed and gapped 15k miles ago, problem started roughly 10k miles ago.
Running XPT Extreme Stg 2 GM BCS map (the one you pay for).
Also have a non-firing condition: http://forums.nasioc.com/forums/show....php?t=1559402
Superorb is offline   Reply With Quote
Old 07-18-2008, 06:35 PM   #2
SedonaScooby
Member#: 143522
1987 Brat GL 4 Speed
98 Forester L (RIP)
I kinda have the same problem sometimes where it feels like the clutch is grabbing and slippin and then grabbing during 1k rpm to about 2.5k rpm.
i think its cuz i have a stock clutch and flywheel and need it replaced....so it could be a clutch slip if you know what it feels like, unless your talking like the engine is the problem and not a transmission feel like i have.
SedonaScooby is offline   Reply With Quote
Old 07-18-2008, 08:29 PM   #3
Superorb
Member#: 135252
2002 WRX Wagon
This has nothing to do with the clutch or transmission. It's an RPM-related thing, not a gear-dependent thing.
It does it really bad in 1st gear, less bad in 2nd gear, and hardly in 3rd gear, but ALWAYS at that RPM.
Old 07-18-2008, 08:39 PM   #4
nhat
Member#: 140163
03 STi
hellaflunctional
it sounds like you might have a pre-turbo intake leak.
have you tried using the maf tool? or logging a/f learning and a/f correction?
Old 07-18-2008, 08:46 PM   #5
Superorb
Member#: 135252
2002 WRX Wagon
I'm not familiar with any of that. Could you explain please?
Is this kinda jerky, or really jerky, or not jerky at all? Sharkbait Off-Topic 51 11-11-2008 04:30 PM
Rough idle, herky-jerky take-off poison Normally Aspirated Powertrain 18 08-08-2008 12:24 AM
Herky Jerkiness Superorb Service & Maintenance 6 07-21-2008 06:39 PM
new txs firmware to cure crossover herky jerk? TexRex2002 Engine Management & Tuning 3 10-13-2005 03:08 PM
Herky jerky acceleration with unichip? Fubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 01-20-2002 03:29 PM
