Welcome to the North American Subaru Impreza Owners Club Saturday July 20, 2019
Old 07-18-2008, 08:48 PM   #1
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Default Open Loop to Closed Loop Transition
I've been paying a lot of attention lately to my AFR Gauge and it seems to take a long time for my car (02 WRX 16bit ECU) to get back to closed loop after a shift or just releasing the throttle out to 5-30% from 40-50%.
Seems to take my car 5-10 seconds to get back to 14.7:1.
Anyone know if the Closed Loop to Open loop tables also apply in reverse when going from Open to Closed?
Thanks
Ron
Old 07-18-2008, 09:10 PM   #2
Tea cups
Member#: 103136
This is explained in the sticky at the romraider site.
Tea cups is offline   Reply With Quote
Old 07-19-2008, 12:36 AM   #3
Phatron
Member#: 36033
CEO PhatBottiTuning
link....i found tons of closed to open loop threads...but not open to closed
Old 07-19-2008, 08:38 AM   #4
Tea cups
Member#: 103136
http://www.romraider.com/forum/topic1603.html
When throttle and load are both below the tables' thresholds (hysteresis) then the counter is reset to zero and you potentially enter closed loop, again, depending on the primary fuel enrichment.
However, post up some logs on the romraider site (including the cl\ol status, load, rpm, TPS and your fuel map, delays, and cl to ol throttle and cal load maps (if non-zero delays)).
Old 07-19-2008, 03:56 PM   #5
MasterKwan
Member#: 98961
2003 WRX
Mine seems to go from open to closed loop in under 1/2 second when I let off the gas.
You should run the learning view tool from Romraider and see what your fuel trims are. Maybe your MAF or injector scale is wrong so, it's having to add or remove alot of fuel to hit 14.7
Old 07-19-2008, 04:49 PM   #6
Phatron
Member#: 36033
CEO PhatBottiTuning
i dont think thats it. I think its because my turbo inlet hose is off the turbo lip so i am sucking in unmetered air, but it seems like that should make me lean....who knows. I have an APS inlet and TGV deletes going on soon, i was just curious as to how the transition back to closed loop was calculated by the ECU.
Code:
A	B	C	D
-0.1	-1.07	-1.27	0
0	-1.07	-1.27	0
0	-1.07	-1.27	0
0	-1.07	-1.27	0
Open loop to closed loop hiccup. biggreen96 Engine Management & Tuning 2 12-19-2007 01:30 AM
open loop or closed loop fueling for auto? WRXout Engine Management & Tuning 2 06-21-2004 04:12 PM
open loop vs. closed loop Mancini Normally Aspirated with bolt-on Forced Induction Powertrain 24 09-25-2003 11:55 PM
Open Loop vs Closed Loop UTEC boost map. Example? mav1c Engine Management & Tuning 3 02-01-2003 10:58 PM
open loop VS closed loop iloveturbos Newbies & FAQs 4 11-12-2002 07:33 PM
