Welcome to the North American Subaru Impreza Owners Club Wednesday March 20, 2019
Old 02-14-2019, 04:09 PM   #1476
the_unknown
Member#: 168211
2013 Cargobob
Originally Posted by IceWilly View Post
Damn I'm jealous of a powdercoating setup at a makerspace. That'd be sweet. None around me have one, but one of them does have grit blasting which would be cool as well.
The one near me is really cool. They have a Tormach 4 Axis CNC, so I'm thinking about making my own custom billet adjustable A arms and steering knuckles that have a shorter turning radius. Also, they have a full working metal shop with lathes, welders, etc...
the_unknown is offline   Reply With Quote
Old 02-19-2019, 11:34 AM   #1477
MrSaabaru
Member#: 74709
2007 Solstice
2006 Saab 9-3 Aero
I just shamelessly hit up a work contact for some LED headlights, . I want a set, but don't think I'll have a few hundred dollars for them anytime soon. It's not that high on my list of upgrades.
MrSaabaru is offline   Reply With Quote
Old 02-20-2019, 12:46 AM   #1478
chapstien
Member#: 68284
1988 GMC Sonoma
0-points
Project: bike truck with a place to change and sleep.
99 Sonoma, 2.2l, 4l60e, 2wd, 6' bed
I got it from my neighbor last summer for $500. It started and did not have reverse. He had a bad experience with a transmission change (seems like he bought a bad transmission used) so it was last registered in 2013. 93K. I had him change the oil before turning the key.
I don't know a lot about transmissions, but I learned for this one if it's not going in reverse, it's internal pretty regularly. It sat there while I spent my budget on broken bike frames and parts.
I was going to get a used/rebuilt one, then decided not to shade tree a transmission on to my chest and found a guy that rebuilt and installed. When I got quotes, most of the shops I called said they had a 3-year warranty, and this guy said 1-year. He, and all the other guys, sell 3rd party warranties, he sells the separately. In fact, he didn't even try to sell me one, I asked him about the brochures I had been stating at, and said he sells 2 and 3-year ones if I really wanted one. His price was almost 3/4 of the others. He must have but in a shift kit because 1-2 shifts are crisp, for lack of a better term.
I had the interior detailed because it was more filthy that I wanted to mess with, unbelievable.
I couldn't live with the wheels. the pattern (4.75 x 5) limits the choices, American Racing and Pacer both have steel wheel more suited to me. Add a set of General Grabber AT2's, 225 x 70. I kept them at 15" so I could have a taller profile for mud and snow, and keep the original diameter to not need more torque to turn them. I found a site that has the diameter of a lot of tires in various sizes listed so I could get withing 0.25"
Coming items:
A bed and tailgate mat. I'll apply bedliner or something to the inside bed walls.
Paint the grille black. The center is cracked, and I would rather have a mesh or billet.
1UP hitch mount bike rack, black.
And the big one, ARE commercial 36" canopy with a single rear door with a window. One side will have a solid door and a tool box, the other a sliding window, and the front window slides. Fully lined with a headliner material, aluminum can get condensation. I need to see it I can to that to save a chunk, and use a more insulating material. That's why I don't need complete bedliner, and I wanted a thicker mat. I would probably line the bed walls with the same material.
There is a common mod to put on Explorer front brakes.
For sleeping, I am thinking about one of those cot-like things that climbers use on cliff walls, which would move out of the way really well.
chapstien is offline   Reply With Quote
Old 02-20-2019, 03:12 AM   #1479
lag
Member#: 34631
I put liner in my old truck mostly just for preservation. I think if I used it a lot I'd still get a mat since the liner material likes to put its mark on everything that's at all soft. Just one less thing to do. I'd experiment with a small amount of headliner if getting normal/generic stuff if you're using it anywhere that's not a sealed cabin. Mold and smells at best like to collect in it from my limited experience.
Looking good. Auto Trannies are easy to replace but weigh a good deal more than manuals. No way I'd shade tree it alone. Manuals... too many.
lag is offline   Reply With Quote
Old 02-20-2019, 09:51 AM   #1480
MrSaabaru
Member#: 74709
2007 Solstice
2006 Saab 9-3 Aero
I got my axle out.
I have a bolt that sheared off inside the bell, the bolt that held the driveshaft coupler. I have been trying to drill it out, left handed threads, no progress made. Any suggestions are much appreciated. It's an 8mm bolt, probably about 25mm long, and inset into the hole by about 3 or 4mm. My drill bit just isn't getting any purchase.
As for the axle, I'm going to do the disc brake conversion while it's out, and I have to relocate the two things circled in this picture. The lower one is the shock mount, and the upper one is the leaf spring mount. I'm going leaf under, so those need to be flipped.
Is a good idea doing the following:
1. use an angle grinder to remove the two pieces, careful to keep them in a condition where they can be mounted.
2. Use wire wheels on my drill to clean rust off all parts.
3. Weld leaf spring mount and shock mount in new locations.
4. Paint with black anti corrosion stuff.
5. Reinstall
So does that sound good? Any advice is much appreciated. I'm already farther in this than I've been on anything in a long time.
Old 02-20-2019, 10:07 AM   #1481
VpointVick
Member#: 93193
'03 325iT
Mysticblau
Cut off with angle grinder, not torch, and if anything sacrifice the perches and shock mounts, make sure not to cut into the axle tube. Replacement perches and mounts can be bought inexpensively.
perches
Shock mounts
You really want to minimize the amount of heat that you put into the axle tubes as they can distort if not welded on a fixture and even a little bit of axle misalignment can lock up your differential and cause wear.
VpointVick is offline   Reply With Quote
Old 02-20-2019, 10:11 AM   #1482
Georgethefierce
Member#: 41713
. sprayfinishing
supplies.com
perches
Shock mounts
^^ this 100%
Georgethefierce is offline   Reply With Quote
Old 02-20-2019, 10:36 AM   #1483
AWDspider
Member#: 43748
I'm basically turning my zr2 into a pre-runner/crawler. 16" stroke 3" triple bypass Kings going in the rear, deaver spring under with new shackles. 3" double bypass 14" stroke Kings going on the front with custom long travel. New turbo setup with new connecting rods and pistons. Upgrades to the transmission to handle the torque increase. The goal is 300whp and 550-600wtq. Will be running 35" tires, extended fenders .
The pics below are early pics of the bumpers. The truck is being built down in Houston (I'm in Dallas). I try not to bug the builder too much so I don't have many pics. I know the rear suspension should be going on this week and the front upper/lowers arms should be finished this week and then we will order the front coilovers.
AWDspider is offline   Reply With Quote
Old 02-20-2019, 10:50 AM   #1484
lag
Member#: 34631
Something more serious than a wirewheel may be needed for the areas you're welding. Nothing dramatic and wirewheel may be fine but just take a lot of time for the rust on the axle.
Angle is important... set it for your perches before final welding. *for total pinion angle
Verify how the tubes are held into the pumpkin. How they're in there may give you more fudge room. Welded in = very little room. Pressed/held in with pins of some sort = more fudge room and ability to maybe fix things if they get out of sorts.
It would be hard to put enough heat in the axle to warp it welding on perches, tabs, whatever but total possible. Heating the tubes is advisable at times just before welding.
Fun fact... racers with live axles will bend them to get negative camber, if they want more negative camber.
Fact: Negative camber used to be what you did not want in your suspension.
@ AWDspider
How did you like the truck from factory? I'm happy as hell we're getting other than full sized trucks again.
Old 02-20-2019, 11:33 AM   #1485
tobylazur
Member#: 150289
2006 SV650, 05 CTSV
1972 Travelall
Coming items:
Man, it's amazing what a little elbow grease and few small changes can make. The truck looks great now!
Have you considered a camper shell on the bed then just sleeping on an air mattress in the bed?
tobylazur is offline   Reply With Quote
Old 02-20-2019, 11:39 AM   #1486
AWDspider
Member#: 43748
Originally Posted by lag View Post
@ AWDspider
Absolutely love the truck. I traded my 2017 taco TRD off-road for it. Hated that truck. The zr2 is the first vehicle I have paid off and have kept more than 30k miles and Ive had many many vehicles. At the time of the truck going off to my builder ive got 37k miles, I use it for work at times pulling anywhere from 2k-~5k pounds. I've pulled my RV several times (6500lbs), done a ton of offroading and my lifetime avg mpg (hand calculated) is 22.7mpg. on a road trip on relatively flat ground I would average 26-28mpg at 70mph.
The stock suspension is nice and handles great, works better when you remove the sway bar, however I want more hence the reason for the build. I've only had one issue and that was loose tie rod sleeve that i caused by too much skinny pedal on a hard trail. Dealer covered it under warranty.
My only complaints, they are small, is that for this kind of money it should have heated mirrors, smart key entry and push start and a locking tail gate. YMMV though
Old 02-20-2019, 11:40 AM   #1487
MrSaabaru
Member#: 74709
2007 Solstice
2006 Saab 9-3 Aero
Thanks for all the input. I don't really understand what lag is saying in the part I bolded. Are you talking about fixing any warping due to welding heat, or are you talking about fixing any errors in the mounting of the perches?
Old 02-20-2019, 12:42 PM   #1488
lag
Member#: 34631
My only complaints...
I have a good buddy I somewhat trust with auto opinions but he's a little over the top. He had a ~2009 Tundra, loved it. He bought it to do house projects and sold the truck after he was done with the house stuff. Hated not having it... got a tacoma and did a lot of the stuff Chappy is looking to do. I camp with him and was a little jealous of the mood lighting in the bed but I'm not single enough to double bunk. He moved so got rid of the tacoma. He liked it but not enough to get another one but did buy a much older one which says a lot to me. He was happy with the newer one but didn't find anything about the current one worth a real look again. Not sure if he looked at the current GMC/Chevy options though.
Random Axles:
Almost sure this is a ford 8.8. Pinned tubes. The weld you see is a modification, not from factory. They're just pinned in as standard. Pull the pin pull the tube.
this one says Moser but didn't give any other info. Fully welded tube. It doesn't seem common to have a fully welded tube from factory on a mass produced vehicle but I don't have all of the stats.
This should be another ford but not sure which one. I'd guess 7.5" but have no emotion behind being wrong on any of that. Looks normally pinned as normally seen from factory.
If the tubes are pinned there's a lot of flex in them anyway. Distortion is a concern but you'll unlikely distort the axle outside of factory spec if the tubes are pinned in.
If the tubes are welded there's little deviation that can happen before the binding vpoint mentioned.
The pinion angle is more of a no option but right.
This can be source of vibration and u-joint failures if not correct.
I couldn't/didn't find specs on your specific axle.
Old 02-20-2019, 01:40 PM   #1489
SilverFleet
Member#: 91941
2012 Mazda 3
'79 Trans Am WS6
Spent some time fixing stupid crap on my Power Wagon over the weekend. To get an inspection sticker, I need lights, a horn, non-leaky exhaust, and to fix the P/S seatbelt floor mount. I started with the horn, because it was the easiest to knock off the list.
The old horn wiring consisted of a bunch of these household wire nuts holding corroded wires together, and even some bare wires wrapped around each other. No wonder why it was not working. Turns out that was just part of it; both horns were completely dead. I remembered I had a pair of truck horns I snagged for a former vehicle in my parts stash, so I mounted them up, cleaned up that terrible wiring, and things went TOOT TOOT!
As an added bonus, I decided to replace the crumbly negative battery cable and the ground to the core support. This not only made the truck 100x easier to crank over, but the core support ground seemed to be the key in getting all my headlights working! BONUS!!!
I love this truck so far. It's so goddamn simple to work on.
SilverFleet is offline   Reply With Quote
Old 02-20-2019, 02:32 PM   #1490
Benhart21
Member#: 149617
Every time I see a ZR2 it makes me want one again. I'm just having a hard time finding a diesel below $40k, and even the used ones with 35k miles on them are still at least $37k and usually either in the rust belt or on the east coast 1500 miles away. Doesn't help I've dropped more on my nearly 20 year old 4Runner with new wheels/tires, new double DIN head unit, front and rear bumpers with a tire carrier on the back, a new set of King 2.5" coilovers, and a new steering rack going in shortly.
Benhart21 is offline   Reply With Quote
Old 02-20-2019, 03:28 PM   #1491
MrSaabaru
Member#: 74709
2007 Solstice
2006 Saab 9-3 Aero
perches
Shock mounts
Sorry again, and I really appreciate the assist. If I bought the shock mount there in your link, does that mean I can get a shock that mounts through those holes, instead of trying to find a shock that mounts to the welded threads on the mount I have (see picture)?
I already have to get a custom shock because of the relocation.
Old 02-20-2019, 03:33 PM   #1492
VpointVick
Member#: 93193
'03 325iT
Mysticblau
You can go either way. Here is a stud mount one.
Old 02-20-2019, 03:33 PM   #1493
Hondaslayer
Member#: 4562
2014 Electric Datsun
2005 Adventure van
Man,
We got a used one traded in. Super low miles (under 10k IIRC). One of our techs snagged it before it was even given an inspection. I believe he got it ~ 25k.
Old 02-20-2019, 03:35 PM   #1494
MrSaabaru
Member#: 74709
2007 Solstice
2006 Saab 9-3 Aero
Huh. How bout that.
I feel kinda stupid with how fast you found those.
Old 02-20-2019, 03:42 PM   #1495
VpointVick
Member#: 93193
'03 325iT
Mysticblau
Huh. How bout that.
I'm no master, but my Google fu is pretty good.
I think that you'll likely want to stay with the studded mount as it will allow you to keep the shocks in more of a transverse mounting arrangement. The eyelet type will require the shocks to be more fore/aft.
Old 02-20-2019, 03:47 PM   #1496
MrSaabaru
Member#: 74709
2007 Solstice
2006 Saab 9-3 Aero
I'm wondering if I should even worry about trying to save the ones on the axle already. I can't imagine not damaging the pieces when it's a rounded surface, when using an angle grinder, and putting emphasis on protecting the axle.
I'm also getting worried about welding. I've never welded before. I have some scrap I've gathered to practice on, but I have absolutely no idea what i'm doing.
Old 02-20-2019, 03:47 PM   #1497
lag
Member#: 34631
Originally Posted by SilverFleet View Post
nioce
"when in doubt, add grounds"
dad would say "clean your ****ing corroded cables or I'm taking your **** away the next time you ask why it's not starting."
"why not both"
Seeming one of the most forgotten parts not replaced in engine replacements. Ground straps.
Vpoint is dead on, there's no reason to reuse the mounts you're cutting off. Too much planning start and finish for a questionable part in the end.
Old 02-20-2019, 03:49 PM   #1498
Georgethefierce
Member#: 41713
. sprayfinishing
supplies.com
something as superficial as shock mounts are definitely a great first time welding project!
Old 02-20-2019, 03:52 PM   #1499
totallynotbeau
Member#: 387569
1968 Abomination
Mudstang
Does this stuff really rust out and fall apart almost immediately?
Flexible exhaust pipe:
https://www.summitracing.com/parts/w...+5ba2a4ce14c40
Ah screw it, it's going on the Gambler so crappy is cool. I'm contemplating a pretty damn crazy exhaust setup for the Mudstang, stay tuned.
totallynotbeau is offline   Reply With Quote
Old 02-20-2019, 03:55 PM   #1500
Hondaslayer
Member#: 4562
2005 Adventure van
Not quite.
I used it on an old Samurai back in MI. Made it through a winter before it came off in a swamp.
I would not use it for anything long term, but to get things in place and maybe test afew mufflers out for a few weeks? Hell yeah.
