Welcome to the North American Subaru Impreza Owners Club Saturday March 23, 2019
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Old 01-02-2017, 12:37 PM   #1
Depo Racing
Vendor Sales Rating: (0)
Member#: 304236
Default FA20F Parts: J-pipe $199.99-TopMount $329.99-Intake $179.99-Charge pipe $129.99
Fair prices on the best main tuning parts for the 2.0t
Catless Jpipe set $199.99
Hi Flow Cat Jpipe set $279.99
Intake K&N $179.99
Top mount Intercooler Largest Made $329.99
Charge pipe 129.99
http://www.deporacing.us
__________________
Depo Racing is offline   Reply With Quote
Old 01-02-2017, 12:41 PM   #2
Depo Racing
Member#: 304236
Default FA20F Intake kit $179.99
Depo Racing 2015 2016 2017 WRX 2.0t Intake Kit K&N filter
This is the most well thought out intake design, simple not an overly long pipe,
– 3″ OEM grade (2mm) Aluminum Intake pipe
– Perfect fitment and tight seal
– K&N RU-4960 Filter included (retail $65.00)
– Comes with all Hardware
– Heat Shield Included
– 9 plus HP gain
http://www.deporacing.us/shop/subaru...16-wrx-intake/
I don't check the forums often email me for fastest response [email protected]
__________________
Old 01-02-2017, 12:57 PM   #3
Depo Racing
Member#: 304236
Default FA20 Charge Pipe $149.99
Depo Intercooler Charge Pipe Kit is a free-flowing, mandrel-bent aluminum tube designed to replace the restrictive soft factory intercooler piping. The charge pipe has been engineered to reduce turbo charged air pressure loss as well as dramatically increase air flow from the turbo to the intercooler. The intercooler piping is constructed from lightweight aluminum with a durable black finish. . The charge pipe kit is easy to install.
Estimated Horsepower Gain 13 HP @ 3750 RPM
Black 2.25 - 2.75″ Diameter
Material Used Aluminum
T Bolts and Couplers included
A recirculation kit can be made for $10.00 consisting of 2x 1" elbows and 2 feet of 1" hose. Not Rocket Science , many of my customers have done this, with a trip to the local auto parts store.
__________________
Old 01-02-2017, 01:26 PM   #4
Depo Racing
Member#: 304236
Default FA20F Topmount Intercooler $349.99
Depo Racing Top Mount Intercooler for the 2015+ Subaru WRX 2.0t is a "Mini Mammoth" direct bolt-on replacement intercooler designed to drastically increase intake air cooling capability and horsepower over the smaller stock intercooler.
Depo Racing intercoolers (and parts) have always had a price point that may leave some scratching there heads. I only sell direct to the customer, no dealer commission, overseas labor is cheaper and lastly I don't price gouge.
I dont build intercoolers to be cheap alternatives. I build them to be as good or better then the best made. I build them for performance gains and to cool intake temps, I dont polish them, I have perfect internal fin density. Internal fins grab the heat and transfer it to the external fins. External fins are serrated to release heat as fast as possible. The fins are also made of the correct material grade to be thin enough to cool quickly as air passes through. Depo Intercoolers are often compared to the cheaper brands like CX or Mishimoto because the prices are similar, Evo X, Focus ST and Gencoupe turbo drivers know the performance difference.
-Pressure tested to 40 psi
-110% more internal flow space than stock and is the largest available top -mount for the 2015 WRX
-13.2 x 10 x 4 inch core
-Cast Aluminum End Tanks
-Bar and Plate Core
-Aluminum Mounting Brackets
-Fits with OEM Charge Pipe
-Fits with OEM Engine Cover (Minor Trimming Required)
-Direct OEM Replacement with all Hardware Included
http://www.deporacing.us/product-category/subaru/
“MY 3.5″INTERCOOLER is on the fastest pump gas EVO X in the WORLD ” member Darksun280 evoxforums.com [email protected] Darksun280, same core
__________________
Old 01-04-2017, 12:12 PM   #5
raven1231
Member#: 427206
2016 WRX
Glad to see you on here finally! I know Adam and I are loving your parts! If anyone is looking for a very affordable intercooler that absolutely performs, pick one of these up!
The quality is top notch, fitment is spot on, and the price is unbeatable!
raven1231 is offline   Reply With Quote
Old 01-04-2017, 12:13 PM   #6
raven1231
Member#: 427206
2016 WRX
Great product and it only take about an hour to install. I noticed immediately boost coming on sooner. It really makes that car almost seem lighter. Pipe is light, well made, and fitment was great!
Old 01-04-2017, 12:17 PM   #7
raven1231
Member#: 427206
2016 WRX
– 9 plus HP gain
If you're looking for the BOV sound/want to hear your turbo better this is the product to get. The K&N filter is a very nice added touch. The map sensor flange is straight with zero issues, installs in under and hour, and it came with all the hardware that is needed. I have been running this, the charge pipe, and intercooler and have been extremely satisfied. For the price these products cannot be beaten, I'm confident they will perform as well as or better than the competition. As soon as I get the funds my car will be heading to TIC for a dyno tune.
Old 01-04-2017, 12:18 PM   #8
raven1231
Member#: 427206
2016 WRX
Can't wait to pick one of these up! It's the last part I need before I can finally get my car all dialed in via dyno tune at TIC!
Old 01-06-2017, 05:42 PM   #9
Depo Racing
Member#: 304236
thanks
__________________
Old 01-06-2017, 05:43 PM   #10
Depo Racing
Member#: 304236
__________________
Old 01-06-2017, 05:43 PM   #11
Depo Racing
Member#: 304236
__________________
Old 01-06-2017, 05:44 PM   #12
Depo Racing
Member#: 304236
thanks
__________________
Old 01-09-2017, 08:54 PM   #13
raven1231
Member#: 427206
2016 WRX
On its way!
Old 01-13-2017, 06:00 PM   #14
Depo Racing
Member#: 304236
__________________
Old 01-13-2017, 06:00 PM   #15
Depo Racing
Member#: 304236
__________________
Old 01-13-2017, 06:00 PM   #16
Depo Racing
Member#: 304236
__________________
Old 01-13-2017, 06:01 PM   #17
Depo Racing
Member#: 304236
__________________
Old 01-19-2017, 05:56 PM   #18
Depo Racing
Member#: 304236
__________________
Old 01-19-2017, 05:57 PM   #19
Depo Racing
Member#: 304236
__________________
Old 01-19-2017, 05:57 PM   #20
Depo Racing
Member#: 304236
__________________
Old 01-19-2017, 05:57 PM   #21
Depo Racing
Member#: 304236
__________________
Old 01-26-2017, 12:54 PM   #22
Depo Racing
Member#: 304236
__________________
Old 01-26-2017, 12:54 PM   #23
Depo Racing
Member#: 304236
__________________
Old 01-26-2017, 12:54 PM   #24
Depo Racing
Member#: 304236
__________________
Old 01-26-2017, 12:55 PM   #25
Depo Racing
Member#: 304236
__________________
