Welcome to the North American Subaru Impreza Owners Club Monday March 18, 2019
Old 02-06-2019, 01:59 AM   #1
Fl4t_Matt
Member#: 485592
2005 WRX
Default Weird WOT stutter
So on my 05 wrx I have basically everything you can bolt into it with the exception of an fmic, tgv deletes, cai, ported manifold, 800cc injectors, full exhaust from headers up and back, etc. however I am having a weird tuning issue. I have a solid 14.7 idle afr that may fluctuate to 15.3 at worst but at WOT it drops to around an 8.53 and seems to cut fuel as if to stop the car from hitting peak boost. I have no leaks in my intake system but as I am on e85 with large injectors I had to scale my fueling accordingly to suit the mods. Car runs like a dream just cruising around and can chuck flames all day long but the second it tries to hit full boost (16.4 psi I believe) it stops itself and almost sounds like rolling anti lag. Any ideas what this could be? I do not believe anything is faulty mechanically however it is possible, I am leaning more toward the tune itself and something not being correct. Any help from some similar odd situations would be greatly appreciated!
Fl4t_Matt is offline   Reply With Quote
Old 02-06-2019, 02:04 AM   #2
Fl4t_Matt
Member#: 485592
2005 WRX
Just to clarify I donít have an fmic but I have the rest listed
Old 02-06-2019, 11:17 PM   #3
SkateAndDestroy
Member#: 133893
2011 BMW 328i Xdrive
EJ255 02 WRX Wagon PSM
Did you tune it yourself? Can you post a datalog?
SkateAndDestroy is offline   Reply With Quote
Old 02-13-2019, 01:56 PM   #4
snobordboi
Member#: 149130
2002 WRB WRX
VF39 Brembos etc
Is this just in higher gears, or all the time? Sounds like wastegate duty cycle to me.
snobordboi is offline   Reply With Quote
Old 02-16-2019, 12:40 AM   #5
Krazie99
Member#: 497845
I had some issues and replacing the spark plugs seemed to help mine to be honest.
Krazie99 is offline   Reply With Quote
Old 02-18-2019, 04:46 PM   #6
car_freak85
Member#: 13530
EA63 , EA81T, EJ20G,
EJ205
Pull a spark plug and check the gap. Should be around 0.028
car_freak85 is offline   Reply With Quote
