Welcome to the North American Subaru Impreza Owners Club Monday March 25, 2019
Old 02-16-2019, 12:45 AM   #1
Krazie99
Member#: 497845
Default Strange rattling front passenger side 02 wrx
So this recently started to happen, there seems to be some rattle sound, not like heat shield more like a knocking rattle. From passenger front side, no not transmission or engine. I think itís suspension related. Everything is right nothing is loose. I was leaning towards bad strut or bad strut mount? Could that make a rattle sound?
Itís loudest when car is NOT warmed up. When it gets warm itís not as noticeable
If I drive soft it doesnít make any sound.
Itís only when I get on it a bit it starts to rattle. It only happens when moving, and accelerating.
Any ideas?
Krazie99 is offline   Reply With Quote
Old 02-16-2019, 07:55 AM   #2
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 VF48 6sp RA
Sounds like the up pipe heat shield may be the issue.
D-Rodman is offline   Reply With Quote
Old 02-16-2019, 10:06 AM   #3
Foo_Blyat
Member#: 93750
Check for a broken end link on your front sway bar
Foo_Blyat is offline   Reply With Quote
Old 02-16-2019, 10:25 AM   #4
Krazie99
Member#: 497845
I have replaced the end links with Perrin ones. All those bolts are still tight. My sway bar seems fine also?
Old 02-16-2019, 10:25 AM   #5
Krazie99
Member#: 497845
I have removed my up pipe heat shield already
Old 02-16-2019, 10:37 AM   #6
Foo_Blyat
Member#: 93750
Check the passenger side motor mount. I think it has a dinky thin heat shield on it as well that might have rusted out
Old 02-16-2019, 12:14 PM   #7
Krazie99
Member#: 497845
Iíll check it out thank you!!
Old 02-17-2019, 01:20 AM   #8
Boosted_Shoe
Member#: 497875
I second the engine mount heat sheild, had one on my forry crack and rattle ��
Boosted_Shoe is offline   Reply With Quote
Old 02-17-2019, 09:49 PM   #9
ericmillercbc
Member#: 477850
2002 WRX Wagon
I had a front pass side rattle/clunking sound on my 02 wrx wagon that I could not figure out for several months. Turned out to be the brake caliper rattling on the carrier. The rubber bushings on the caliper slides were worn away, so any rough road would cause it to rattle around and clunk.
ericmillercbc is offline   Reply With Quote
Old 02-17-2019, 11:36 PM   #10
Krazie99
Member#: 497845
Yeah mine goes away when cruising at constant speed. If Iím on free way and get on it, I canít hear it. Itís when I get on it a little city driving. Normally around higher rpms. Itís pretty loud too
Old 02-17-2019, 11:37 PM   #11
Krazie99
Member#: 497845
I got no heat shield in my up pipe, how can I tell it engine mount is bad
Old 02-17-2019, 11:50 PM   #12
Krazie99
Member#: 497845
It also makes the sound only when accelerating, not Decelerating
Old 02-18-2019, 12:17 AM   #13
Krazie99
Member#: 497845
Here is video of sound
Coming from front passenger side
https://youtu.be/MazYpAVqVfE
