Welcome to the North American Subaru Impreza Owners Club Tuesday March 26, 2019
Old 02-16-2019, 03:57 PM   #1
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 VF48 6sp RA
Default Exhaust issue
Iím looking at buying a used axleback and one of the pictures the seller sent shows what Iím concerned is rust. Seller claims discoloration is from high heat due to track use and stains are just tar from the road. What do you think ?
Thank you.
D-Rodman is offline   Reply With Quote
Old 02-19-2019, 09:34 AM   #2
Foo_Blyat
Member#: 93750
That thing can be brand new in 15 minutes
Check my post here https://forums.nasioc.com/forums/sho...&postcount=484
I restored one that was 500000000x More rusty and dirty than the one you’re interested in
EDIT: Sorry I’m an idiot and forgot to answer your questions. Yes the seller is well informed and honest, that is def road tar and heat discolation. Both can be removed/polished out
Foo_Blyat is offline   Reply With Quote
Old 02-19-2019, 11:35 AM   #3
Dadsquatch
Member#: 458140
1995 Impreza
Doesn't look bad.
Dadsquatch is offline   Reply With Quote
Old 02-19-2019, 09:23 PM   #4
TXwrxWagon
Member#: 191557
2004 WRX Wagon
WRB not so minty fresh
the seller is being honest on this one. the black spots do indeed appear to be road muck and the brown/redish stains appear to be Stainless discoloration. Rust on a stainless muffler to be concerned about would be in a deep gouge/dent/crease or at the welds.
some 000 steelwool or stainless polish and some elbow grease. better than new.
~Rob
TXwrxWagon is offline   Reply With Quote
Old 02-20-2019, 04:05 AM   #5
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Thank you gentlemen.
Old 02-20-2019, 09:10 AM   #6
bp05obxt
Member#: 459799
Make sure not to use any abrasive, when refinishing, that contains material that will oxidize and corrode later. I have seen steel wool impregnate SS and ruin an entire exhaust. I would suggest scotch brite pads
bp05obxt is offline   Reply With Quote
Old 02-20-2019, 12:10 PM   #7
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Thanks for the advice, point taken.
