Welcome to the North American Subaru Impreza Owners Club Friday March 22, 2019
Old 02-19-2019, 11:32 AM   #1
Dadsquatch
Member#: 458140
1995 Impreza
Default Replacement cam gear bolts?
Hi, yes, I have an 02 wrx. Stripped 2 cam gear 10mm hex heads. Got them out be welding axle nut bolts. Now, I do not want to put ANY of them back in. Has anyone successfully substituted back to the older regular head type bolts?
I do not want to use these $6 bolts ever again! , as I am planning on keeping this wrx for another 100k..
It seems like it would work fine...
Any input or links? I tried, but only got repair/ extraction methods..
Dadsquatch is offline   Reply With Quote
Old 02-19-2019, 12:27 PM   #2
jamal
Member#: 71875
I feel like I've heard of or seen older bolts being used but am not completely sure. Or you could use these Turn in Concepts bolts:
http://turninconcepts.com/engine/tic...-non-avcs.html
jamal is offline   Reply With Quote
Old 02-19-2019, 12:40 PM   #3
Dadsquatch
Member#: 458140
1995 Impreza
Right on Jamal! That's all I needed to see. I'm hoping I can find something close at my local fastenall later today.
