Welcome to the North American Subaru Impreza Owners Club Wednesday March 20, 2019
Old 02-19-2019, 09:23 PM   #1
bigchoppers2003
Member#: 487654
Default Help my car is sick
I have an 03 WRX wagon with I stage 1 2.5L hybrid. I just did injector Dynamics 1050x injectors, an aem 320 fuel pump and got a base map for that plus a 20 g turbo with catless exhaust. Now when I start the car it will rev up and die, if I don't bump the gas to keep it going. Thanks in advance for the help.
bigchoppers2003 is offline   Reply With Quote
Old 02-20-2019, 08:50 PM   #2
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
Is this a new issue that started out of no where?
How old is the install on the fuel pump?
Do you have any smell of fuel from the car?
When was the filter last changed?
Do you have a fuel pressure gauge?...if so is it dropping? Might be a fuel pressure regulator.
Old 02-21-2019, 01:11 AM   #3
bigchoppers2003
Member#: 487654
I actually got it figured out today, it was a mistake on my part installing injectors.
Fuel pump is new, just installed
I don't know about the fuel filter
Fuel pressure past the filter is 46 psi at an idle
No smell of fuel when I made the post but did find a leak later.
Issue I had is when I installed the new id1050 injectors I pulled the adapter sleeve off the bottom, thought it was just a protector of some sort. Took me laying the new and old injectors side by side to figure out what went wrong. Put the adapter sleeve on and runs fine now.
Old Today, 02:12 AM   #4
MehLoot
Member#: 499311
Default Glad you got it!
Glad you figured it out! Yikes, also just bought some similar parts so hopefully install goes smoothly.
MehLoot is offline   Reply With Quote
