Welcome to the North American Subaru Impreza Owners Club Tuesday March 26, 2019
Old 11-21-2004, 01:55 AM   #51
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
It's not spam, but it's against this forum's terms of service so you might want to edit your post lest it be deleted. You need to be a paying Vendor to advertise here and this is an advertisement.
Old 11-21-2004, 02:11 AM   #52
DavidV
Member#: 17621
Is that better (edited)? I honestly think it is a good starting point for learning about how turbos work, turbocharged cars, etc.
I can remove my post it it bothers you that I am the one mentioning it.
-- DavidV
DavidV is offline   Reply With Quote
Old 11-21-2004, 02:18 AM   #53
DavidV
Member#: 17621
Maybe this will help explain why I think WRX folks might be interested:
"1. on Page 17:
"... Chapter 1: Cool Car Basics 17 A friendís Subaru WRX station wagon has been used many times to carry four of us plus a trunk full of supplies from Home ..."
2. on Page 104:
"... flow of air, most wings are mounted on raised pedestals, as shown in Figure 8-1. Figure 8-1: Airflow and the WRX: Why a tall wing is good. ..."
3. on Page 105:
"... the angle of the wingís plane for adjustable levels of resistance. Figure 8-2 illustrates an adjustable wing on a Subaru WRX STi, shown in two different positions. A wing needs to be bolted into the rear trunk of your car. This ..."
4. on Page 211:
"... Chapter 15: Basic Power Bolt-Ons211 Figure 15-21: WRX axle-back exhaust. Cat-back exhausts A cat-back exhaust replaces the exhaust system behind the primary catalytic converter. In many states, it ..."
5. on Page 212:
"... header) is on the right. The small piece at the front is the up-pipe, which in this application (the Subaru WRX), replaces a catalytic converter that Subaru has placed before the turbo. Most turbos do not have a cat before them. ..."
6. on Page 213:
"... working order usually can keep up with power modifications. Axle-back with muffler Down-pipe Mid-pipe (Intermediate pipe) with resonator Figure 15-23: WRX turbo-back exhaust. Up-pipe Ignitions ..."
7. on Page 241:
"... intake charge because its core is taking on heat faster than it can shed it). Some cars, like the Subaru WRX STi, spray water on the outside of the air/air intercooler. This cools it quickly and gets rid of some heat ..."
8. on Page 257:
"... the core is so much larger that you have to install it in a different location. For example, the Subaru WRX often loses its top-mount intercooler for a much larger upgraded front-mounted intercooler.  Convert to an air-to-water intercooler. ..."
9. on Page 259:
"... intercooler involves fitting a surface water sprayer, like those found as factory equipment on the Mitsubishi Lancer Evo and Subaru WRX STi. You can tap into your factory water spray reservoir and use a manual switch to trigger the water spray, ..."
10. on Page 272:
"... 272 Part VIII: Faster Thinking Figure 20-1 illustrates the factory ECU of a Subaru WRX, with the wiring harness coming off the left side of it. The ECU is responsible for continually setting and adjusting ..."
11. from Front Matter:
"... for the corners. This part guides you through making your car handle with the best. Cornering is where a Subaru WRX station wagon can be set up to pass a Porsche 911 on a twisty road. In motor sports, corners are ..."
-- DavidV
Old 01-08-2005, 01:48 AM   #54
DavidV
Member#: 17621
Grass Roots Motorsports Magazine did a write up this month:
-- DavidV
Old 07-12-2005, 10:09 PM   #55
Godfather Inc 03
Member#: 84050
Do you think that upgrading a wrx turbo witht he vf39 would be a good idea?
Godfather Inc 03 is offline   Reply With Quote
Old 07-12-2005, 10:47 PM   #56
BrianH
Bing user
Member#: 44383
Originally Posted by Godfather Inc 03
Do you think searching in the 2.0L forum for information on how the vf39 works on the wrx 2.0L is a good idea?
Why I think it's a grand idea.
BrianH is offline   Reply With Quote
Old 07-12-2005, 11:40 PM   #57
Godfather Inc 03
Member#: 84050
cool thanks
Old 07-13-2005, 12:56 PM   #58
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
You need more than just the turbo.
mbiker97 is offline   Reply With Quote
Old 07-13-2005, 01:29 PM   #59
Godfather Inc 03
Member#: 84050
what else do i need? im getting the intercooler and fuel pumps also...
Old 07-13-2005, 01:52 PM   #60
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
You need learning more honestly. Search, search, search and then search some more.
You need at a minimum:
catless uppipe
STi pink injectors
engine management
Boost and EGT gauges
a brain to not destroy your gears
You should also have:
dowpipe (catless or high flow), preferably a turbo back
fuel pump
IC hoses or different IC
custom tune
wideband O2 with readout
oil temp or pressure gauge
That's about it.
Old 07-13-2005, 02:05 PM   #61
Godfather Inc 03
Member#: 84050
awsome thanks
Old 07-13-2005, 05:52 PM   #62
Godfather Inc 03
Member#: 84050
btw what is a wideband o2 couldnt find any definitions or soemthign describing what it is....im owkring on the sti intercoole, sti upipe,i have the downpipe and fuel pump and am working on exhuast and when my mods aer done im going to do ecuteck./dyno tune sounds good???
Old 07-13-2005, 06:17 PM   #63
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Old 09-08-2005, 02:18 PM   #64
TarmacRally
Member#: 85805
... Shiny & Chrome
Witness Me!
whats the name/number of the stock turbo.
TarmacRally is offline   Reply With Quote
Old 09-08-2005, 02:25 PM   #65
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
TD04L-13T
Old 10-21-2005, 12:18 PM   #66
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Bump for updates on external wastegates that Jerry @ Deadbolt so kindly helped me with.
Old 10-22-2005, 08:36 PM   #67
JalopySiR
Member#: 39378
2004 Carless
98' VFR800Fi/02' RC-51
It is a good idea to take it easy after installing a new turbo, so you can see if the tune is good, and make sure everything is kosher. However, no break in is neccessary after installing a new turbo (aside from priming the CHRA).
JalopySiR is offline   Reply With Quote
Old 11-26-2005, 01:52 AM   #68
SixSick6
Member#: 76658
Originally Posted by DeadBolt Enterprises
A popular choice for autocross is the VF39 (yes, the STi factory turbo) It uses the F55 compressor wheel from the VF34 and a different version of the 18 exhaust housing. (I know there are lots of people saying it has a 17 housing but that is incorrect, I can take a pic if someone wants one
I'd like to see one of those pictures since I have a VF39 right in front of me and am not seeing reference to a P18 exhaust side. From what I understand, divide by 25.4 to get what Garrett calls their A/R. Unless I'm looking in the wrong place, the only letters/ numbers on the exhaust side are:
R5
E2
17
3GW
17/25.4=.66 A/R which works out the same as using a telescoping micrometer and a tape measure to caluclate A/R.
Care to elaborate?
SixSick6 is offline   Reply With Quote
Old 11-29-2005, 12:02 PM   #69
SixSick6
Member#: 76658
Yes, no, maybe so?
Old 12-26-2005, 09:49 PM   #70
SixSick6
Member#: 76658
Anyone? From everything you guys have said, the exhaust housing is a P18. Mine says P17.
Old 06-19-2006, 04:37 PM   #71
WolfPlayer
Member#: 65054
2005 STI (CGM)
Descooped / Dewinged
Sidefeed stock STI injectors are reported in this thread to be 480cc. I had all 4 of my stock injectors tested by both WitchHunter and RC Engineering.
WitchHunter results show 490-500cc.
http://www.bescaredracing.com/sti/fu...r/DSC05985.JPG
RC Engineering results show 517-524cc.
http://www.bescaredracing.com/sti/fu...ng/results.jpg
Basically, we are talking about a 25cc difference just by utilizing different companies. Also, keep in mind that if you get 1 injector flow tested then that means nothing since you could have tested either the lower flowing injector of the bunch or the higher flowing injector of the bunch. You need to have several tested. 10cc difference between my injectors.
Test the low flowing injector at WitchHunter and you get 490cc.
Test the high flowing injector at RC Engineering and you get 524cc.
It is now really easy for me to see, explain, and understand why some people said 480cc and why some people said 540cc. Lower flowing injectors vs. higher flowing injectors. One company vs. another company.
t
WolfPlayer is offline   Reply With Quote
Old 12-07-2016, 11:55 AM   #72
sluttywhale
Member#: 439860
Default newbie turbo question
so i have an 03 wrx with the following:
STI top mount intercooler
Cobb AP (stage 1 flashed)
565cc injectors (not installed)
Upgraded fuel pump (not installed)
Full Cobb exhaust
Invidia Downpipe
Got a pretty good offer on a TDO 20 g turbo and was wondering what other supporting mods I would need to run to get maximum safe potential
thanks
sluttywhale is offline   Reply With Quote
Old 02-15-2019, 10:53 AM   #73
jbama03wrx
Member#: 497472
2003 WRX
walbro 255 the next logical step up from factor wrx 03 fuel pump to accompany upgraded injectors and turbo
jbama03wrx is offline   Reply With Quote
Differential FAQ: Read if you are thinking of upgrading! Unabomber Transmission (AT/MT) & Driveline 163 02-15-2019 10:49 AM
Turbo FAQ: Read if you are thinking of upgrading! Unabomber Newbies & FAQs 226 01-28-2019 07:08 PM
Transmission FAQ: Read if you are thinking of upgrading! Unabomber Transmission (AT/MT) & Driveline 225 12-28-2018 12:44 AM
Injector, Fuel Pump, and Fuel Rail FAQ: Read if you are thinking of upgrading! Unabomber Newbies & FAQs 184 10-10-2017 03:38 PM
Turbo Timer FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 93 06-22-2017 08:29 AM
