06-27-2008, 12:39 PM | #1 |
Vendor Sales Rating: (1)
Member#: 171509
AMR - Turbo XS Delta v2.0 UTEC for 02-05/06-07 WRX & 04-07 & 08 STi
Turbo XS Delta v2.0 UTEC for 02-05/06-07 WRX & 04-07 & 08 STi Turbo XS Delta v2.0 UTEC Engine Management for WRX & STi The Turbo XS UTEC is a new concept in engine management that combines the features of a stand-alone engine management system with the simplicity of a piggyback system. The UTEC enables complete programmable control over ignition timing, fuel, and boost, while allowing the factory ECU to maintain control over basic day-to-day functions.Functions like cold start, hot start, intake temperature compensation, AC compensation and closed-loop fuel control signals are all managed by the factory ECU reducing your tuning time significantly while enhancing daily drivability. Spend more time driving and less time tuning for stock functions.UTEC Standard Features: PLUG & PLAY: Installs in minutes on top of the factory computer using all the factory connections. END-USER PROGRAMMABLE: Fine tune maps via a laptop equipped with a serial cable and Hyperterminal. PRE-PROGRAMMED BASE MAPS: Standardized maps are available for common setups (i.e. turboback exhaust, upgraded intercooler, bigger turbo & injectors, etc.) Maps can be uploaded and downloaded easily. Not currently available for the Legacy GT. 5 MAP MEMORY: 5 maps can be stored at a time, and using the remote map selector, you can quickly switch into valet mode, stock mode, nitrous, or race fuel maps with the click of a switch. FUEL, TIMING, AND BOOST ARE USER-PROGRAMMABLE: in 250rpm increments up to 9000rpm over 10 load sites. COMPLETE IGNITION TIMING CONTROL: No need to worry about the factory ECU pulling timing anymore; be as aggressive or conservative as you want or just let the factory ECU determine timing at any point in the map FUEL CONTROL: Controlled via MAF sensor signal offset, tune stock and larger than stock injectors; pre-set injector correction (just type in the size!). LOAD REFERENCE: MAP (manifold pressure) CLOSED LOOP BOOST CONTROL: Programmable via throttle Position and RPM. No more re-adjusting the boost controller due to changes in temperature or altitude. Keeps boost low while in closed loop fuel mode for reliability. KNOCK CONTROL: Automatically retards timing when the knock is detected safeguarding against engine damage. Adjustable knock threshold, timing correction, and duration. ON-BOARD DATA LOGGING: Displays all necessary data required for tuning, including wideband AFR when used in conjunction with the Turbo XS Tuner. BUILT-IN PROGRAMMABLE SOLENOID CONTROLLER: Control nitrous, water injection, intercooler water spray or any other solenoid device. ADDITIONAL FEATURES: Drag racing launch control (secondary rev limit used during launch). All UTEC software downloads and upgrades are free and available from Turbo XS's website. 1 YEAR WARRANTY FITMENT: 2002-07 WRX 2004-07 STi Delta Utec 02-05 WRXtxs-DELTA-001 Delta Utec 04-06 STitxs-DELTA-002 Delta Utec 06-07 WRXtxs-DELTA-003 MSRP - $1046 Our Price - $944 _________________________________________________ Turbo XS Delta v2.0 UTEC Engine Management for STi The Turbo XS UTEC is a new concept in engine management that combines the features of a stand-alone engine management system with the simplicity of a piggyback system. The UTEC enables complete programmable control over ignition timing, fuel, and boost, while allowing the factory ECU to maintain control over basic day-to-day functions. Functions like cold start, hot start, intake temperature compensation, AC compensation and closed-loop fuel control signals are all managed by the factory ECU reducing your tuning time significantly while enhancing daily drivability. Spend more time driving and less time tuning for stock functions.UTEC Standard Features: PLUG & PLAY: Installs in minutes on top of the factory computer using all the factory connections. ADDITIONAL FEATURES: Drag racing launch control (secondary rev limit used during launch). All UTEC software downloads and upgrades are free and available from Turbo XS's website. 5 MAP MEMORY: 5 maps can be stored at a time, and using the remote map selector, you can quickly switch into valet mode, stock mode, nitrous, or race fuel maps with the click of a switch. ON-BOARD DATA LOGGING: Displays all necessary data required for tuning, including wideband AFR when used in conjunction with the Turbo XS Tuner. COMPLETE IGNITION TIMING CONTROL: No need to worry about the factory ECU pulling timing anymore; be as aggressive or conservative as you want or just let the factory ECU determine timing at any point in the map FUEL CONTROL: Controlled via MAF sensor signal offset, tune stock and larger than stock injectors; pre-set injector correction (just type in the size!). LOAD REFERENCE: MAP (manifold pressure) CLOSED LOOP BOOST CONTROL: Programmable via throttle Position and RPM. No more re-adjusting the boost controller due to changes in temperature or altitude. Keeps boost low while in closed loop fuel mode for reliability. KNOCK CONTROL: Automatically retards timing when the knock is detected safeguarding against engine damage. Adjustable knock threshold, timing correction, and duration. END-USER PROGRAMMABLE: Fine tune maps via a laptop equipped with a serial cable and Hyperterminal. FUEL, TIMING, AND BOOST ARE USER-PROGRAMMABLE: in 250rpm increments up to 9000rpm over 10 load sites. BUILT-IN PROGRAMMABLE SOLENOID CONTROLLER: Control nitrous, water injection, intercooler water spray or any other solenoid device. PRE-PROGRAMMED BASE MAPS: Standardized maps are available for common setups (i.e. turboback exhaust, upgraded intercooler, bigger turbo & injectors, etc.) Maps can be uploaded and downloaded easily. Not currently available for the Legacy GT. FITMENT: 2008-00 STi Delta Utec 2008-09 STi txs-DELTA-003 MSRP - $1046 Our Price - $944 Please pm us with any questions or Visit automasteramr.com
__________________
[LEFT][SIZE=1][B][COLOR=red][SIGPIC][/SIGPIC][/COLOR][/B][/SIZE] [SIZE=1] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/SIZE] [FONT=Century Gothic][B]Instant Messenger:[/B] [COLOR=red][I][B]AMR Performance[/B][/I][/COLOR][/FONT] [SIZE=1][COLOR=black][B] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/B][/COLOR][/SIZE] [SIZE=1][FONT=Lucida Sans Unicode][COLOR=black][B]ECU SOFTWARE & PERFORMANCE PARTS MANUFACTURER[/B][/COLOR][/FONT][/SIZE] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/LEFT] |
06-30-2008, 10:38 AM | #2 |
Member#: 171509
Bumpity Bump!!
__________________
[LEFT][SIZE=1][B][COLOR=red][SIGPIC][/SIGPIC][/COLOR][/B][/SIZE] [SIZE=1] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/SIZE] [FONT=Century Gothic][B]Instant Messenger:[/B] [COLOR=red][I][B]AMR Performance[/B][/I][/COLOR][/FONT] [SIZE=1][COLOR=black][B] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/B][/COLOR][/SIZE] [SIZE=1][FONT=Lucida Sans Unicode][COLOR=black][B]ECU SOFTWARE & PERFORMANCE PARTS MANUFACTURER[/B][/COLOR][/FONT][/SIZE] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/LEFT] Last edited by AMR; 07-07-2008 at 11:40 AM. |
07-01-2008, 02:33 PM | #3 |
Member#: 171509
Bump!!
__________________
07-03-2008, 09:54 AM | #4 |
Member#: 171509
Uppp^^^
__________________
07-07-2008, 11:35 AM | #5 |
Member#: 171509
AMR Built Motors
Bump!!
__________________
turbo xs utec for 02-05 wrx | soobieajax325 | SCIC Private Classifieds | 0 | 05-03-2007 02:07 AM |
turbo xs utec for 02-05 wrx | soobieajax325 | Engine/Power/Exhaust | 0 | 05-03-2007 02:07 AM |
Fs Ns: Turbo Xs Utec For 02-05 Wrx | handyRS | Engine/Power/Exhaust | 11 | 10-13-2006 02:12 AM |
Turbo XS UTEC for 02-05 WRX | riSTI | Private 'For Sale' Classifieds | 7 | 03-24-2006 08:55 AM |
FS: Turbo XS UTEC for 02-05 wrx | vipmooneyes | Private 'For Sale' Classifieds | 0 | 10-22-2005 07:52 PM |
