01-30-2003, 07:00 PM | #1 |
Member#: 9534
Vehicle:2002 Silver 2002 Liquid Silver R1 |
How does a flywheel work and what does it do?
Searched but came up with a lot... Can anyone give me an explaination or know a site I can go too? I try howstuffworks but there isnt anything there.. thanks.
01-31-2003, 01:11 AM | #2 |
Member#: 3467
Vehicle:1998 Dinan3 Bleck |
crude writing, but the flywheel is around metal plate (weighing around 25lb. for the RS) and has metal teeth around the outer edge which is meshed with the starter motor. when you turn the key, the starter rotates the flywheel, which is connected to the crankshaft and sets things in motion to get your car started. Next function, the surface of the flywheel provides a contact patch so that the clutch disc (attached to the shaft in the tranny) can engage with the flywheel, hence causing the car to move forward.
01-31-2003, 08:37 AM | #3 |
Member#: 10801
NESIC
Vehicle:2008 Outback |
Look harder. http://www.howstuffworks.com/clutch2.htm
01-31-2003, 08:51 AM | #4 | |
Member#: 9534
01-31-2003, 08:52 AM | #5 | |
Member#: 9534
In that whole article thats the only place the flywheel is mentioned... If thats the way you choose to explain things to people then I will make sure not to ask you questions in the future. Thanks for the help. |
01-31-2003, 02:33 PM | #6 |
Member#: 3467
Actually, that drawing does help explain what I was trying to say. It gives a visual
01-31-2003, 02:37 PM | #7 | |
Member#: 6971
NWIC
Vehicle:2008 WRX STi SSM |
01-31-2003, 03:11 PM | #8 |
Member#: 10801
NESIC
Wow, this is the first time I pissed off a n00b. I've pissed off old-schoolers before, though. Does this mean I'm no longer a n00b?
01-31-2003, 03:15 PM | #9 | |
Member#: 9534
i do need a hug, wait are you a guy?...... Nevermind |
what is turbine clipping and what does it do? | singsing | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 11 | 05-22-2020 06:45 AM |
What is this, and what does it do? | Karas | Newbies & FAQs | 10 | 08-25-2009 08:45 PM |
what is this and what does it do? | Russ77 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 09-22-2005 01:00 AM |
Noob question! What is a camber plate and what does it do? | GlenCastleberry | Brakes, Steering & Suspension | 2 | 03-11-2005 04:29 PM |
('93-'01) what is this and what does it do? | shimstock | Impreza Forum | 4 | 04-10-2001 09:53 AM |
