05-22-2017, 02:28 PM | #1 |
Member#: 422319
NWIC
Vehicle:2015 WRX WRB |
Wet sanded past clear coat, what options now?
Like the title indicates, I wet sanded a good amount of clear coat off when trying to repair a rock chip yesterday. It's a good amount of area, roughly the size of a dime or so.
I put some new clear over it but it is still extremely noticeable. I'm afraid that I'll have to get the door panel repainted and am prepared to do so. Are there any other options?
05-22-2017, 03:14 PM | #2 |
Member#: 422693
Vehicle:2016 WRX Premium Lapis Blue Pearl |
Should have compounded and polished before putting the clear on as you likely scratched the base coat with the wet sanding. Will have to polish and compound over cleared spot as well to level everything out and make it smooth and reflect light like the rest of the panel. Will probably still notice the spot even after polishing it up.
05-22-2017, 04:17 PM | #3 | |
Member#: 422319
NWIC
05-22-2017, 04:21 PM | #4 |
Member#: 402977
SCIC
if you indeed did sand through the clear (possible) then the only solution is to re-paint and then re-clear. My question (which will sound aggressive) is:
1. why were you sanding if you did not know what you were doing? It is easier to use a rotary polisher then it is to sand clear coat effectively!!! 2. why did you not use paint for the rock chip? 3. do you have a paint measuring device? 4. what steps have you tried up to this point? If you have tried compound/polish and the paint remains hazy, then yes you sanded too deep. If the color came back but there are still scratches, then you need a more aggressive compound |
05-22-2017, 05:31 PM | #5 | |
Member#: 422319
NWIC
2) Do you mean color coat? If so, I did. I filled the chip with color, leveled it and then applied clear, at which point I noticed that it was still looking foggy. 3) I don't have any measuring tools and have learned an expensive lesson from eyeballing it. 4) I haven't done anything since applying the final coat of clear last night. I was planning to level it down with compound and polish tonight. Sounds like I'm going to have to live with it until I get the door repainted. |
05-22-2017, 07:17 PM | #6 | |
Member#: 402977
SCIC
Depending on how much touch up paint you used and how thick it was when applied (think blob of paint vs evenly sprayed spray can paint), it could result in a foggy look. Maybe try another layer of paint and/or try going over the area with compound and polish to see if it brings back some color. |
