Welcome to the North American Subaru Impreza Owners Club Tuesday February 19, 2019
Go Back   NASIOC > NASIOC Classifieds > Vendor 'General Sale' Forum
Old 11-14-2018, 04:36 PM   #1
EastEndRaceshop
Vendor Sales Rating: (0)
Member#: 492744
Default Moton/AST High Quality Suspension
EAST END RACESHOP | MOTON/AST SUSPENSIONS
I am proud to announce that East End Raceshop now carries Moton/AST coilover kits.
Moton is a renowned damper brand, started its activities in 1999.
Moton Suspension Technology develops, manufactures and markets a full range of high quality, easy to use and state of the art adjustable dampers.
By June of 2000, 30% of the starting field at the famous 24 hours race of Le Mans was equipped with Moton dampers and since that time many Championships were won on Moton dampers like the FIA GT and FIA Sportcar Championship, FIA ETCC and FIA WTCC Championship, Grand-Am and World Challenge Championship, 24 Hours of Spa, 24 Hours of Le Mans, 12 hours of Sebring and 10 hours of the Petit Le Mans, and not to mention numerous national GT, Touring and Club Racing events all over the world.
PLEASE contact me for individual specs/pricing and to order!
I can be reached on here via PM or email at [email protected]
AST 1-Way 5100
Available for:
15+ VA WRX/STI, GC/GF Impreza, GE/GH/GR/GV Impreza, and GG/GD Impreza, ZC6 BRZ
*Image is not vehicle specific.
The 5100 Series shock absorbers utilise inverted / upside down technology. The inverted design is race proven technology and produces an extremley strong damper, providing better suspension geometry under heavy lateral and braking loads as seen in a road and track environment.
The 5100 Series shock absorbers give your car a better performance than the standard twin tube design. With the 5100 Series suspension you can adjust rebound with one knob. The adjust platform allows you to adjust the ride height of your car. AST suspension shock bodies are specially designed to keep maximum stroke, even with a lower ride height.
How a Monotube design works?
Monotube design essential for performance, The oil and nitrogen are separated by a floating piston, and allows the use of a larger piston, increasing the damper performance and sensativity felt by the driver, all this added together produces more grip, gives more control and driver feedback from your vehicle.
What is a rebound adjustment?
Rebound controls the rate of extension of your shock absorber, By changing the rebound you can directly change the charecteristics of the vehicle.
  • Floating piston design with high pressure nitrogen means no cavitation around the piston.
  • 14mm diameter internal shaft.
  • 44.5 mm diameter shaft struts, inverted.
  • Steel cylinder body shocks, inverted.
  • High end, track ready suspension.
  • Rebound adjustable (”Singles”).
  • Low friction seal.
  • Adjuster knobs permanently mounted on the dampers.
  • Rubber bushings for ”eye” shock mounts.
  • Optional spherical top mounts.
  • Optional DLC Coated shafts.
  • Optional DDP piston (double digressive).
  • Rebuildable.
  • Optional custom valving.
AST 2-Way 5200
Available for:
The 5200 Series are 2-way adjustable shock absorbers which are based upon competition 3-way adjustable shock absorbers. The 5200 shock absorbers are adjustable in compression and rebound.
The design of the compression adjuster is an evolution of the compression adjuster we provided for the American Grand-Am series for the last few years. The 5200 shock absorbers were designed to achieve a quick and easy set up, allowing separate adjustment of compression and rebound.
In the 5200 Series AST uses an external canister. Throughout testing and competitions, the 5200 has been praised for its performance and capabilities, surpassing other major, more expensive brands and setting a new standard of 2 way damper. Its no surprise that the 5200 is fast becoming a favorite damper amongst race teams and track day enthusiasts world wide.
Benefits include:
  • High end, track ready suspension that is totally streetable
  • Fully upgradeable to 5300 spec
  • Rebound and Compression Adjustable (‘Doubles’), with a remote reservoir
  • Remote reservoirs allow additional travel and heat dissipation
  • 44.5mm diameter shaft struts, Inverted
  • New low friction seal on all AST dampers
  • Spherical lower ‘’eye’’ shock mounts
  • Reservoir with hose or piggyback
  • Spherical upper shock mount assemblies
  • Synthetic hydraulic fluid
AST 3-Way 5300
Available for:
For the best performance on the track, AST Suspension designed the Competition 3-way adjustable series. The 5300 Series shock absorbers are rebound adjustable in 12 positions on the strut.
The highspeed compression is adjustable in 12 positions and the lowspeed compression is adjustable in 14 positions. Both compression adjustments are made using an external canister. All adjusters work completely independent.
Many years of technical knowledge, testing and experience has been refined, fettled and brought together to create a perfect balance between the choice of springs and the corresponding damping characteristics. This makes it a versatile product for every customer. The 5300 series shock absorbers are the best solution for every race team. Once installed te shock absorbers are easy to setup, highly reliable and require low maintenance during the season because of the high grade of materials used.
All of this together makes the 5300 series shock absorbers a championship winning damper, over and over again. The AST 5300 Suspension is worldwide renowned for its performance at every level.
Benefits include:
  • Rebound, Low & Hi Speed Compression Adjustable (‘Triples’), with a remote reservoir.
  • Remote reservoirs allow additional travel, heat dissipation and oil/nitrogen gas capacity.
  • 44.5mm diameter shaft struts are inverted and offer exceptional strength, which in turn reduces geometry change under corner and braking manoeuvres.
  • Aluminum cylinder, threaded body shocks, factory mounting style.
  • New low friction seal on all AST dampers.
  • Spherical lower ”eye” shock mounts.
  • Reservoir with hose or piggyback (piggyback examples: ’08 STI & BMW E36 rears).
  • Spherical upper shock mount assemblies.
  • Synthetic hydraulic fluid.
  • Optional DLC Coated 44,5mm inverted shafts.
  • Fully serviceable and rebuildable.
  • Revalvable for specific characteristics.
Moton 2-Way Clubsport
Available for:
GG/GD Impreza, GG/GD Impreza, GE/GH/GR/GV Impreza, ZC6 BRZ
The Sport line is designed for the serious club racer and high performance street driver. This ultimate suspension system is by far the finest quality and best handling suspension system on the market today.
Featuring remote reservoirs for superior fluid temperature control, quick release hydraulic lines (on most models) for easy installation, separate compression and rebound damper valving adjustment and height adjustable spring perches, this kit is beyond the more common coil-over systems on the market. If your driving can benefit from the ultimate in suspension tuning, then this kit is for you.
Specifications
The Moton Sport damper features 15 positions of bump adjustment on the remote reservoir and 15 positions of rebound on top of the piston rod. Each adjustment done to the damper is very noticeable to the driver. Our sport dampers are designed to be easy-to-use and to deliver the absolute best performance. The sport dampers perform really well at low speed as well as high speed velocities which gives you total control in any track condition. The reservoir is connected by a high pressure hose and is equipped with swivel banjo’s for easy installation of the canisters in the vehicle, regardless of the position. The damper bodies are produced from the highest quality steel or aluminum. The shafts are induction hardened and chrome plated. The canister pressure can be varied between 6 – 16 BAR (100 – 300 psi) to help support the car in high speed cornering with soft springs.
Benefits include
  • Comfortable on daily roads
  • Easy to adjust to a real race setup
  • Easy to work with
  • Minor adjustments are very noticeable to the driver
  • Proven reliability
  • Wide range of spring rates can be used
  • Improved platform stability
  • Improved traction, higher grip level
  • Improved rumble strip and bumpy track control
  • Improved tire wear
Moton 3-Way Motorsport
Available for:
The 3-Way adjustable Moton damper features 15 positions of high speed bump, 6 positions low speed bump and 15 positions of rebound adjustment. The low speed bump adjuster is located on top of the high speed bump adjuster and can be adjusted independently. The low speed bump adjuster is very effective in helping to control body roll while adding to turn in and also is effective in controlling pitch and squat. The 3-Way adjustable Moton damper is using, like the double adjustable damper, a unique blow-off valve system in the canister to totally control curb stones and bumpy track conditions.
Benefits include
  • Improved tire wear over the complete race distance
  • Easy to adjust and work with
  • Every single adjustment done is very noticeable to the driver
Features
  • Unique blow off valve system in canister for high speed bump control
  • Large piston rod diameter for more fluid displacement
  • Adjustable gas pressure for added lifting force
  • Large main piston for quick response
  • No preloaded valve stacks needed for low speed damping control
  • Separate Bump and Rebound control
  • Swivel banjo hoses for easy installation of remote reservoirs
__________________
East End Raceshop
909-517-3688 (M-F 9-5 PST)
EastEndRaceshop is offline   Reply With Quote
Old 11-16-2018, 02:05 PM   #2
EastEndRaceshop
Member#: 492744
Is your car not listed? Contact us for more info:
Moton offers custom specifications for any chassis those looking to get really serious about their suspension set up.
MOTON 2-way, custom specification - $ 7,199.00
MOTON 3-way, custom specification - $ 9,499.00
MOTON 4-way, custom specification - $ 14,599.00
__________________
East End Raceshop
Old 11-19-2018, 03:04 PM   #3
EastEndRaceshop
Member#: 492744
Monday bump! It's almost Thanksgiving and Black Friday, PM me to get ahead of the line for the best holiday deals!
Check out some photos of the AST 5100 for the 15+ VA WRX/STI
Adding new products to the site everyday, check it out!
__________________
East End Raceshop
Old 11-19-2018, 06:54 PM   #4
EastEndRaceshop
Member#: 492744
AST Suspension kits added to the East End Raceshop site, click on the following links to check them out!
2015+ VA WRX/STI AST Coilovers (Please Contact us with your desired spring rates before placing order)
AST 1-Way 5100 - $2,599
AST 2-Way 5200 - $4,499
AST 3-Way 5300 - $5,099
__________________
East End Raceshop
Old 11-21-2018, 03:47 PM   #5
EastEndRaceshop
Member#: 492744
Who's looking forward to a well deserved break this Thanksgiving?
TREAT YOURSELF this holiday season with the lowest prices on performance parts! East End Raceshop Black Friday/Cyber Monday sale starts NOW and goes until the 27th!
-PM OR EMAIL ME AT [email protected] IF YOU WANT TO PURCHASE AT BLACK FRIDAY PRICING-
All parts are for the 15+ VA WRX/STI
Here's our complete sales list:
Coilovers (WRX/STI)
Tein Flex A Coilover Kit - $959
Greddy x KW Performance Coilovers - $1,249
Tein Street Basis Z Coilover Kit - $430
Exhausts (WRX/STI)
Greddy Supreme SP Exhaust - $999
Magnaflow Competition Series Exhaust (Stainless) - $849
Blox Racing Exhaust System (Stainless) - $899
Headers (WRX)
Perrin Equal Length Header (1.625" Primaries, Big Tube) - $899
Header (STI)
Perrin Equal Length Header (1.625" Primaries, Big Tube) - $1,019
Perrin Equal Length Header (1.5" Primaries) - $1,015
Intakes (WRX)
AEM Cold Air Intake - $299
K&N Typhoon Cold Air Intake Kit - $279
Perrin Cold Air Intake - $299
Intakes (STI)
Perrin Cold Air Intake - $275
Intercoolers (WRX/STI)
Perrin Front-Mount Intercooler Core - $755
Perrin Boost Tubes - $799
**ASK ABOUT SPECIAL NASIOC PRICING**
Free shipping to the Continental USA with all orders over $300
(Flat rate international shipping available)
We offer the option to buy now and pay later with Affirm!
__________________
East End Raceshop
Old 11-23-2018, 04:58 AM   #6
EastEndRaceshop
Member#: 492744
Now that you've treated yourself it's time to treat your car to some goodies, check out our lowest prices of the year on some of the most popular brands!
CLICK HERE TO CHECK THEM OUT!
__________________
East End Raceshop
Old 11-24-2018, 05:51 PM   #7
EastEndRaceshop
Member#: 492744
No need to worry about missing out on door buster deals with East End Raceshop, we are continuing our Black Friday prices throughout the weekend and until the 27th, check them out!
Click here to check out our Thanksgiving deals!
__________________
East End Raceshop
Old 11-26-2018, 10:20 PM   #8
EastEndRaceshop
Member#: 492744
It's Cyber Monday, time to get clicking!
Don't miss out on our biggest sale of the year!
Click here to check out the East End Raceshop Thanksgiving Sale!
__________________
East End Raceshop
Old 12-04-2018, 12:08 AM   #9
EastEndRaceshop
Member#: 492744
Monday bump!
__________________
East End Raceshop
Old 01-08-2019, 05:29 PM   #10
EastEndRaceshop
Member#: 492744
Get the BEST in racing technology with AST/MOTON coilovers! Engineered to win!
Please PM or email [email protected] for special forum pricing!
__________________
East End Raceshop
Old 01-09-2019, 07:51 PM   #11
EastEndRaceshop
Member#: 492744
Stand out from the crowd with AST/MOTON!
__________________
East End Raceshop
Old 01-10-2019, 07:39 PM   #12
EastEndRaceshop
Member#: 492744
Ready for the next level? The AST 5100 Series coilovers are the next step up when considering a performance suspension. They still offer great driving comfort but are definitely track focused. These are great coilovers for the performance minded enthusiast who tracks their car occasionally, but doesn't want to get too deep into fine suspension tuning.
The 5100 Series feature full height adjustability with damper tuning aimed at performance driving, occasional track days, and a civilized ride. The monotube dampers are invert mounted for improved strength and the rebound adjustability allows for more tuning to your desired performance level and driving style. Like the 4100 Series, the 5100 Series features improved corrosion resistance with AST's KTL Coating.
__________________
East End Raceshop
Old 01-11-2019, 07:51 PM   #13
EastEndRaceshop
Member#: 492744
Visit us at WWW.EASTENDRACESHOP.COM!
PM for SPECIAL FORUM PRICING on all MOTON/AST products!
__________________
East End Raceshop
Old 01-14-2019, 08:07 PM   #14
EastEndRaceshop
Member#: 492744
__________________
East End Raceshop
Old 01-15-2019, 07:56 PM   #15
EastEndRaceshop
Member#: 492744
Looking to bring your handling and driving dynamics to the next level? Look no further! AST/MOTON coilovers bring the best to the table!
PM us for special forum pricing on your next set!
__________________
East End Raceshop
Old 01-16-2019, 07:12 PM   #16
EastEndRaceshop
Member#: 492744
Get the best prices for your favorite brands at WWW.EASTENDRACESHOP.COM!
Discount code: GGFRS
__________________
East End Raceshop
Old 01-17-2019, 06:52 PM   #17
EastEndRaceshop
Member#: 492744
Push your car to the limits with AST/MOTON coilovers!
Now available at East End Raceshop!
__________________
East End Raceshop
Old 01-18-2019, 06:26 PM   #18
EastEndRaceshop
Member#: 492744
Have a GREAT WEEKEND NASIOC!!!
__________________
East End Raceshop
Old 01-22-2019, 07:04 PM   #19
EastEndRaceshop
Member#: 492744
AST/MOTON coilovers are now available at East End Raceshop!
PM FOR SPECIAL FORUM PRICING!
__________________
East End Raceshop
Old 01-23-2019, 07:33 PM   #20
EastEndRaceshop
Member#: 492744
For those of you who want to push your WRX/STI to the limits on the track, AST coilovers are the perfect choice for you!
__________________
East End Raceshop
Old 01-24-2019, 06:55 PM   #21
EastEndRaceshop
Member#: 492744
__________________
East End Raceshop
Old 01-25-2019, 06:09 PM   #22
EastEndRaceshop
Member#: 492744
Have a great weekend NASIOC
__________________
East End Raceshop
Old 01-28-2019, 06:51 PM   #23
EastEndRaceshop
Member#: 492744
__________________
East End Raceshop
Old 01-29-2019, 06:16 PM   #24
EastEndRaceshop
Member#: 492744
Check out our selection of aftermarket parts at WWW.EASTENDRACESHOP.COM! Discount code: GGFRS
Don't see what you're looking for on our site? We can source parts for any Subaru chassis old or new, just shoot a me private message or email at [email protected]
__________________
East End Raceshop
Old 01-31-2019, 07:01 PM   #25
EastEndRaceshop
Member#: 492744
Get the best in technology and customer support with AST/MOTON coilovers!!! The perfect choice for those of you who want to upgrade your ride and finish first!
__________________
East End Raceshop
