Welcome to the North American Subaru Impreza Owners Club Saturday April 4, 2020
Old 04-23-2014, 07:12 PM   #1
Gro Harlem
Member#: 165782
2015 WRX Limitd Stg2
'02 Stg4 & JSW TDI Stg2
OMGHi2U 2015 WRX & STI Epic Thread of Knowledge
This thread is a compilation of useful information regarding the new 2015 Subaru WRX and STI. My goal with this is to post links to thread posts, videos or webpages with factual information regarding the new models.
If anyone find/discovers any new information on the 2015 models post it here & i'll update this post. Or if you find a thread that has decent discussion on any particular topic link it. OR if you disagree and/or feel any of the information is incorrect please quote it and post the corrections.
General Information Resources:2015 WRX / STI Owners Manual Links:
  1. http://www.joomag.com/magazine/mag/0...=;solid,ffffff
  2. http://www.subaru.ca/WebPage.aspx?We...&WebSiteID=282
  3. http://www.iwsti.com/images/2015-sti...ers-manual.pdf
2015 WRX & STI Performance Numbers:
  • 0-60:
    • (6MT): 5.4 sec (Subaru), 4.8 sec (C&D redlining in 2nd), 5.2 sec (Road & Track) 5.5 sec (Motor Trend), 5.4 sec (Edmunds), 5.2 sec (Edmunds w/1 ft rollout)
    • (CVT): 5.9 sec (Subaru), 5.8 sec (Motor Trend)
    • (STI): 4.6 sec (Motor Trend), 4.8 sec (Road & Track)
  • 1/4 Mile:
    • (6MT): 13.6 sec @ 102 mph (Car & Driver), 13.7 sec @ 99.5 mph (Road & Track), 14.0 sec @ 98.1mph (Motor Trend), 13.8 sec @ 99.8 mph (Edmunds)
    • (CVT): 14.5 sec @ 96.7 mph (Motor Trend)
    • (STI): 13.1 sec @ 104.4 mph (Motor Trend), 13.3 sec @ 102.8 mph (Road & Track)
  • Top Speed:
    • (6MT) 144 mph (Gov Ltd, Mfg's Claim), 174 mph (Road & Track @ redline estimate)
    • (STI) 155 mph (Road & Track @ redline estimate)
  • Figure Eight:
    • (6MT): 25.3 sec @ 0.76g avg (Motor Trend)
    • (CVT): 25.5 sec @ 0.73g avg (Motor Trend)
    • (STI): 24.9 sec @ 0.79g avg (Motor Trend)
  • Slalom:
    • (6MT): 70.1 mph (Edmunds)
  • Skidpad:
    • (6MT): 0.95g avg (Car & Driver), 0.96g avg (Motor Trend), 0.94g (Edmunds)
    • (CVT): 0.93g avg (Motor Trend)
    • (STI): 0.97g avg (Motor Trend)
  • Braking 60-0mph:
    • (6MT): 106 ft (Motor Trend), 110 ft (Edmunds)
    • (CVT): 107 ft (Motor Trend)
    • (STI): 108 ft (Motor Trend)
  • Braking 70-0mph:
    • (6MT): 160 ft (Car & Driver)
DYNO Results: --------------------------------------------------------------------------------------------------------
Engine:--------------------------------------------------------------------------------------------------------
Suspension / Brakes:--------------------------------------------------------------------------------------------------------
Wheels/Tires:--------------------------------------------------------------------------------------------------------
Interior:--------------------------------------------------------------------------------------------------------
Exterior:--------------------------------------------------------------------------------------------------------
Stereo / Speakers:--------------------------------------------------------------------------------------------------------
Lighting:--------------------------------------------------------------------------------------------------------
Dealer/Factory Accessories:--------------------------------------------------------------------------------------------------------
Gro Harlem is offline   Reply With Quote
Old 04-23-2014, 07:12 PM   #2
Gro Harlem
Member#: 165782
OMGHi2U
Specifications:
  • WRX FA20DIT Engine:
    • Bore x Stroke: 3.39 x 3.39 in, 86.0mm x 86.0mm
    • Displacement: 122 cu in, 1998 cc
    • Compression Ratio: 10.6:1
    • Fuel Delivery System: gasoline direct injection, electronic throttle control (ETC), twin-scroll turbocharger with intercooler
    • Turbocharger: Honeywell
    • Maximum Boost Pressure: 15.9 psi
    • Valve Gear: double overhead cams, 4 valves per cylinder, variable intake and exhaust valve timing
    • Redline/Fuel Cutoff: 6700/6800 rpm
    • Power: 268 hp @ 5600 rpm
    • Torque: 258 lb-ft @ 2000rpm
  • WRX 6MT Gear Ratios / Max Speed in Gear:
    • 1: 3.454:1 / 35 mph (6800)
    • 2: 1.947:1 / 62 mph (6800)
    • 3: 1.296:1 / 93 mph (6800)
    • 4: 0.972:1 / 124 mph (6800)
    • 5: 0.780:1 / 144 mph (6350)
    • 6: 0.666:1 / 144 mph (5400)
    • Reverse: 3.636:1
    • Final Drive: 4.11:1
  • CVT Gear Ratios:
    • 1: 3.505:1 (S#: 3.505:1)
    • 2: 2.238:1 (S#: 2.405:1)
    • 3: 1.641:1 (S#: 1.855:1)
    • 4: 1.194:1 (S#: 1.544:1)
    • 5: 0.880:1 (S#: 1.258:1)
    • 6: 0.611:1 (S#: 1.032:1)
    • 7: (S#: 0.856:1)
    • 8: (S#: 0.716:1)
    • Reverse: 2.345:1
    • Final Drive: 3.90:1
  • Steering Ratio: 14.5:1
  • Turns lock-to-lock: 2.8
  • Turning Circle: 35.4 ft
  • Exterior Dimensions:
    • Wheelbase: 104.3 in
    • Length: 180.9 in
    • Width: 70.7 in
    • Height: 58.1 in
    • Front Track: 60.2 in
    • Rear TracK: 60.6 in
    • Ground Clearance: 4.9 in
  • Interior Dimensions:
    • SAE Volume: 52 cu ft (Front) / 41 cu ft (Rear)
    • Trunk: 12 cu ft
Fluids & Capacities:
  • Fuel Type:
    • WRX: 91 Octane (95 RON) or higher. 87 (90 RON) may be temporarily used if 91 is not readily available
    • STI: 93 octane (98 RON) or higher. 91 (95 RON) may be temporarily used if 93 is not readily available
    • Fuel Capacity: 15.9 US Gallons (60 liters, 13.2 Imperial Gallons)
  • Oil Type/Grade: API classification SM with the words "ENERGY-CONSERVING" or SN with the words "RESOURCE CONSERVING" or ILSAC GF-4 or GF-5 SAE Viscosity: 5W-30 Synthetic. 5W-40 may be used if 5W-30 is not readily available.
  • Oil Filter Part Number:
    • WRX: 15208AA170
    • STI: 15208AA100
  • Engine Oil Capacity:
    • WRX:
      • Adding the oil from L to F leveL: 1.1 US Quarts (1.0 Liter, 0.9 Imperial Quarts)
      • Changing the oil and oil filter: 5.4 US Quarts (5.1 Liters, 4.5 Imperial Quarts)
      • Changing the oil only: 5.2 US Quarts (4.9 Liters, 4.3 Imperial Quarts)
    • STI:
      • Changing the oil and oil filter: 4.5 US Quarts (4.3 Liters, 3.8 Imperial Quarts)
      • Changing the oil only: 4.2 US Quarts (4.0 Liters, 3.5 Imperial Quarts)
  • Transmission Oil Grade:
    • WRX 6MT: Subaru Extra MT recommended. API Classification GL-5 (75W-90) may be used but will detract from driveability and fuel efficiency.
    • WRX CVT: "Consult Subaru Dealer" (according to Owners Manual)
    • WRX CVT Front Differential: Subaru Extra MT recommended. API Classification GL-5 (75W-90) may be used but will detract from driveability and fuel efficiency.
    • STI 6MT: API Classification GL-5 (75W-90)
    • Rear Differential (All models): API Classification GL-5 (75W-90)
  • Transmission Oil capacity:
    • WRX 6MT: 3.5 US Quarts (3.3 Liters, 2.9 Imperial Quarts)
    • WRX CVT: 13.1 US Quarts (12.4 Liters, 10.9 Imperial Quarts)
    • WRX CVT Front Differential: 1.5 US QUarts (1.4 Liters, 1.2 Imperial Quarts)
    • STI 6MT: 4.3 US Quarts (4.1 Liters, 3.6 Imperial Quarts)
    • WRX Rear Differential (all): 0.8 US Quarts (0.8 Liters, 0.7 Imperial Quarts)
    • STI Rear Differential: 1.1 US Quarts (1.0 Liter, 0.9 Imperial Quarts)
  • Fluid Types:
    • Brake Fluid: FMVSS No. 116, Fresh DOT 3 or DOT 4 brake fluid
    • Clutch Fluid (MT Models): FMVSS No. 116, Fresh DOT 3 or DOT 4 brake fluid
    • Power Steering Fluid (STI): Subaru ATF, "Dexron III" Type Automatic Transmission Fluid, IDEMITSU ATF HP.
    • Coolant: SUBARU Super Coolant
  • Fluid Capacities:
    • Power Steering Fluid Capacity (STI): 0.7 US Quarts (0.7 Liters, 0.6 Imperial Quarts)
    • Coolant (WRX 6MT): 8.7 US Quarts (8.2 Liters, 7.2 Imperial Quarts)
    • Coolant (WRX CVT): 8.9 US Quarts (8.4 Liters, 7.4 Imperial Quarts)
    • Coolant (STI 6MT): 8.2 US Quarts (7.7 Liters, 6.8 Imperial Quarts)
Electrical System:
  • Battery Type: 55D23L (12V-48ah)
  • Alternator: WRX: 12V-130A, STI: 12V-110A
  • Spark Plugs: WRX: NGK ILKAR8H6, STI: NGK SILFR6A
Bulb Types:
  • High Beam Headlight: HB3 (9005)
  • Low Beam Headlight (w/out LED headlights): H11 (H8, 881)
  • Parking Light (w/out LED headlights): W5W (168/194)
  • Front Fog Light: H16 NOTE: Owners manual is WRONG. 2015 WRX & STI use PGJ19-3 base as opposed to the 5202/9009.
  • Front Turn Signal Light: WY21W (7440)
  • Front Side Marker Light: W5W (168/194)
  • Rear Turn Signal: WY21W (7440)
  • Backup Light: W16W (921, 955, T15)
  • Rear Side Marker Light: W5W (168/194)
  • License Plate Light: W5W (168/194)
  • Cargo/Trunk Light: W5W (168/194)
  • Map Light: DE3175
  • Rear Dome Light: DE3175
  • Visor/Vanity Light: 6614/6614F 6641/6641F NOTE: Owners manual is WRONG. Visor/Vanity Lights are 29mm fuse-style bulbs
Factory Torque Specifications: (thanks to speedrye & tamtalizied for this info)
  • Wheel Lug/Nut Torque: 88.5 ft-lbs.
  • Engine Oil Drain Plug: 31 ft-lbs.
  • Brake Caliper Torque:
    • Front Brake Caliper to Bracket: 20 ft-lbs.
    • Rear Brake Caliper to Bracket: 20 ft-lbs.
    • Front Caliper Bracket to Hub/Knuckle: 59 ft-lbs.
    • Rear Caliper Bracket to Hub/Knuckle: 49 ft-lbs.
  • Front Suspension Torque:
    • Lower ball joint to steering knuckle: 37 ft-lbs.
    • Lower ball joint to control arm: 29 ft-lbs. (Turn an additional 60)
    • Lower control arm bushing: 70 ft-lbs.
    • Support plate to arm: 81 ft-lbs.
    • Support plate to body: 111 ft-lbs.
    • Upper strut/shock mounting: 15 ft-lbs.
    • Lower strut/shock mounting: 114 ft-lbs.
    • Strut center shaft: 41 ft-lbs.
    • Anti-roll bar to bracket: 18 ft-lbs.
    • Anti-roll bar to control arm: 28 ft-lbs.
    • Spindle nut: 162 ft-lbs.
    • Bearing hub to knuckle: 48 ft-lbs.
  • Rear Suspension Torque:
    • Hub to control arm: 48 ft-lbs.
    • Upper strut/shock mounting: 22 ft-lbs.
    • Lower strut/shock mounting: 59 ft-lbs.
    • Strut center shaft: 18 ft-lbs.
    • Spindle nut: 140 ft-lbs.
  • Steering System Torque:
    • Tie rod stud: 20 ft-lbs.
    • Tie rod clamp or jamb nut: 63 ft-lbs.
    • Steering gear mounting bolt: 44 ft-lbs.
    • Steering shaft bolt: 17 ft-lbs.
2015 WRX & STI Known Problems / Warranty Concerns
  • WRX & STI Trunk Chipping Issue: Reports of chipped paint on the edge of the trunk deck from contact with the rear 1/4 panel of the car. Cause to be determined but suspected that either the bumpstops/latch adjustment from the factory is too low causing contact when slamming the trunk shut OR possibly due to the tie-down straps used during shipping from Japan to North America being too tight.
  • 2015 WRX & STI Base Radio Glitch: when programming presets on XM radio, the steering wheel controls for changing stations increase by the # of the last preset pressed
Old 04-23-2014, 07:13 PM   #3
Gro Harlem
Member#: 165782
2015 WRX & STI Knowledge Base Requests
If you have a question regarding the new 2015 WRX or STI that hasn't been answered above please post it in this thread & I'll post it below for others to answer. I'll update the knowledge base when the information has been confirmed. NOTE: Please do not spam up the thread with questions that have already been answered, thanks!
Questions that need confirmation:
  1. FA20DIT ECU Tuning Status (Cobb, ECUtek, etc)
  2. FA20DIT Downpipe Development & options
  3. Front & Rear swaybar sizes on stock STI
  4. Do LED turn signal mirros from STI models fit WRX? Do harnesses exist under door cards? Any wiring involved?
  5. Factory Speaker depth limits for front & rear.
  6. Speaker adapter compatibility & options
  7. Subwoofer mounting locations, custom sub box options
  8. Base STI Factory Wheel Weight (to closest 10th or 100th of a lb)
  9. Limited STI Factory Wheel Weight (to closest 10th or 100th of a lb)
  10. Optional 17" STI WRX Wheel Option Weight (to closest 10th or 100th of a lb)
  11. Wheel Offset limits for factory fenders.
  12. Lowering Spring offerings
  13. Swaybar/Endlink Offerings
  14. Suspension brace offerings
  15. Quote:
    Originally Posted by transit View Post
    I'm not sure if this has been covered, but does 15 WRXs share the same windows/windshield as 2014 Impreza?
  16. Trunk Measurements: http://forums.nasioc.com/forums/show....php?t=2624333
Old 04-23-2014, 07:14 PM   #4
-vanguard-
Member#: 379708
2015 WRX Limited Nav
Nice thread man
-vanguard- is offline   Reply With Quote
Old 04-23-2014, 07:25 PM   #5
DRTiraPiedra
Member#: 265912
Thumbs up
^Agreed! Mods should definitely sticky this thread since the links & information are all consolidated here. Thanks Gro Harlem.
DRTiraPiedra is offline   Reply With Quote
Old 04-23-2014, 07:27 PM   #6
colin1234567
Member#: 212639
WRX= 13/SWP/SOLD
'10 NC2 Miata
Yay more 2015 threads!!!!!!!! :****ingbananas:
colin1234567 is offline   Reply With Quote
Old 04-23-2014, 07:30 PM   #7
Thunderpaw
Member#: 242205
2009 I don't know
Dirt
I vote for sticky
Didn't hit any links but consolidation and a year long ride at the top should help this swell of 2015 posts
Thunderpaw is online now   Reply With Quote
Old 04-23-2014, 07:31 PM   #8
C4RBON_F1BER
Member#: 208507
'15 BRZ
I think you win NASIOC for the month.
C4RBON_F1BER is offline   Reply With Quote
Old 04-23-2014, 07:43 PM   #9
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
Originally Posted by Thunderpaw View Post
I vote for sticky
Agreed. Sticky this beotch!
Gallo2011 is offline   Reply With Quote
Old 04-23-2014, 08:22 PM   #10
Ultimateone
Member#: 48025
2020 Supra
AZW
Sticky, Magnet, All Of The Things
Ultimateone is offline   Reply With Quote
Old 04-23-2014, 08:37 PM   #11
rainking
Member#: 380934
2015 WRX
Nicely done. Happy to see my pics made it on the headlight list
rainking is offline   Reply With Quote
Old 04-23-2014, 09:59 PM   #12
96accord
Member#: 145105
2007 Impreza WRX STi
'15 Accord (Daily)
Subscribed.
96accord is offline   Reply With Quote
Old 04-23-2014, 10:02 PM   #13
BuckiWRX
Member#: 294409
2017 Hoodscoop Ltd
Rock Chip Silica
Wow! Nicely done! Small correction - the base STI wheels part # is missing a '1'. It is 28111VA050. Source: I own a set (currently up for sale)
BuckiWRX is offline   Reply With Quote
Old 04-23-2014, 10:07 PM   #14
thill
Member#: 377200
18 GT350
Shadow Black
Then don't ****ing open and read them..
OP nicely done!
thill is offline   Reply With Quote
Old 04-23-2014, 10:35 PM   #15
Type2
Member#: 200436
2004 Forester XT
Somebody looking for their first sticky! Approved!
Type2 is offline   Reply With Quote
Old 04-23-2014, 10:40 PM   #16
Gro Harlem
Member#: 165782
OMGHi2U
Oops, fixed it
Also added a link to a video on how to disable seatbelt beep. Apparently the passenger seat sensor is ridiculously touchy on the 2015's so this will be something ppl will want to do ASAP.
Old 04-23-2014, 10:58 PM   #17
colin1234567
Member#: 212639
WRX= 13/SWP/SOLD
'10 NC2 Miata
OP nicely done!
How can you not read them with four more with 2015 in the title below it?
I'll relax when the forum is re-titled "General 2015 Community"
Old 04-23-2014, 11:07 PM   #18
-vanguard-
Member#: 379708
Looks like you're just a sour 2013 owner to me
Old 04-23-2014, 11:14 PM   #19
colin1234567
Member#: 212639
WRX= 13/SWP/SOLD
'10 NC2 Miata
2013 is a great car as I'm sure the 2015 will be.
Just pointing out it doesn't need this amount of thread starting.
If this one thread started at the beginning that would have been wonderful!
Old 04-23-2014, 11:16 PM   #20
-vanguard-
Member#: 379708
Yes, but this thread is probably one of the better 2015 threads.
If you need to bash one, bash a more useless 2015 thread...not one that this OP put a serious amount of effort in.
Old 04-23-2014, 11:18 PM   #21
thill
Member#: 377200
18 GT350
Shadow Black
There was one thread. The mods shut it down and asked people to post in various threads here, and other subforums.
Honestly, I do agree that the 2015 really needs it's own section. But Nasioc wanted it this way, and this is what we got.
And it will only get worse as the 2015 community grows.
Old 04-23-2014, 11:18 PM   #22
Gro Harlem
Member#: 165782
yayy lets start a flame fest in the thread!!!
anyways, added LED illumination kit part #'s, install instructions, interior illumination mod link and homelink mirror part numbers.
taking a break for tonight from this...will update more tomorrow when i'm bored at work
Old 04-23-2014, 11:20 PM   #23
gargleblaster
Member#: 11107
2015 WRX STi
Crystal White Pearl
Another nomination for sticky. Nicely done Gro!
gargleblaster is offline   Reply With Quote
Old 04-24-2014, 02:15 AM   #24
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP 2016 Sienna
Nice
Old 04-24-2014, 03:02 AM   #25
starKnight
Member#: 386564
Awesome, thanks OP!
starKnight is offline   Reply With Quote
