#1 |
Member#: 519428
Vehicle:2013 Impreza Wrx World Rallye Blue |
![]() Hi all, I have a 2013 wrx that is making a very loud buzzing/humming noise that lasts for about 15 min upon starting the car. Thought it was a one time thing but I've started twice since then and it makes the same noise. Not trying to drive it until I take it to my mechanic but I was wondering if this happened to anyone else and/or if anyone has an idea of what this issue could be.
Appreciate the help!
#2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
![]() Where in the car is it coming from? If it's from the rear it may be the fuel pump. Turn the key to "run" without starting, do you still hear it? Normally the fuel pump should prime for a few seconds and turn off when you turn the key on but don't start, if that sound is the same buzzing you've found your problem.
If it's not coming from the rear then it's something else. |
#3 |
Member#: 28976
Vehicle:2016 Step 2 Push Buggy GT |
![]() What he said ^^^. You need to provide more information. Have a smartphone? Record it, upload the video to youtube and paste the link here. Could be bearing on the idler pulley, could be a bad steering pump, could be a bearing on the alternator pulley, could be a fuel pump that's about to go out.
#4 |
Member#: 519428
![]() The noise is coming directly from the engine bay, it is very clearly coming from there and its somewhere in the middle of the engine bay.
#5 |
Member#: 519428
![]() I'll record a video and get it on youtube to post here so you can get a better idea, thanks!
#6 |
Member#: 519428
![]() Btw the noise goes away after 15 min and the car drives fine, if that means anything. (tried driving it for 10/15 min earlier to see if i felt anything different while driving)
#7 | |
Member#: 519428
![]() Quote:
#8 | |
Member#: 519428
![]() Quote:
#9 | |
Member#: 28976
![]() Quote:
Car is stick or auto? Any electrical gremlins? Issues starting the car? Car stalling? I am no expert, it is a heavy metallic sound. Well duh the entire motor is metal ![]() Do you hear this whine when you turn the steering wheel left/right. Don't know how hand you are but can you try to take off the belt? Spin the idler pulley, spin the alternator. Here is a reference on the topic. |
#10 |
Member#: 521349
South East
Vehicle:2005 Impreza WRX |
![]() Let your car cool down and then remove your v belt. Turn the car over and run for 5 - 10 seconds. If the sound is gone that narrows it down for you. If not repeat with accessories belt. Do not do this with a warm car.
My money is on that alternator. |
#11 | |
Member#: 519428
![]() Quote:
I'll take a look at that video though thanks for the help! |
#12 | |
Member#: 28976
![]() Quote:
Start the car. Let it warm up and idle to normal. Grab a wood stick, say about 3 or 4 feet long. Stick it on top of the alternator, avoid the holes of the stator motor. Stick the other of wooden stick near your ear. Close your other ear with your finger. Don't take your eyes off the stick, lots of moving parts, you don't want to mess around with a live motor. If you hear humming it's not the alternator. If you hear the heavy metallic noise then you know it's the alternator. When in doubt leave it to the experts. Good luck and report back either way. |
#13 | |
Member#: 519428
![]() Quote:
#14 |
Member#: 28976
![]() Yes that is totally possible. Check the manual to see when it should be checked and what type goes in. Also check to make sure you don't have a leak by looking under the car.
#15 |
Member#: 519428
![]() I think my steering rack is leaking, do you know how much it would cost to replace and/or the correct steering rack for a 2013 Impreza WRX Sedan?
#16 |
Member#: 28976
#17 |
Member#: 48377
Vehicle:1996 Gutted, built XP class Impreza L |
![]() If you are not going to fix it yourself just take it to a decent mechanic nearby. Good mechanics are worth the money you pay them. DO NOT take it to a dealership, they are a ripoff every time.
#18 |
Member#: 521682
![]() This. You said you're not handy wwith cars, so might as well get it in a shop and get a quote/diagnosis ? Then come back and ask if it's an easy fix, maybe you're better than you think
#19 |
Member#: 487
TXIC
Vehicle:1998 /2005 STunIcorn Acadia Green RS-T |
![]() Got $6?
Buy one of these https://www.harborfreight.com/mechan...CABEgItJ_D_BwE Start poking around and listen Can appreciate you saying ***8220;not handy with cars***8221; Got to get lil dirty/do some investigation and report back This could be a $40 pulley that takes 20mins to change Or alternator......20mins to change (Maybe a hour for someones 1st time) That wood stick thing is same as using that $5 stethoscope Some mechanics just use a long screw driver, with your ear at one end |
#20 |
Member#: 429864
Vehicle:2009 WRX |
![]() Yeah I have a noise too but I think I rather have your noise. I have a ticking noise sounds like a diesel. ***55357;***56873;
