#26 |
Member Sales Rating: (16)
Member#: 114730
SWIC
Vehicle:2006 WRX Limited Wag [email protected] |
![]() Threads are the same you just need to pin the wires or splice them to the old connector.
#28 |
Member#: 62510
Vehicle:2005 Impreza Wrx Sti WR BLUE PEARL |
![]() Just finished installing this EGT Probe from thesensorconnection.com and i can tell ya it works just as the original Defi Probe.
Just make sure like they say previously to reverse the leads as Yellow is the positive wire on the sensor. Thanks to OP for the finding. |
#29 | |
Member#: 114730
SWIC
![]() Quote:
#30 |
Member Sales Rating: (1)
Member#: 178656
Vehicle:14 WRX hatch & 06 Evo IX |
![]() so it seems as thought i cannot use this if i have no existing egt probe to replace? as in i bought a defi egt gauge with no sensor (but have the half of the wire that connects to the control unit), this is unusable? or is there a way to bypass the plugs on the defi harnesses?
#31 | |
Member#: 114730
SWIC
![]() Quote:
#32 |
Vendor Sales Rating: (1)
Member#: 282460
Vehicle:2005 Evo-STI R.R.-WRB |
![]() sensor connections, chris, great guy and up front. We were looking for numerous other sensors as well and yup, he's gone as far as sourcing them to make sure we get what we need. Even letting us try a couple out to make sure they are within operating measures.
-Mark
__________________
[B]APM Tuned[/B] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Phone: (630) 833-8911 Email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [COLOR="Black"][B][SIZE="1"]Fill out our online survey for up to $50 off your next order from APM - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/SIZE][/B][/COLOR] |
#33 |
Member Sales Rating: (2)
Member#: 78288
Vehicle:2006 Subaru STi CGM |
![]() Bump to 2014 - this just saved me some serious cash. $50 vs $200+ for the same thing. Be mad all you want that I'm bringing it back but it's too good.
#35 |
Member Sales Rating: (9)
Member#: 206931
South East
Vehicle:2004 WRX Wagon 6MT JBP 318WHP//300WTQ |
![]() I'm glad I remember seeing this thread from a few years back because my sensor is busted now. I can't thank you enough OP!
Shame on Defi for wanting $200 for a simple thermocouple (two wires welded together inside a metal casing) |
#36 | |
Member Sales Rating: (3)
Member#: 21339
HIIC
Vehicle:2002 LHD STI V7 6MT [email protected] EJ205 4EAT |
![]() Quote:
Exactly my thought the other day when I saw my sensor. |
#37 |
Member#: 114730
SWIC
![]() Thanks. I'm glad it helped you out.
#38 |
Member#: 6176
NWIC
Vehicle:15 WRX, 04 wrb STi 85 wrb BRAT |
![]() Yes, this is a little late, but I was wondering people that said my original defi sensor failed...What were the symptoms when your sensor went bad ?
My EGT readings have always been a near 1400 @65mph, lately its been drifting upto 1600, then back to 1500, then 1400 then 1600 again. Even at idle, use to be 850, now 950 to 1000. WBO2 gauge shows around 14.5 as always at light cruise and 14.6 to 14.8 at idle. And fuel trims are still in the -2 to +4 range, not showing the engine is lean or the ecu is needing to add a bunch of fuel. I am thinking the gauge is not telling me the truth. |
#39 | |
Member#: 114730
SWIC
![]() Quote:
#40 |
Member#: 21339
HIIC
![]() Installing mine now after buying it a while ago. LOL. hand to change out my header so need a new probe too. Anyway, my wires are kind of old for my Defi link meter gauges and when I cut back the metal braids I have fiberglass and looks like bare wires in them. At the end before the connector end I have red and white wire sheeting.
How did you determine which wire is what and what's the easiest way to connect this up? ![]() |
#41 |
Member#: 78288
![]() Connectors confirmed.
This thread helped me out big time. I had purchased the sensor some time ago and just installed it. Saved me well over $100+. Hope the below proves useful for some! Thanks again to the OP for the information on the sensor. If you're OCD like me and wanting to replace with exactly what DEFI uses; below are the part numbers and model names for the connectors. They are made by TE Connectivity (who makes Deutsch connectors, Raychem and much...much more. Sub-brand for these - called "AMP" by TE Connectivity Housing for female terminal Econoseal - J Mk II Mfr. Part# 174352-2. http://www.alliedelec.com/te-connect...52-2/70283636/ Male terminal (on the end of the Defi EGT Sensor) Econoseal - J Mk II Mfr. Part #881772-1 http://www.te.com/usa-en/product-881...-docs-features Last edited by resu; 11-28-2016 at 10:10 AM. Reason: Confirmed connectors are correct |
#42 |
Member#: 114730
SWIC
![]() Bumping again, as the one I ordered 10 years ago finally bit the dust, so I ordered another.
WTB: EGT probe for greddy egt gauge | pannell77 | Private 'Wanted' Classifieds | 1 | 04-24-2009 10:40 AM |
EGT probe for old Defi-D? | tazswing | Electrical & Lighting | 2 | 03-19-2009 01:06 PM |
What EGT fitting for Defi probe | illmatic | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 03-01-2006 05:27 PM |
Teamrip EGT probe and Defi Gauge | Lunchbox027 | Electrical & Lighting | 6 | 07-25-2005 12:56 AM |
Westach EGT Probe with different gauge | TurboRex | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 28 | 06-22-2002 03:24 PM |
