Welcome to the North American Subaru Impreza Owners Club Tuesday March 2, 2021
Old 12-02-2013, 09:27 PM   #26
Half Crazed
Member Sales Rating: (18)
Member#: 321842
08 460/420w 08 STi
17 Stock WRB WRX
Originally Posted by majik1 View Post
I disagree completely, I have this exact clutch(cc stage 2 steel back brass+) and I enjoy it, the break in was rough but other than that it has been smooth sailing. The engagement is nice. It does grab a LOT harder than stock but a tiny change in throttle while taking off and you're golden. I don't have any more chatter or problems at all with this clutch and I have 2k on it. I would recommend this clutch to anyone who is stage 2 or more. I will be getting tuned for meth in a few weeks I'll let you all know how it goes.
Let us know how it holds after around 10k miles. I've had it for about 10k now and it slips when I'm hard on throttle. I'm around 320ish awtq. The clutch is rated at 80% over stock.. Since stock is around 290 tq (crank), 80% over should be 522 ftlbs, or ~390 awtq. I haven't ever launched with this clutch nor have I slipped it taking off or between gears. The break-in did suck though, took forever for the chatter to go away.
Half Crazed is offline   Reply With Quote
Old 12-02-2013, 11:17 PM   #27
08SubbySniper
Member Sales Rating: (4)
Member#: 361108
2005 STi
So do you recommend or not? Is my money better spend on a different clutch? I have 323tq at crank. I was told that exedy stage 1 will hold up if I'm not launching it. My stock clutch lasted over 25K before it started slipping after I did a turbo swop. I DD my car and never seen track but eventually plan on going to one.
08SubbySniper is offline   Reply With Quote
Old 12-03-2013, 12:05 AM   #28
Half Crazed
Member#: 321842
08 460/420w 08 STi
17 Stock WRB WRX
I posted my recommendation on page 1.
You should pick a clutch that's close to the tq output. Too strong and it causes more stress on other parts of drive train. If you're upgrading the clutch, you shouldn't stick with a stock/stage 1 clutch if you plan on gaining more power.
Make sure you read this: http://forums.nasioc.com/forums/show....php?p=9878792
As for clutches, I've heard good things about exedy clutches and south bend (I plan on trying the stage 2 south bend clutch soon).
This would probably work for your 08 wrx according to your profile: http://www.dxdracingclutches.com/eco...m?item_id=4269 -- of course, buy from a dealer to save $$.
All up to you, and your goals!
Old 12-04-2013, 11:30 AM   #29
Dominic.CCI
Member#: 303189
what was the part number on the clutch you had installed that you got from your buddy. Comp has had 2 versions of their Subaru STI clutches over the years. The original 15020-XXXX and the newer (much much better) 15030-XXXX series.
Dominic.CCI is offline   Reply With Quote
Old 12-04-2013, 06:57 PM   #30
Half Crazed
Member#: 321842
08 460/420w 08 STi
17 Stock WRB WRX
Interesting. I'm not sure (without pulling the clutch). If I had to bet, it was the older one. Good info!
Old 12-10-2013, 02:02 PM   #31
elias0930
Member#: 262239
2011 135i
i have had this clutch for about 1350 miles now and for the first 500 miles it seems like all this clutch did was chatter and burn. Its true the pedal still feels like oem as well. The chatter has started to go away but if i don't rev match when i downshift the clutch is very loud and sounds like its having trouble engaging. Am i the only one exeriencing this downshift issue?!
elias0930 is offline   Reply With Quote
Old 12-28-2013, 07:16 PM   #32
08SubbySniper
Member#: 361108
2005 STi
Finally got around to install my clutch kit. I ended up going with Competition Clutch Stage 2 with their 13.5 lbs light weight flywheel.
My stock clutch was really worn out
Comparing old with new
New clutch
Light weight flywheel installed
So far it feels smooth and I'm still getting use to the kit I will keep up with updates as I bake in the clutch.
Old 12-29-2013, 07:14 PM   #33
RSD Performance
Vendor Sales Rating: (8)
Member#: 346602
2013 Subaru WRX
www.rsdperformanceinc.com
Installed the Competition Clutch Stage 2 with flywheel on my '13 last week, after the last round of mods, the factory clutch was a no go.
So far only about 350 miles on the setup so I am taking it easy. No chatter, pedal feel is about the same. The traditional burn smell is almost gone and only noticed when the clutch was cold at startup.
I will repost after more miles logged. The '13 has 324hp on the dyno for note.
James
RSD
__________________
[B]
[/B]
[B]
[/B]
[COLOR=blue]Open Monday-Friday 8am-5pm CST, online ordering 24/7[/COLOR]
[COLOR=black]Telephone 219-851-1195 or email
[/COLOR]
[COLOR=blue]Your Source for Subaru WRX and STI performance parts and accessories.[/COLOR]
[COLOR=#0000ff][COLOR=black]Find us on Facebook [/COLOR]
[/COLOR]
RSD Performance is offline   Reply With Quote
Old 12-29-2013, 08:11 PM   #34
08SubbySniper
Member#: 361108
2005 STi
Originally Posted by RSD Performance View Post
Installed the Competition Clutch Stage 2 with flywheel on my '13 last week, after the last round of mods, the factory clutch was a no go. So far only about 350 miles on the setup so I am taking it easy. No chatter, pedal feel is about the same. The traditional burn smell is almost gone and only noticed when the clutch was cold at startup. I will repost after more miles logged. The '13 has 324hp on the dyno for note. James RSD
What's your mods? I'm pushing 325hp/323tq I plan on going cattless and maybe headers
Power Mods
Forced performance 68HTA turbo
750cc injectors
Fuel pump
Fmic
BOV
Cai
Invidia high flow catted cat back with the N1 single tip race exhaust
Mods
BC racing coilovers
Kartboy ss
Front shifter bushings
Old 12-29-2013, 08:47 PM   #35
RSD Performance
Member#: 346602
2013 Subaru WRX
Power Mods
750cc injectors
Fuel pump
Fmic
BOV
Cai
Mods
BC racing coilovers
Kartboy ss
Factory Turbo, PW Top mount IC, BOV, 1000cc injectors, fuel pump, Cobb Intake, Invidia header, N1 Race exhaust and catless DP, turbo inlet hose, air pump and TGV removed, Misho radiator, few other goodies.
James
RSD
__________________
[B]
[/B]
[B]
[/B]
[/COLOR]
[/COLOR]
Old 12-29-2013, 10:12 PM   #36
08SubbySniper
Member#: 361108
2005 STi
Very nice set up
Old 12-29-2013, 10:56 PM   #37
RSD Performance
Member#: 346602
2013 Subaru WRX
Very nice set up
Thanks, yours as well.
James
RSD
__________________
[B]
[/B]
[B]
[/B]
[/COLOR]
[/COLOR]
Old 01-01-2014, 03:43 AM   #38
El Wray
Member Sales Rating: (6)
Member#: 303030
2009 STI
Does the clutch + flywheel combo generate a CEL?
El Wray is offline   Reply With Quote
Old 01-01-2014, 04:01 AM   #39
08SubbySniper
Member#: 361108
2005 STi
Nope, the flywheel is 13.5 I believe anything under 10.0lbs will cause a CEL.
Old 01-01-2014, 10:01 PM   #40
RSD Performance
Member#: 346602
2013 Subaru WRX
No CEL here.
James
RSD
__________________
[B]
[/B]
[B]
[/B]
[/COLOR]
[/COLOR]
Old 01-14-2014, 10:09 AM   #41
z32turbokittehh
Member Sales Rating: (3)
Member#: 294908
2005 OBP STi
Has anyone had any fitment issues with CCI? I have a stage 4 and last night we pulled the motor and got everything ready to be put back together the pressure plate wouldn't fit without having to take off the dust shield. It's a solid 1 inch to big around the PP... I am being overnighted a new clutch kit from the guy I bought it from. Hopefully we don't have the same issue.
z32turbokittehh is offline   Reply With Quote
Old 01-17-2014, 06:25 PM   #42
Excision
Member Sales Rating: (25)
Member#: 294622
2007 STI - WRB
Perrin GTX3076r, Slow
i have had the competition stage 2 clutch with a ACT Streetlight flywheel for 5k miles. i hate it!! it smells NASTY really easy. i mean just pulling my car on ramps makes it smell! its holding the power fine. i haven't really launched my car hard yet though so i dont know if it grabs or not. my only complaint is the smell. also you guys says it's not stiff compared to stock. mine is stiff as **** compared to my friends 2011 STI and 2013 WRX.
2007 STI
Built motor
Perrin rotated GTX3076r kit
417whp/395tq 23 psi on straight 93 octane. COBB Plano Mustang Dyno
Excision is offline   Reply With Quote
Old 01-17-2014, 10:44 PM   #43
08SubbySniper
Member#: 361108
2005 STi
Originally Posted by Excision View Post
i have had the competition stage 2 clutch with a ACT Streetlight flywheel for 5k miles. i hate it!! it smells NASTY really easy. i mean just pulling my car on ramps makes it smell! its holding the power fine. i haven't really launched my car hard yet though so i dont know if it grabs or not. my only complaint is the smell. also you guys says it's not stiff compared to stock. mine is stiff as **** compared to my friends 2011 STI and 2013 WRX. 2007 STI Built motor Perrin rotated GTX3076r kit 417whp/395tq 23 psi on straight 93 octane. COBB Plano Mustang Dyno
I'm only about 1,300 miles on it and pedal feels about same as stock to me, smell went away but I do get it as well if I ride the clutch into my driveway or up hills, But it's not bad! I have not launched it yet but when I down shift it grabs hard once I get new tired ima launch it once or twice and see how it handles. I also have the light weight flywheel from Competition Clutch
2008 wrx
I'm on Cobb pro tune
Forced performance 68hta turbo
Fmic
Cai
High flow catted dp with Invidia N1 full race CBE
750cc injectors and bigger fuel pump
325whp/323tq on 19psi with Ca 91 octane
Old 02-01-2014, 05:49 AM   #44
Jayzwrexx
Member Sales Rating: (5)
Member#: 125927
2000 2.5rs
Brp
I've had this clutch installed for about 7 months now with about 8,000+ miles on it. This clutch grabs pretty hard which i love. I've launched it about 15-20 times or so with no issues what so ever. This clutch did have some chatter in the first 300 miles or so but went away. I have no complaints with this clutch at all.
2000 swapped Rs
Vf39 All bolt-ons
Jayzwrexx is offline   Reply With Quote
Old 02-01-2014, 10:52 AM   #45
08SubbySniper
Member#: 361108
2005 STi
Originally Posted by Jayzwrexx View Post
I've had this clutch installed for about 7 months now with about 8,000+ miles on it. This clutch grabs pretty hard which i love. I've launched it about 15-20 times or so with no issues what so ever. This clutch did have some chatter in the first 300 miles or so but went away. I have no complaints with this clutch at all. 2000 swapped Rs Vf39 All bolt-ons
That's good to hear I'm just over 2k on it and have no issues as well still haven't launched it tho but I have confidence that t will hold up I some hard launches!! Chatter is no issue to me, my car is loud and I'm partially deaf in my left ear haha
Old 02-01-2014, 01:13 PM   #46
Jayzwrexx
Member#: 125927
2000 2.5rs
Brp
My car is gutted so its noisy anyways and i DD it so im used to all the minor noises the car makes. I want to say i may of smelled my clutch no more then 2-3 times max.
Old 02-13-2014, 05:39 PM   #47
mkvaron
Member#: 326317
2011 WRX hatch
SSM
Good feedback in here, thanks! I am debating between the Comp Stage 2 or a Exedy Stage 1 Organic clutch, but there isn't much to read on people with 08+ WRXs on the Exedy. My 11 WRX is only stage 2 with no plans for insane power, but lots of track time. I am at 60K on the stock clutch with over a dozen track days and the need to daily drive it. I am liking the Comp Stage 2 more and more, but I wana make sure I evaluate all options. Hummm...
mkvaron is offline   Reply With Quote
Old 03-14-2014, 01:27 AM   #48
azsun
Member Sales Rating: (1)
Member#: 351553
Sorry to bring back an old thread, but you ever decide what clutch to go with? In the same boat and that clutch looks great on paper, still waiting to see what my tuner thinks of it (had suggested the ACT HD, but the torque capacity on this looks quite a bit better).
At 305w torque, stage 2 + PW TMIC but looking to throw a 440xt on soon...
azsun is offline   Reply With Quote
Old 04-02-2014, 07:21 PM   #49
SourceDecay
Member#: 311597
2012 WRX
I have had this clutch on my car for almost a year now...
...and I still frickin HATE it!!
Break in was terrible, and the car smelled like the worst version of a burning clutch smell that you can imagine with even the slightest amount of slipping. It also chattered like crazy.
So, you try to slip it less to minimize the nasty smell - bad idea. The clutch actually felt a little lighter than the stock one, but it grips much harder, so less slip given the same power results in pretty harsh starts that made me feel like I hadn't been driving stick shifts for the last fifteen years.
Eventually, I've learned to find the delicate balance which results in a smooth launch for daily driving, but if I'm not paying attention, it's still easy to have an unintentionally choppy start. Irritating, considering I've driven a lot of cars with higher capacity clutches than mine which didn't exhibit this trait.
I bought the clutch because, immediately after something around "stage 2," my stock clutch was useless. I do have to say that it never showed any signs of slipping or inability to hold power.
One big end rod bearing and a turbo later, my engine is stock again with the same clutch, and I'm still regretting my purchase.
I'm actually looking forward to this thing wearing out eventually so I can try something else. Anything else.
SourceDecay is offline   Reply With Quote
Old 04-02-2014, 07:30 PM   #50
majik1
Member#: 255841
2005 WTX STi
white
I don't have any of the issues that a few have been reporting. I recommend this clutch to anyone at stage 2 or larger power levels
majik1 is offline   Reply With Quote
FS : Delete NXTLVL Drivetrain 16 07-27-2011 04:26 PM
Competition Clutch Stage 2 Clutch Kit JasonOJordan Newbies & FAQs 5 10-08-2009 03:18 PM
FS: BNIB Competition Clutch Stage 2 : 02 - 05 WRX tvieira24 Drivetrain 3 03-08-2009 01:01 AM
Competition Clutch Stage 2 Clutch/Flywheel Combo + Free Fluid! VIPGarage Drivetrain 1 03-07-2009 01:23 AM
FS: RC 750cc injectors and Competition Clutch stage 3 sheikthin Private 'For Sale' Classifieds 5 07-29-2005 05:39 AM
